Old 09-03-2011, 04:02 PM   #365
My Genset says 82 hours....
The wire that connects it to the gen is not connected tho...
Anyone know where it should go?
Old 09-03-2011, 05:41 PM   #366
Laid here "On Ice" I have time to research...
My Hours meter, I need to find out if its "Spark, 120v, or 12v" to know where the wire should go..
Also, important info on Genset noise levels.
There is a National Park Maximum Noise Level..
National Park Service sound level requirements (60 dB(A) @ 50 ft) for national park use.
Onan quote their newest LPG powered 6500W unit as 67Db(A)@ 10' at half load..
I will have to retest now at 50' but from my earlier test,
I did set my Meter to just show me the peak level too, but I think thas a fair way to test.
With no soundproofing, its 65.5Db at 6' with no load..
And 73Db at about 10' on full load..
And
Old 09-03-2011, 06:03 PM   #367
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
That gen set got no work over the years, not a good thing.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-03-2011, 06:38 PM   #368
LOL, my guess is that it was dripping so much oil it was too expensive to run!
BP should have bought it cos it leaked less than some Wells they own..
Some Arab states have offered me millions for the land it is parked on..
Seriously tho, it seems to run ok..
Old 09-05-2011, 06:43 PM   #369
Oh, here is what I used for the window shields..
Old 09-05-2011, 06:49 PM   #370
Roof Vents...
When i was last over working on the 345, i had the ladder out to look at the state of my roof, and what needs to be resealed/fixed.
I am planning to paint it white from the roof joints to the end caps to keep the temperatures down, and save me polishing too.
Evertime we have rain, i have a wet floor in the kerbside Bedroom closet, so was looking at the joints and seams above that for clues..
I noticed something on the roof vent that looked suspect, and needed some opinion and advice...
Both roof vents, left and right, have no cap on them...
it just looked like some screen mesh inside, but even that is a mess..
What stops water going inside?
Old 09-05-2011, 07:41 PM   #371
Mike Leary's Avatar
Images: 11
It is suspect, and prolly the cause of most of your leakage. The gasket is actually a rubber boot that fits over the "gas vent" pipe from your grey/black water tanks. The screen is to protect from critters getting down there. Andy has a kit with screen to fix it. Getting the old Vulcum off is a pain, but a chisel and the Dremmel and a clean with solvent will do the trick. I had water in the same place, cured. Use a couple of wire tires to secure the vent screen.
Old 09-05-2011, 08:48 PM   #372
Thanks for that info Mike.
I searched Inland RV's site and found it... Sewer vent pipe is the term you need to find info.
So now I know how it should look, and is it me, but that is a terrible design!
So, any rain either falls down the Vent pipe, or, as the vent pipe is ROUND and the Aluminum cap hole is RECTANGULAR, it falls between the cap and pipe..
I now find there should be 2 drain holes in the cap to let this water out?
See post #19 on this thread...
http://www.airforums.com/forums/f163...s-24437-2.html
Now look at my vent...
If there is drain holes, someone filled them in!
Old 09-05-2011, 09:01 PM   #373
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
It's just some of the joy's of Airstream ownership my friend.
Cheers, Dan
Old 09-06-2011, 09:44 AM   #374
Mike Leary's Avatar
Images: 11
I would not be suprised a lot of guys do the same thing. I used a couple of dull drill bits to clean the Vulkem from the drains. I also used a dab of Parbond on the screws, which may have been stupid. I figure those boots lasted twenty years, so I'll not be replacing them. Someone will curse me, I'm sure.
Old 09-06-2011, 09:49 AM   #375
I am thinking I might add a small curved piece of Aluminum about as big as a playng card, to the top of the vent stack.
If I put it spaced up about 1/2" it will still alow the stack to vent, but will keep direct rain out.
Also it will protect the seal and sealant from UV degradation.
What do you guys think?
Old 09-06-2011, 09:55 AM   #376
Mike Leary's Avatar
Images: 11
Watch out the covers don't become sails and vibrate you out of your mind. Seriously, you'll find the new boot fits very snug over the vent stack. The boot will prolly have to be trimmed to fit the enclosure, I used a matt knife.
Old 09-06-2011, 09:42 PM   #377
1987 34.5' Airstream 345
Milton , Florida
Another Newbie who just picked up an '87 345 last Friday, trying to beat Tropical Storm Lee...it was interesting and not really the best day to learn to drive a wingless C-130. Had lots of rain and wind (did any of you know that Airstreams have occasionally leaked) but I did miss the worst of the storm.
PO had told me about the 2 leaks, not necessarily the velocity of them. Top of windshield and top of left rear curved window. It was kinda like driving one my old Healey 3000's...wiping water with one hand and steering with the other.
Thank you all for the opinions, facts, humor, and DYI pics (especially AirRowan). Tremendously helpful, but I ignored most it and bought it anyway. I feel the opposite of Woody Allen who said, "I wouldn't want to be a member of any club who would have me for a member". I may have bought it just to be a member, but the official reason is "Temporary Insanity".
I do have real question that I haven't able to find a thread about. Can I paint the with White Elastromeric roofing coating to keep it cooler and eliminate future leaks. It's probably here somewhere, but I can't find it...Thanks again
navyspook is offline   Reply With Quote
Old 09-06-2011, 09:54 PM   #378
Well HELLO and welcome!
Wingless C-130 indeed...
Yes, I just wanted one, and was not afraid of a project, so went for it!
When your feet hit the ground, start yourself a thread and fire away!
Also, post us some pics of your new baby in the Classic Picture thread too!
White roof stories you will find in the trailer exterior restoration section..
A quick search showed this good thread up..
http://www.airforums.com/forums/f478...ons-63981.html
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
