05-13-2011, 08:12 PM
#221
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens
, Georgia
Originally Posted by Keyair
I think I did it!
Wow!! Looks great.
Athens GA
05-13-2011, 10:04 PM
#222
1982 28' Airstream 280
Port Angeles
Hey Keyair in looking closely at your pictures, it looks like there is a shroud missing from your generator. It looks like there are two little flanges to the right of the head that might be mounts for an air deflector to direct cooling air over the head. It might help the unit run a little cooler. Just thinking out loud.
Cheers, Dan
05-14-2011, 04:22 AM
#223
Foothill Ranch
Cheers, Dan
You are correct, but I took them off when looking for the oil leak.
05-14-2011, 04:24 AM
#224
Foothill Ranch
Originally Posted by Myrtle lynn
Wow!! Looks great.
Yep, I have spotted a mistake or problem tho...
My accelerator pump is stuck down, and not coming up to contact the arm...
I am thinking I put the spring in wrong!
05-14-2011, 04:59 AM
#225
Foothill Ranch
05-14-2011, 06:37 AM
#226
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
Maybe damage to insulation was from a leaking exhaust in past ?
Those scoops would be ok when moving, but close of lots of air when stopped.
They look cool though.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
05-14-2011, 12:10 PM
#227
Foothill Ranch
I have no idea if there was a leak, but I have had the downpipe fall/blow off twice, I think due to the oil leak.
Gonna get over there today or tomorrow and take some better shots of the scoops and figure out what they are made of.
Anyone have an thought on how I can make make the power supply power the fans only when the genset is running?
05-14-2011, 12:27 PM
#228
Foothill Ranch
Not really Airstream stuff, but connected and I am kinda excited..
Building some overhead storage racks for my Garage from 1" x 1" steel tubing, and getting aquainted with my Welder...
As I posted before, I have a Snap-On MM140SL Welder.
It is built as a MIG, but has a DC TIG(Not Aluminum), and a MIG Spool Gun for Aluminum.
This is my progress using MIG...
05-14-2011, 01:32 PM
#229
2000 31' Land Yacht
Central
When I needed to power water pump, only on genset operation on the boat, I wired an outlet from the output and it worked great as the 30 sec. delay didn't have a chance to overheat.
05-14-2011, 08:44 PM
#230
Foothill Ranch
Thanks Dave... I will have to look at that soon.
I was over today and investigated the genset door scoops...
They are Aluminum, riveted onto the lower door, and look factory to me...
Here are some better Pics..
This is how the lower looks inside...
05-14-2011, 08:57 PM
#231
1984 31' Airstream310
Ajo
Those look pretty factory to me, also. I wonder if the PO had them installed so they could run the t.v. and both roof airs zooming down the road? (actually, no clue, except the rivets look after-market).
05-15-2011, 07:53 PM
#232
Foothill Ranch
Yup, no way to know unless someone else pops up with the same scoops!
05-17-2011, 03:48 PM
#233
Liberator
1972 Argosy 24
Heart of Dixie
, Alabama
Those pop rivets with the hole in center don't look factory.
And you can see a factory solid rivet nearby holding the screen in place.
Well done by someone though.
Click To See Me Wet
1972 Argosy 24'...
05-17-2011, 04:27 PM
#234
Ajo
Agreed, but someone had problems beforehand, and did the typical PO fix: did not get to the heart of the problem. I've since fixed some exterior leaks where the PO caulked the leaks on the INSIDE!
05-18-2011, 10:30 AM
#235
Foothill Ranch
LOL, it never ends!
Ok, so now I am kinda worried about this Intake...
The Edelbrock info said it will fit under a stock hood of a Suburban or C/K series, but now, looking at the OEM intake on my Airstream, it looks flatter.
I took a couple of measurements and its tough to get an accurate read on the Airstream...
I am worried it adds height that will impact my doghouse..
05-18-2011, 11:37 AM
#236
1977 28' Argosy 28
Bullhead City
I thought it was looking a little tall but figured you knew what you were doing.I guess you could always modify the dog house .
Jo
Gypsy Jo 1977 Argosy 28' Motor Home
05-18-2011, 12:13 PM
#237
Foothill Ranch
Oh, don't EVER even think I know what I am doing!!!!
I have put a Edelbrock TBI intake on before, and it was exactly like a stock replacement, but you felt a power difference, and it added 1 or 2 mpg too.
Based on that experience, I assumed that it would be ok, based on what I read here, quoted from the Edelbrock site..
Mine is a #3761
Chevrolet 396-502 V8
PERFORMER 2-0 (idle-5500 rpm)
Designed for street 396-502 c.i.d. big-block Chevy V8s using general duty oval-port cylinder heads. #2161 is stock replacement/street legal part for 396, 402, 427 and 454 V8s with OEM 4-bbl. carb.; 1965-72 (1973 non-CA) passenger cars and 1966-83 trucks, Suburbans and heavy vehicles; except stock equipped EGR. #3761 is stock replacement/street legal part for 454 V8s with OEM 4-bbl. carb.; 1972-89. Will not fit under hood of Corvette without hood modifications. Will not fit "tall block" V8s. May be used with OEM or aftermarket carbs. Will fit 1965-90 oval port heads.
When I put the banks Filter on, it hit me how tall it looked.
I went to the Airstream and took some measurements, but as the carb and filter unit that was on there is not stock, and the Banks filter will not fit on the aftermarket carb, I cant tell if I have a prob!
05-29-2011, 12:01 PM
#238
Foothill Ranch
05-29-2011, 08:36 PM
#239
2005 25' International CCD
Leesburg
, Georgia
One thing missing though!
05-29-2011, 11:32 PM
#240
Foothill Ranch
OMG....
We are ROFL!
Nice Job!
