Old 12-21-2015, 03:21 PM   #1639
Thanks Brad!
I won't knowing I have to install it again!
It depends on who's perspective you're viewing it from...
Old 12-22-2015, 07:16 AM   #1640
Gunter
gunner's Avatar
Greenville , Ohio
For those with the air compressor gauge located at the dash, is there an air line from the compressor to the gauge or is there a another method to transmit the air pressure to the gauge?
Gunter
1984 Motorhome 345
gunner is offline   Reply With Quote
Old 12-22-2015, 07:19 AM   #1641
Gunter,
The 86 345 that I dismantled had a pressure transducer back by the compressor that sent an electrical signal to the gauge.
So to answer your question it's an electrical signal not air pressure directly to the gauge.
Old 12-22-2015, 10:14 AM   #1642
Good job Guys, as that was a question I had.
I have a pressure gauge with twin needles I planned to install with one monitoring the tank pressure and the other the airbag pressure.
I guess I will have to run some air line from the rear when I get around to doing that, which will probably be when i get under to replace the bags.
I have a nice little compressor that I plan to install with a small tank up front, and have a similar gauge and some kind of controller allowing me to see and control the front airbag pressure.
Something like this:
http://www.summitracing.com/parts/air-26161/overview/
Apparently, you have to be careful to NOT link the bags side to side, as this can cause roll instability.
One day...
Yesterday was a good day with a slew of items off my list.
Headlamps are in and connected, but i have a wiring issue with the headlamps... when low beams are on, the hi beams glow slightly, so I assume a ground issue.
The wiring was a mess going in, with brass crimps exposed, so I might just cut it all out and install a HID conversion. That will bypass the headlamp switch, and supply full power via relays in one hit.
I did "test fit" these Bi-color LED light strips between the headlamp, and grill... They are white and amber, so I plan to run with the white on, when ignition is on, and amber linked to blinkers.
One of my PS/Hydroboost pressure hoses arrived. The Autozone system says there are 2 flexible pressure hoses but my MH, only has one... between the PS pump and Hydroboost. The Hydroboost to PS gearbox is hard piped. On the one that arrived, the shape of the metal ends is different to the MH... I hope the 2nd one is correct!
The 2nd pipe and the PS pump should arrive today, so this morning I will be cleaning up the brackets and stuff in preparation!
Also... the electrical gremlins continue...
This "Water in Fuel" lamp on my dash, is a diesel only thing... yet it is lit... and flashes with my blinkers... LOL. I think I will take the bulb out!
Oh, anyone know where to get a replacement black dash rocker switch???
More later!
Old 12-22-2015, 08:23 PM   #1643
Poured with rain all day today, which is great for California... Not so good for fixing Airstreams...
But, when life gives you rain... look for leaks!
Pass side bedroom wardrobe... Tick.
Pass side bedroom cupboard by the compressor... Tick.
Drivers side rear corner...Tick.
Kitchen Maxfan... Tick... Oh wait, maybe cos I left it open a couple of inches.
Closed it, dried up the wet, and will look again tomorrow.
Good news is nothing around the rear tank vents, or cockpit side windows, or windshield upper. all were resealed. Yay!
Back to Autozone, to get the PS pump, Hydroboost hose, Pulley remover, and new drive belts.
Looks good.
Duralast #31-225.
Comparing old to reman unit.
Here is the only difference...
The mounting stud on my old unit is a different place to the one on the reman unit. A simple swap.
The PS pressure hose that arrived today looks good too!
Old 12-22-2015, 09:05 PM   #1644
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Looks like that pulley slipped right off
1983 310 Classic Motorhome
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-22-2015, 09:59 PM   #1645
1982 28' Airstream 280
Redwood City , California
Steve, when I replaced my pump a few years back, I bypassed the "Autozones" and got the parts at the independent parts house that I have used for most of the MH running gear parts. Every replacement part was an exact match. There is only the one high pressure hose and the rest is low pressure hydraulic hose. For better or worse, I also installed a filter in the low pressure return line to the pump.
I know that you know this will be the case, but when I replaced the pump and started the engine, it took a bit of time to work the air out of the system. It took so long in fact that I thought the replacement pump was bad, then all of a sudden I had steering!
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 12-23-2015, 01:54 PM   #1646
FYI, here's what the air pressure transducer looks like. Unfortunately it has NO part numbers or identifying information on it.
Old 12-23-2015, 10:29 PM   #1647
Nice..... lack of info Brad...
I guess I will be running 1/4 airline for 30'!
Today update...
PS pump was all ready to go on.
