Old 09-23-2011, 07:22 PM   #421
You are a smart man Navyspook!
I had that thought which is why I designed it like this!
I did have a prob with the holes, and messed one up, and had to used this little gem I have in the Garage...
I also welded up a casting Voil on the top center lip...
Old 09-23-2011, 07:38 PM   #422
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Steve,
Any possibilities of taking orders on your mod?
Thanks, Derek
Old 09-23-2011, 11:01 PM   #423
1982 28' Airstream 280
Redwood City , California
Got a new gasket and screen from Inland, may look at changing tomorrow, but supposed to be 99 degrees, down from 103 today.
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 09-24-2011, 10:53 AM   #424
1987 34.5' Airstream 345
Milton , Florida
Steve,
Agree with Derek, sign me up if you make any extra. Anything to eliminate a possible leak is a good thing. I will need to figure out the whole Airstream rivet process since I haven't actually drilled any out yet, or replaced any.
navyspook is offline   Reply With Quote
Old 09-24-2011, 12:23 PM   #425
Well, thats cool, and a vindication of my idea that others want some!
Now I need to work on the design of them and have some better ideas!
Old 09-24-2011, 03:37 PM   #426
crazeevw's Avatar
I'll ship the new vent covers to you Steve, for your modification, then have you ship them to me here in the 'Sunshine State' if that works for you.....
Thanks, Derek
Old 09-24-2011, 04:05 PM   #427
As the Vents require drilling, and as I proved, even with my skillset I still messed up.
Working on something better for the mounting method.
I am thinking people would prefer not to modify or drill their vents, yet have
the benefits of keeping leaves, pine needles, as well as water and sunlight out of the vents?
Last night, I sat down with a good friend of mine who is a Product Designer, and we thrashed out about 5 different ways to do this, so watch this space!
Seems there is a lot of interest.. look here...
http://www.airforums.com/forums/f455...ons-82910.html
Old 09-26-2011, 11:20 AM   #428
Thanks, Derek
Why are you getting new vent Covers Derek?
Old 09-27-2011, 09:14 AM   #429
crazeevw's Avatar
Hi Steve,
Up on roof past few days trying to strip off the gray roofing paint up there. While there, I looked at vent covers and realized that there isn't any protective screen material on the street side vent. Figure if I'm going to have to remove covers, may as well try and get all new gasket and screen. Love the appearance of yours, all shined up with that great cover on the top. Let me know if you're interested in doing this, I'll get covers shipped to you and figure out how to get them to me.
Thanks, Derek
Old 09-29-2011, 08:37 AM   #430
Milton , Florida
I will also be replacing my screens and gaskets on the vents soon, but I've never tackled the rivets before. What's the best removal method, drilling, Dremel grinder, or other. I also saw that 3 sizes of rivets are available...what's the right size for the roof vents? One more needy question...has anyone used stainless steel screws instead of rivets?
Thanks for the inspiration,
Bill
Old 09-29-2011, 08:53 AM   #431
Bill,
No rivets on the vent, just pan headed Phillips screws...
Make sure you protect the bodywork, as due to the curve you have to lean the ladder against it. I made a piece of 4x2 and covered it with carpet and made a wire hook so I can hang it on whatever rung I need it on...
Will post a pic later.
Taking a suggestion in the Vent section of the Forum, I will be using a piece of pond liner or some roofing material, as I want it to last..
Looks like my camera took a dump on me!
Grrr!
Old 09-29-2011, 10:18 AM   #432
Yesterday, I got into the water tank and its plumbing...
Here is how it looked before..
Now, the layout is pretty much finalized.
Removed all of the underbed cross beams, and the one support.
Unscrewed the wrongly positioned Electrical box, and moved it aside, and will have to make a new divider or bracket for it.
I flipped the 15 gallon 90 deg onto its edge, from how it was.
This keeps the filler neck inline with the external inlet, and also minimises the footprint... I just need to swap the water supply and breather pipes, and add a new support strap and insulation.
My "Free" 70 gallon tank only has one inlet, and a huge cap. I will have to figure out how to vent it, either I will drill the cap, or drill the top of the tank.
There will be a T and and a ball valve linking the 70 to the system... when it is closed, the water is only fed and received by the 15g... but when its open, the water will fill into the 15g tank, but equalize the level in both tanks... so I have the option of 15 gallons for travel, saving about 500lb of water sloshing about, but I can carry/store 85g max for boondocking, which is only 5g more than the stock system. I think the free tank, plus the little extra complexity will be worth it.
Here is how it will look...
As alway, there is more stuff to fix...The pipe from the furnace was toast, so need to replace them both... I like that 4" Aluminum Flex Dryer ducting better anyway!
Old 09-29-2011, 10:56 AM   #433
Further to the water tank post above, I spent 2 hours at Home Depot trying to figure out how to repair/adapt the original Airstream Pex piping to fix the issues...
I will need to get some advice in the Trailer Plumbing thread!
Have a bad area of flooring in the rear corner probably from a leak from the upper streetside marker light that was missing its sealing.
It will need to replaced, but not now.
What a mess!
I CAN make this better!
Looking in the outside compartment, I have this mess to fix too...
Because the Hose reel pipe was broken someone cut the Pex pipe off, and attached the inlet hose to that... Messed up!
Note also the nice ready to leak kinked pipe where it goes up thru the floor!
So, here we go!
Unbolted the 6 x 9/16" bolts holding the lower floor, to get at the hose reel.
They were rusty, but a bit of WD40 got them moving.
Pulled out the Water Hose Reel, just 2 x 9/16 bolt thru the rear of the compartment.
I will replace the Hose, clean it up, and get it all working correctly.
The Electrical reel has 25' of cord, and is narrower, I will try to fit a 50' length on...
This compartment will be de-rusted and painted, I think with Silver paint to make it lighter in there.
The floor panel will get the same treatment but will be bedlinered like the compartments, and the drop down door will be getting a polish.
Old 09-29-2011, 11:08 AM   #434
before I went over to do the work above, I was working on the Drawer top for the storage compartment.
The ABS top is still ongoing as I am still fixing cracks, etc, but the lid was finished... but I was not happy with it.
I decided to strip off the paint and polish it!
Stripped..
Polished...
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 10:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-18-2011 11:06 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 10:13 PM
