Old 11-05-2011, 05:17 PM   #603
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
Originally Posted by dadstoy
Got same one at O'Reilly Auto Parts today...$12.49
Blah blah! :-) ok so your was cheaper even with my shop discount. o'Reilly wants my business. Look like I better start comparing prices. :-).
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 11-05-2011, 05:20 PM   #604
1982 28' Airstream 280
Redwood City , California
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 11-05-2011, 05:22 PM   #605
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Despite what I have read and been told, the channel that the fin seal sits in is boxed in... there is no slip in or relief area top or bottom...
Looks like someone alread hacked the rubber seal channel...
I also got my seals from Andy, and what is odd is that the one i took out is deeper than the new one.. I dont think it will cover the gap between the panes.
I am taking my Dremel over there next time, and will be cutting a bit of it out!
Not the best of news, since both my right and left sides are shot.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-05-2011, 05:40 PM   #606
I did some research, and i am sure this fin seal is not gonna work well on my motorhome, for whatever reason.
Digging around I find you can get them with the seal and fiber up to 1/2 inch long, and the one i have is less than that i am sure.
Will call the place monday and find out what the deal is.
Old 11-05-2011, 08:43 PM   #607
Smartstream's Avatar
Port Angeles , Washington
When I did mine I took a Dremel with a small wheel and cut a horizontal slot at the top of the vertical slot. The seal is captured at the bottom and once slid in from the top it can't go anywhere.
Yes the new seal from Inland is smaller than the old but it didn't seem to be a problem going down the highway.
I have only done the front passenger window so far and it was very easy once I decided what to do with the vertical seal. The window does open and slide very nicely with the new gaskets in.
Sorry I don't have any pictures but I did it days before we left on our trip and just didn't have the time.
Cheers, Dan
Old 11-05-2011, 08:47 PM   #608
Thanks Dan,
Looks like you confirmed what I said, and need to do!
Old 11-06-2011, 11:11 AM   #609
Milton , Florida
Have either one of you Gentlemen done the, formerly furry, channel seals? Not sure how I get the old one out (or new one in).
Bill
navyspook is offline   Reply With Quote
Old 11-06-2011, 11:59 AM   #610
The channel seal or "Fuzzy Schlegle" as it its known is pretty easy.
I know there are a couple of threads on this, but will add my $0.02c opinion..
I had problems with my window locks, and also fouling the front glass as they slid, so I removed them by removing the 3 small phillips screws...
DONT LOOSE THEM!
I will be posting a refurbisment thread later for the lock/latch...
From outside the cabin...
Pull out and remove the grey lip seal... if you have one still!
From inside the Cabin..
With the window closed, I would pull the seal free of its channel, as it is normally stuck down.. then push it back into place... then slide the window forward into its fully open position.
Grab the channel seal and pull it out of its channel on the vertical section. Now gently hold the sliding window in position, and pull the seal rearward and out from under the glass... Thats why I suggest breaking it loose from the glue first!
Then repeat for the top part.
Remove the seal completely.
Slide the glass gently back until its about and Inch from closed, and grab it front and rear.
Lift it UP as far as it will go, and rotate the lower edge inboard out of the lower channel...
FYI... dont try to take the top edge out as it will foul on the interior trim, and on mine for some reason, it got stuck!
Remove the glass and store it safely!
Old 11-06-2011, 12:31 PM   #611
Bill
It was very easy. With the window closed using a sharp point or hook pull the front ends of the channel out of it's track braking it free of the adhesive. Push it back in the track,move the window forward and pull the rear of the channel out of the track.. Now using the rear half pull the channel and the window to the rear. Slide the window forward and repeat until the channel is free. You can now remove the window glass...carefully. The install is the reverse. Pull up a small section at a time and add glue.
Cheers, Dan
Old 11-06-2011, 01:34 PM   #612
My seal fit pretty well, and the only place I will add glue would be the upper forward part.
What did you do about the gutter holes Dan?
My seal has a metal lattice embedded, so you cannot cut it easily, and I was concerned about weakening the seal, so I read somewhere about using a red hot screwdriver to punch some drain holes?
Old 11-06-2011, 08:28 PM   #613
Milton , Florida
Thanks guys,
Sounds manageable...but being an AS not easy. Much like electronics and automotive systems, they were designed by people who knew they would never have to work on them. I'll check some of the other threads for pics, but your method sounds logical.
I'm hoping it will stop the leaks into the front seat floor area, or I'm building an Ark
Old 11-06-2011, 08:59 PM   #614
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
In a previous life, my moho had been in an accident that tore away the skin on the right front corner. It was missing the passenger side window entirely when I bought it. I actually found the window assembly on this site, and purchased it, before buying the moho, so for a brief period of time my "Airstream ownership experience" consisted solely of a window.
We spent some real quality time together, just the two of us, me and my window. Moho life was a lot simpler (cheaper) then.
When I finally rebuilt the window (passenger side), the entire unit (frame, glass, everything) was sitting on a bench. The moho had no interior door panel or trim in place (everything had been shattered in the accident, so I just had a bunch of broken pieces). You could sit in the passenger seat and look right at the exterior skin and repaired frame work and get a real good look at how it all went together.
One thing that I recall noticing about the window (before installing it) was a separation in the joint where the extruded bottom channel connects to the forward, inclined channel at the A-pillar. While you have the "fuzzy channel" out for replacement, you might want to make sure that you don't have a potential leak at this location by applying some sealant at that spot.
Definitely be certain that the weep holes are clean and clear to do their job, otherwise the bottom track will overflow. Since you'll be installing new channel, it should be easy to fit the channel, mark the spots where it covers the weeps, and cut a fair bit of material out of the way before final installation. The hot screwdriver might be a solution "after the fact". I did several tests with a hose to prove that the channel was able to drain. Ultimately, I added two 1/4" drain holes to the bottom channel that I routed down through the floor with hoses to improve drainage (but again, I had no interior trim or floor (which had rotted) in place at the time.
streamquest is offline   Reply With Quote
Old 11-06-2011, 09:35 PM   #615
Milton , Florida
Stream,
Thanks, in a former life I lived in Nantasket Junction, but got tired of White Easters. Can't imagine buying a unit with a part missing...you get my vote. Of course, at least you knew what was wrong, I have the pleasure of discovering new charms every week. I'm on the water here, so I lose hurricane season every year...now I have 2 months to get this stuff done before the temp drops.
Thanks again to all.
Bill
Old 11-07-2011, 12:12 AM   #616
1936 20' Clipper
1947 22' Liner
Curtis Wright
Bill,
We barely missed a white Halloween here last week. Seventy five miles west of me they got two feet of heavy snow on fully leafed trees. Some places still haven't gotten their power back, and its getting pretty cold at night lately.
I'm almost two years down the road with the moho now, and still discovering new charms every day. It's the gift that keeps on giving.
Charly
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 10:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-18-2011 11:06 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 10:13 PM
