Old 10-14-2011, 04:32 PM   #519
1987 34.5' Airstream 345
Milton , Florida
Your defense for roadway blinding is simple. You're driving a classic AS Moho, therefore not guilty by reason of insanity. I was really hoping that you found a source of inexpensive (cheap) latches.
navyspook is offline   Reply With Quote
Old 10-14-2011, 08:58 PM   #520
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Key,
What's next??? You've gone from stills to motion pictures!!
Get an agent, you have star potential. I see a mini series!
Call the History Channel. This could be every bit as good as "Pickers".
Charly
streamquest is offline   Reply With Quote
Old 10-14-2011, 09:24 PM   #521
Yeah Right Charly... there is plenty going on with you too!
LOL, My life show is kinda scary...
Its more of a mix of: Stanford and Son's, Dirty Jobs, American Chopper, Junkyard Wars, Myth Buster's and MacGuyver...
Old 10-14-2011, 11:02 PM   #522
Exhausted...
Barely slept all night... had food poisoning or something... hot and cold sweats, and stomach cramps until 3am, then got rid of it all...
Finally got to sleep around 5am..
Slept fitfully until 7am, got up, walked the dogs about 2 miles.
Prepped my little 190D for a blast to Hesperia... about 100 miles away, to pick up the Jeep Cherokee transmission.
Called Inland RV so I could grab my Window seals on the way..
Collected my Tools and list for a stop at the Pick&Pull in Ontario.
Stopped off at the Storage to pay my bill and drop off some stuff I had finished at the AS.
Got a frantic call from the Step-Daughter...
My Black Jeep that she is driving until the Cherokee is fixed, has Acrid Black Smoke pouring from under the hood...
She did as instructed(rare), quickly exited the freeway, parked and got out.
The smoke stopped.
She got a ride to work...
My Pick&Pull stop is cancelled.
Drive to Corona, stop in and get my parts, and have a great chat with Andy, before blasting to Hesperia...
Blasting?
Well, my 190D HAD... 75 hp, and AC when it left the factory..
I think some of the ponies escaped as well as the AC...
Riverside County was a Balmy 90deg today, and the traffic and long hill on the 15 was a drain...
Arrived at the Salvage yard, and loaded the Transmission... and set off for LA..
Friday Traffic...
Arrived at the Black Jeep... diagnosed a seized Electric fan.
Snipped off fan wires, lifted the 200lb transmission out of the mercedes and into the Jeep solo....
Gave the Step Daughter the Diesel to drive and nursed the Jeep home with a combo of heater on full and gentle cruising.
A transmission, damsel in distress, Airstream Parts, and nearly 300 miles...
A large Vodka Tonic was waiting when I walked in the door...
Now I am off to bed.... Goodnight all..
Zzzzzzzzzzzz
Old 10-15-2011, 02:01 AM   #523
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
wow, and here I was wondering what you did all day yesterday! lol.
Get your much needed rest! Look forward to seeing you back on the Airstream, but sounds as if you have plenty to keep you busy for awhile. Thanks, Derek
Old 10-16-2011, 05:02 PM   #524
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Originally Posted by streamquest
Hi Key,
I can see that you've got the fever for sure. It is like a drug. The more you polish, the more you want to polish. Looks fantastic!! Be aware that the thin black plastic belt-line strip molding is NO LONGER AVAILABLE, so use caution when you're polishing around it. If you plan on polishing the aluminum molding that contains it, you might want to slip out the plastic for safe keeping.
Just when I thought I was done with the polishing on my coach, your recent display of polished drawer fronts inspired me to strip the black paint that covered my drawers, and everything below the rub rail. What an improvement. The total shape of the body is much more apparent now that everything is shiny. The whole coach appears to sit a bit lower as well.
I am a bit bugged by the look of the vertical line of separation where the aluminum rocker panels meet the rear banana wrap. I'm thinking of adding a bit of aluminum sheet to carry the shiny look up, over, and around the rear bumper trim. I'll post some pics of my silver duct tape mock-ups so you can see what I mean.