Over to the MH, I went, picking up 4' of 3/8 PS return hose on the way.
I have enough to plumb the PS filter in later!
Removed the original PS Pump to Hydroboost hose, and it was good.
Installed the new pump, hoses.
5 word sentence for 3 hours of hard graft!
Installed new belts... the only one that was good was:
Crank-PS-WP...
Crank-PS-WP-AC, was too long...
Crank-WP-Alt-AP was too short... but more than that, the Air Pump pulley did not line up with the other 2. No idea why... back to the drawing board on getting that right! Maybe the pulley or brackets... or eveything! Ugh.
Anyway, put the original belts back on, and buttoned it all up.
Had the front on stands, so filled the PS reservoir, and turned the steering back and forth, and pushed the brakes, and after a while the whining and grumbling stopped, and I have brakes and steering!
It was dark when I finished... No leaks(so far), and I was able to drive the MH back and forth under its own power!
Tomorrow, I will wrap a few items up and go for a testdrive!
Old 12-24-2015, 05:58 AM   #1648
Gunter
gunner's Avatar
Greenville , Ohio
Attachment 254484
Where is the transducer located; between the tank and airbags or compressor and tank?
Gunter
1984 Motorhome 345
Old 12-24-2015, 06:58 AM   #1649
Steve, here's a right up I did for the v-belts on my old 84 310. I went through several different iterations of belts before I finally settled on the right combination.
Hopefully this might help you a little:
Rear means to rear of coach
Front means towards radiator
WP = water pump
PS = power steering
Get the first two belts in place and lined up with appropriate grooves before any tensioning. Then tension the PS pump first, then the A/C pump and then install the alternator belt and tension it.
Order of installation:
Gates 7410 (41-5/8" long)
1st belt - PS to Crank
Rear groove of PS pump pulley to rear groove of crank pulley.
Tension PS using 1/2" ratchet connected to top bracket of power steering pump.
There is one tension bolt on the top of the PS bracket that uses a 3/4" wrench.
There are two pivot bolts on the bottom side of the PS pump. The wrench size is 15mm. They will need to be loosened before removing the belts and tightened after the belt has been tensioned.
Gates 7585 (59-1/8" long)
2nd belt - A/C to PS to Crank to WP
Rear groove of A/C pump to rear groove of WP pulley to middle groove of crank pulley.
Tension after step 1 (PS pump) has been tensioned, Tension using A/C pump adjuster.
Note that the A/C pump has two grooves. The front groove (closest to radiator) is not used.
Gates 7495 (50-1/8" long)
3rd belt - Alt to WP to Smog pump to Crank
Front groove of WP pulley to front groove of Crank to single groove of Smog pump to single groove of Alternator pulley.
There is one bolt that uses 1/2" wrench at the top of the alternator bracket that will need to be loosened and one pivot bolt on the bottom side of the alternator that is a 9/16" wrench size that will need to be loosened. The lower alternator bolt is accessible from inside right front wheel well. Be careful not to loosen bolts on smog pump which is right below alternator.
Tension by using a pry bar on the Alternator. Tighten the top bolt first and then the lower pivot bolt.
Beware of lower part of smog pump bracket. Before tensioning, the belt can get blow this bracket and then when you tension the belt it will be caught. The belt will then squeal badly. Not safe to drive with the belt caught light that.
Old 12-24-2015, 06:59 AM   #1650
It was located close to the compressor under the bed. The is a 345 with an east west bed and the compressor was located in the right rear are.
Old 12-24-2015, 11:01 AM   #1651
Thanks for the info Brad.
I will compare what I have to what you used. Who the hell knows what mods have been done!
I was puzzled by the 2 grooves on the AC compressor, and I think I had it in the front groove, so just as well it was too long!
I was saying to Peter, that my Smog/Air pump is a puzzler. I took that pump from a '85 454 powered suburban at the Junkyard that must have been a Federal smog unit because all the CA smog 454's were electrically triggered by then. I took everything. The pulley is offset forward by maybe 1/2" compared to the crank and alternator pulley. I had not been able to fit the pulley before because the belt was in the way. The pulley is offset to the pump side, but reversing it would make it worse. Will try to find another pulley.
Old 12-24-2015, 11:18 AM   #1652
Steve,
I wasn't able to correctly sort out the belt order on the 310 after all the belts broke while on a trip until several years later when I was fitting the belts to my Argosy motor. It was at that point I realized why things weren't lining up correctly on the 310. I made the changes and all was good on the 310 after that.
Keep in mind I have a couple of smog pumps with pulleys.
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 10:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-18-2011 11:06 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 10:13 PM
