Old 03-11-2019, 08:05 AM   #2227
Hi Dean,
I started a thread up in the Trailer, Exterior, Roof section that has opinions flowing, might be worth a read. Some people are stuck on the Henryís Solarflex silicon product.... but I shied away from it, rightly or wrongly due to the silicon in Airstream saga. Plus Enviro white is an elastomeric and has a 12 year warranty.
The Enviro white seems like it needs no crazy prep, and no primer.
My roof, as per the pics, was clean... ish, weathered, but no clearcoat or paint visible. I went over it with my Eastwood SCT, which is a drum sanding tool, and a Woven drum thatís like scotch pad. I was down to bright aluminum pretty quick. I used a SS wire brush in the detail areas, and that worked well and quick too. Iíve been told not to use a normal steel wire brush on Aluminum as it can embed steel dust, which contaminated the surface and u can get rust! So SS only.
I think as long as the paint is well stuck it should be fine. If not, SS brush the loose bits.
Old 03-12-2019, 11:03 AM   #2228
I am not sure what on earth is going on, but I have ordered a bunch of Solar Panel kits this week.
I have to share...
Maybe a scam, but with Paypal Protection, and added Squaretrade 2 year warranty for $10...
Im just interested in the panels.... the rest I will see.
https://www.ebay.com/itm/1500w-Flexi...53.m2749.l2649
Old 03-12-2019, 10:29 PM   #2229
This gem arrived today.
NIB NOS Jabsco 5Ē Spot/flood light, with remote control unit, cable, connectors and 25í extension cable.
Old 03-12-2019, 11:59 PM   #2230
Kreimer's Avatar
1965 22' Safari
1987 34.5' Airstream 345
Kansas city , Missouri
Nice! You by any chance have the old remote panel for sale if it looks like the one I am looking for?Click image for larger version
Kreimer is offline   Reply With Quote
Old 03-13-2019, 01:08 AM   #2231
My 345 never had a spotlight on the roof as far as I can tell. I have 3 other lights I have collected over the years, and one other remote, but it is not the same as yours. The other remote looks like the one I just got, but I think itís cast aluminum, as itís like 3x the weight!
The only thing I donít like about my new purchase is itís the short base version.
Here is the new one with the short base next to a used one that has the tall base.
The extra height is clearly visible, and I assume extrapolates into better down angle to see things closer to the MH
I might investigate swapping the bases.
Seriously thinking about putting one on the rear of the MH with the control in the bedroom. You never know where you might be when you need to light someone or something up!
Magnet18 and I were back and forth all day discussing the LED conversion options. We might have a plan that gives Spot and flood, similar light output, and longer life than the $80 incandescent stock bulbs.
Took a break from hammering aluminum to start building a prototype Solar Hot Water Heater Panel. I started a thread up in the plumbing, Hot water section.
A 2í x 3í piece of copper sheet and 50í of 1/4Ē OD copper pipe will be the basis for the test panel.
Layout of pipe routing.
Rough placement of piping.
Close, but no cigar. I need about 4í more pipe!
Ends on the upper on left radius of the return
Iíve seen panels, both smaller, and less surface area that this one produce 150f water easily. The idea is to use a combo of Solar electric, and This panel to cover all my hot water needs eventually.
Old 03-13-2019, 10:27 AM   #2232
Ive not seen that style of controller before Kreimer.
This is the style I have 2x of... Spendy!
https://www.ebay.com/itm/Jabsco-4367...EAAOSwJRZafnTI
Is it just the direction knob thats missing?
I think they maybe available separately?
This is the closest one I found in a search.
https://www.ebay.com/itm/Jabsco-Xyle...AAAOSwmgJY3sro
Old 03-13-2019, 10:48 AM   #2233
Kreimer's Avatar
1965 22' Safari
The switches in the back of the panel got brittle and have almost disintegrated. I probably just need to get a whole new switch. I could probably figure out how to wire to a new style if I had to. Iíll keep lookin! I like the lights you got. Much better looking than the original that is on ours.