Charly.
Out of doors mart has the belt line. I just bought to redo mine. Unless I bought the last of it. They also have other colors if you want.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 10-16-2011, 06:38 PM   #525
1936 20' Clipper
1947 22' Liner
Curtis Wright
Myrtle lynn,
When you say the "belt line", do you mean the really thin strip up high, or the wider stuff down low which I think is called "rub rail"?? Thanks.
Charly.
Old 10-16-2011, 07:14 PM   #526
crazeevw's Avatar
Myrtle Lynn, if it's the thin beltline, halfway up the moho, I sure want to know! Mine is in sad shape. Thanks, Derek
Old 10-17-2011, 07:45 PM   #527
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Yeah they have both. Thick and the thin ones. Same color and others. Check it out.
Athens GA
Old 10-18-2011, 09:07 PM   #528
As I posted, I have been kinda sick.... but trying to push thru it..
Stripped and treated the rust on the Streetside Drawer, and its in primer now..
Also found the energy to pull the pan off the used transmission for the Jeep...
The paperwork says it had 63k miles when the doner was in a rollover, and the inside story says its good... we will see, and it has a 90 day warrantee.
Looks good!
Also, on a sidenote, I think I had a little score...
Found and bought a pair of NIB (New in Box)... Velvac 2025 heated and powered mirrors...
So cheap, I am still pinching myself..
Not got them yet, so fingers crossed, as they are in transit.
They look so similar to the Ramco Units people have fitted, so I hope they will work!
They have heated upper and lower mirrors, altho the lower wide angle is manual.
I will need to find the Switch, heater switch, and maybe the extension harnesses when I get around to fitting them.
These:
Velvac Photos
Old 10-18-2011, 09:25 PM   #529
crazeevw's Avatar
Steve, gotta know where the mirrors you found came from, if you don't mind sharing. Ebay? Craigslist? Less than $200? Less than $150? Heck, less than $100??? My Ramco are power and heated. I'll get a photo of the dash switch and post for you tomorrow. Will say this, went to clean the mirrors on mine, and the lower wide angle on the passenger side, decided that the glue holding it wasn't good enough, and took a swan dive to the ground. Thank goodness, Airstream is parked on grass, or I'd be looking for 2 replacement wide angle lenses!
Thanks, Derek
Old 10-18-2011, 09:34 PM   #530
Craigslist...
And.... $135... for the pair... New..
Had to sell my body to find it... Lucky the GF is so generous...
Old 10-19-2011, 08:49 AM   #531
Milton , Florida
Steve,
Great find...Cali Craigslist lists are much better than mine. I have to trek to Atlanta or down Derek's way to find anything. I've tried selling my body lately, but age has made it an as is, where is, transaction.
Old 10-19-2011, 11:09 AM   #532
Hi Bill, You box arrived yesterday... Thankyou Sir!
I am working my debt to the GF off by doing this Transmission swap.. I think I am cheap!
Actually found them in Florida!
Excuse me if I didnt tell you guys...
Chatted back and forth, got pics, did the deal via Paypal, and have a tracking number... Fingers crossed.
The mirrors on mine are junk, so it was on my wish list.
My base measurements tell me it should be fine, but I will have to enlarge or change the holes slightly and add a plate behind to take the bolts.
These do not have a Blinker on the arm, altho its an option on that mirror series.
There is a removable plate where the Blinker goes... I am thinking I can find a LED Marker that will do the job.
I Emailed Velvac about the switch and wire harness extentions I will need, and this is the prompt reply I got...
Part 747198 is the switch kit that consists of the mirror control switch, heater switch and cover plate. The price is $114.13, The wire harness are not included. To commonly used harness are part 747328 an 11' wire harness, price $31.40 and part 747329 a 5.5' harness price $23.63. To order parts you could contact our customer service department at 1 800 783 8871.
Tim La Bonte
Velvac Inc
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 10:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-18-2011 11:06 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 10:13 PM
