Old 05-13-2011, 12:02 PM   #211
I spent about an hour looking thru all the pics I have collected, as well as here and Fred's looking for an answer...
Either they are different years, or the pics are too low quality to see..
Old 05-13-2011, 12:20 PM   #212
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Are the screens still in the back of the scoops?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-13-2011, 12:33 PM   #213
Yes, If I remember rightly, there is metal mesh over the inside of each scoop..
Old 05-13-2011, 12:50 PM   #214
Mike Leary's Avatar
Images: 11
Our doors look alike, are the scoops plastic (abs)?
Old 05-13-2011, 01:05 PM   #215
I thought they were metal, but will check!
Old 05-13-2011, 01:16 PM   #216
Mike Leary's Avatar
Images: 11
Judging from the amount of heat damage to the insulation, I'd be real tempted to pull those scoops; who the heck needs them? A fan system perhaps if those gen sets run that hot.
Old 05-13-2011, 01:31 PM   #217
To be honest Mike, even that same insulation that is in my spare wheel area is failing, so not sure how much of it is heat related.
After talking in detail to the Soundproofing guy, and thinking about getting it done,and done right, I think I am gonna mount a pair of 180mm Computer case fans, to the upper door louvers to suck air out when the Generator is running... So, like a 110V computer power supply powering them?
Old 05-13-2011, 01:44 PM   #218
So, here is my door, as I posted over on SS's thread...
Here is how my genset looks... Oil leaks and all...
Underside is soaked...
Old 05-13-2011, 01:52 PM   #219
I am planning to do what Brad did here:
http://www.airforums.com/forums/f159...ide-33447.html
I have my slides already, 20" and 500lb max rated.
Old 05-13-2011, 02:01 PM   #220
Mike Leary's Avatar
Images: 11
I'm not sure if you want to suck or blow (geez, that sounds dirty). Brad's idea is a good one, although I'm not sure it's needed. I mean, how often does the gen set need to slide out? (p.s. , post some pics if you ever accidently leave that slide open when you leave the campground) ((I've done it on one of my others)).
Old 05-13-2011, 09:12 PM   #221
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
Originally Posted by Keyair
I think I did it!
Wow!! Looks great.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 05-13-2011, 11:04 PM   #222
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Hey Keyair in looking closely at your pictures, it looks like there is a shroud missing from your generator. It looks like there are two little flanges to the right of the head that might be mounts for an air deflector to direct cooling air over the head. It might help the unit run a little cooler. Just thinking out loud.
Cheers, Dan
Old 05-14-2011, 05:22 AM   #223
Cheers, Dan
You are correct, but I took them off when looking for the oil leak.
Old 05-14-2011, 05:24 AM   #224
Originally Posted by Myrtle lynn View Post
Wow!! Looks great.
Yep, I have spotted a mistake or problem tho...
My accelerator pump is stuck down, and not coming up to contact the arm...
I am thinking I put the spring in wrong!
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