Old 03-13-2019, 11:20 AM   #2234
Ok.
They are pretty deep, so make sure you have clearance(Clarence, LOL).
I can easily give you a size for the one I have, as its to hand, but its maybe 3".
I've seen your work, and fabricating a sheet aluminum plate, to let the switch into would be cake.
Let me know if you need anything!
Old 03-15-2019, 10:54 PM   #2235
First...
I apologize for posting the Solar Panel deal on EBay.
If it seems to good to be true, it normally is, was the truth.
Got refunded today.
Oh well, I was hopeful.
But today was Airstream day, and what a day it was!
Installed the Maxxfan. Not 100% happy with my efforts today. It fitted ok, it works, but there is a ripple in the roof, behind the fan, caused by a flat fan surround and a curved roof. Itís on, itís sealed, but I might revisit it later.
ID:	335807Click image for larger version
ID:	335808Click image for larger version
Very pleased with the look, and function. Love the fact I can leave it up to let the Motorhome breath!
I think there is another in my near future for the front!
The 10 speed fan is near silent on its lowest setting and pulls 0.5amps in that mode, and 2.7a at warp 10!
How do I know this?
Yup, I finally fitted my Trimetric 2025rv Battery Monitor after about 4 years in its box!
ID:	335810Click image for larger version
Also confirmed that my little 32w Solar Panel was happily pumping between 1.5 and 1.7 amps into the restored house batteries.
Old 03-15-2019, 11:34 PM   #2236
That done, today was warmer than my last day there, so I took a step back to look at the results of the roof paint project.
First thing I had noticed was that the white painted section was cool to the touch...
The IR thermometer says... 87.8f.
On the uncoated part of the roof, which is tricky to read, I got 98f.
A little later, I was inside the bedroom, finishing the wiring for the new vent, and took another reading.
Ceiling under white painted section.
91f.
And off to the side...
105f.
Canít argue with that!
Old 03-16-2019, 10:36 AM   #2237
A few years back we had a slab leak in the house. The restoration involved replacing the downstairs vinyl plank flooring. I salvaged the good pieces to maybe use in the Airstream.
I compared the flooring to the cream and brown leather I am planning to use, and was pleased with the color contrast, and I think it works.
So, I took some pieces over to see how it looked with the cabinetry. Not ideal, but I will need to refinish it, so it could go a shade darker anyway.
I tested in the entrance, ripping up some of the linoleum and also the 1/4Ē ply beneath it. Found wet flooring below that, which I need to address.
Like it.
Due to constraints of the pieces I have(lots of shorter pieces), I think Iím going with the orientation shown, which is 90deg to what most do.
The step area will be the diamond plate shown, but the riser will be the plank. If I donít like it, I can pull it out as it will be a drop in piece.
One thing I did spot, that concerned me, and I hadnít noticed before, was the impact of the Reflectex window covers I have been using. In the bedroom rear window, it had sagged a little and the I think had formed a little parabolic mirror.
Vinyl wall covering has been hurt!
I think I need to deal with the sagging before summer comes.
Old 03-16-2019, 10:51 AM   #2238
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Hey Steve, be careful when you get to wrapping your step riser. When I did mine I found that there isn't much clearance between the screen door and the front face of the front corners. I needed to plane down my walnut material to about 1/2" so there was clearance when door is shut. Just a heads up.
Mike
mayco is offline   Reply With Quote
Old 03-16-2019, 10:54 AM   #2239
mayco's Avatar
Old 03-16-2019, 11:52 AM   #2240
Gorgeous!
Go ya, that is on my radar now.
The flooring I am using, is pretty thin... under 1/4", Can't beat the price tho!
Also, your step, and configuration looks different.
The step is shallower, than mine and comes right to the door, where as mine is offset back from the door.
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 10:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-18-2011 11:06 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 10:13 PM
