Old 04-04-2010, 01:00 PM   #29
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
hitch upgrade
We have a 345 up near LA, had our hitch upgraded to 10000 lbs by a local shop in Glendale. Enjoy your journey home. You may want to buy fanbelts and radiator hoses before you start back.
[QUOTE=Keyair;832684]Mmmm... I dont know!
When I get it back, I will mod the hitch in a similar way to what they did in Elkhart, but I want mine to bolt on, and also add some protection against impact with the ground on ramps, which i assume is a problem with that much rear overhang.
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 04-04-2010, 02:32 PM   #30
Thanks for the info.
Assuming you were happy with the shop's work, can you post up who did it, and maybe some pics of their work?
Can you post or PM me what it cost?
I like to travel with spares, and belts/hoses are primary stuff, like fluids to have onboard. Since I will be flying in to KS, I cannot take much with me. I guess I am kinda lost with the spares and supplies bit... its not like you can walk into a Auto supply place and ask for hoses for an Airstream... or is it?
Is there a knowledge base that says the radiator hoses are from a 1984 Suburban 1 ton or something?
Plan to buy a Craftsman tool kit when I get there for the trip.
Old 04-04-2010, 06:36 PM   #31
The nice Earthquake we had here this afternoon makes me happy that I will have a "safe" place to go if or rather when a big one hits!
We were rockin and rollin!
Old 04-04-2010, 07:09 PM   #32
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Knowing your year model and that it is a P30 Van chassis is generally enough to get most driveline parts at the national auto parts stores.
Specialty items can sometimes be found at Millsupply.com in the stepvan catalog.
Airstream parts of course from your local, or not so local Airstream dealers.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 04-04-2010, 07:15 PM   #33
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I use stock 20 " wipers on my MH. Available at any auto store. I didn't use any of the plastic clips that come with the blade. My old blade was attached with a nut & bolt. I just drilled the new blade & used new nut & bolt. Left photo is top view, Right is bottom view
Ricky
ID:	99422   Click image for larger version
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 04-05-2010, 08:33 AM   #34
str8strm's Avatar
hitch info
It was Heacock welding in glendale. I believe it was $600. Rainy here and moho is in storage so no pics today.
HEACOCK HORSE TRAILERS (818) 242-0211 GLENDALE, CA
AIR 7992
Old 04-06-2010, 10:24 AM   #35
When its home, I will give them a call, sounds like a good place!
At least the rain has gone!
Anyone know if there ever was a service or shop manual for this model and year?
Does it have air suspension?
Old 04-06-2010, 02:05 PM   #36
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Yes to both. If you search here you should be able to get info on how to order. I think Brad (bkhaler) has the 84 MH manual in a pdf.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 04-10-2010, 10:20 AM   #37
Thanks Guy, made contact with Brad!
I fly out to pick up the MH on April 20th.
The PO, have replaced the fresh water tank, put new wiper blades on, and filled the Propane tank. They report all the heaters and A/C units, as well as hot water is all functional and ready for my drive.
I went to my nearest RV parking yesterday and surprised to see a 345 in there... sadly the tags were 2008, so clearly not used for a while. What was odd, was the whole lower was sprayed charcoal metalic and the upper was sprayed silver... both had the clearcoat peeling.
I looked under the rear to get a first hand look at the towhitch etc, and noticed a pair of tubular bars hanging down just rearward of the huge tank that is in the back to protect it.
Is that the gas tank?
Do all 345's have that protection?
Old 04-10-2010, 01:08 PM   #38
345bill's Avatar
Las Vegas , Nevada
[QUOTE=Keyair;836048
Do all 345's have that protection?[/QUOTE]
Don't know if all 345's are the same but here's the gas tank and tubes to protect it on mine.
Name:	Tank & Guards.jpg
345bill is offline   Reply With Quote
Old 04-10-2010, 01:11 PM   #39
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I don't know if that's factory, but a damn good idea!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-10-2010, 03:25 PM   #40
Bill, that is identical to the one I looked at!
Right down to the ground flats in the bends!
Old 04-10-2010, 08:12 PM   #41
345bill's Avatar
Las Vegas , Nevada
Keyair, Ya know when I was looking at the picture this a/m is first time I noticed the flat spots, so I went back outside and sure enough...they're doing intended job. I do remember hearing them scrape, once, on a very steep driveway apron. They probably end up protecting more than just the tank.
Mike, my guess is they are from the factory. If all 345's don't have them it would be well worth making some.
Guy99, When I was reading about your repeat caster damage I got to wondering if this application would remedy that??
Old 04-11-2010, 08:57 AM   #42
Silverton , Colorado
We have them on ours, and it's a GOOD thing, as we've used them...
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
« Mistress | Top | - »
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
dznf0g
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 10:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-18-2011 11:06 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 10:13 PM
