Old 12-20-2015, 10:03 AM   #1625
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Wow... That good info Gunner!
But I have that little red light next to the hole... I will have to see if that's a replacement.
I must be loosing my mind I thought we had a rear tank pressure gauge on the dash!
The red light to the right of the ignition switch on mine is a indicator for when one of the hydraulic jacks is not fully nested when they are in the up position. I have had that light come on when driving and I hit a hole in the road that jarred the motorhome enough that one of the jacks came down slightly. I stopped and shoved it back up. Springs maybe getting weak. I do not have a air gauge in mine. For those that have the air gauge is there an electric version with a sender at the compressor or is there a air line from the compressor to the gauge?
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 12-20-2015, 10:04 AM   #1626
I put 4 x 5 gallon cans of fresh gas in plus some Stabil in, so should be 20 gallons in there.
My new $22 sender unit is working but I noted that it is only reading about 1/8. Now it might be that my battery is low 11.9v after cranking for a while... Or it needs more ignition on time to stabilize... Or the rear airbags are not fully inflated, leaving a tail down stance... Or just simply my sender setup was off.
I am OK with the gauge under reading by an 1/8 if that's the case!
I had not primed the rear pump, and I know they are not good at pulling air, or initial priming. I disconnected the line at the rear of the pump and sucked... Did not have my Mityvac with me! After pulling nothing and noting the vacuum holding... Have to assume the feed line is pinched. It was dark and raining so time to call it a wrap.
Today will drop the tank a little with the mityvac connected and if I see a sudden fuel pull I will know!
Yeah it sure sounds like a pinched line
Hopefully you can resolve it by just dropping the tank enough to fiddle with the lines.
Good luck!!!
Old 12-20-2015, 10:40 AM   #1627
1989 34.5' Airstream 345
Hanalei, /Chino Valley , Hawaii / Arizona
It's really tight to get between the tank and the frame rail to get at the supply hose on the tank. At least on the 345.
I'm thinking that tapeing the hoses in place on the top of the tank while reinstalling is a good idea. As this pinched hose is starting to seem like a common problem. It happened to me too.
I mentioned earlier about putting a hinge on the straps on the side opposite the clamps. This really let's you get the straps out of the way while dropping and installing the tank.
I was pressed into doing this by a helper who has more experience with R V s
And felt it was a bit excessive at the time. But was very glad We had done so. When I had to drop the tank for the third time to get the sender sorted.
Once to start the repair, once to get the hose freed up, and then again to replace the sender. Each time with the hinge there, it was easy to pull the pin and get the straps out of the way.
Cheers Richard
tevake is offline   Reply With Quote
Old 12-20-2015, 11:47 AM   #1628
Awesome info... I have learned so much about my MH this week!
Old 12-20-2015, 12:00 PM   #1629
Cheers Richard
Good info.
I too, had issues with the connection between the electric pump and pipes, so I bypassed that whole section.
My no fuel issue is between the tank and pump...
Off to find out now!
Old 12-20-2015, 09:20 PM   #1630
Exactly as I thought.
Attached my Mityvac to the suppy line, and pulled a vacuum.
This is the one I have...
http://www.mityvac.com/hq_images/07201.jpg
As soon as I dropped the tank, I saw fuel pull into the Mityvac tank, so I knew I was correct.
Dropped the tank, readjusted the lines and buttoned it up.
Few words for a 2 hour job!
After that was done, I tried to start the engine... but the Holley FPR threads leaked...
I guess they are NPT lines when they should be NPTF... seriously?
I will need to wrap each thread with PTFE tape now... Ugh.
Bypassed the FPR, and started the engine... needs so tuning, but its running!
On Peters suggestion, I tested the batteries with the motor running..
Chassis battery was a healthy 13.9v and charging.
House battery was a flat 12,2, and not.
Built a 10 gauge wire with alligator clips and bridged the drivers firewall solenoid, and so had both charging.
New 7 blade fan is slipping, cold at fast idle and noticeably quieter than the Flexfan, and as the engine warmed, it began to pull some serious air!
Much better, I feel.
With the engine running I went outside to check everything...
Then I see the Power Steering fluid dropping.
Stopped the engine, checked the tightness of everything. No joy, and regular drip every 2 sec when not running.
I knew I had a leak before, but this is not acceptable.
Seemed the be coming off the bottom of the pump...(Note my JASPER rebuilt engine sticker tho!).
No room for messing about, as this pump works PS and BRAKES!
20 min later, the pump was off, and I was seriously greasy!
This is the suspect area.
On my way home, I stopped at Autozone.
Ordered:
Re manufactured pump with Reservoir, $48.
New pressure line to Hydroboost... $20.
New pressure line to Power Steering... $20.
Return line, they have in stock.
Tuesday they say.
Done.
Old 12-21-2015, 02:48 AM   #1631
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
don't forget the free pulley puller loaner tool at Autozone, unless you own one.
Don't be a fool, like I was and try to save time by using a gear puller. You will regret it, guaranteed!!!
1990 29' Excella Trailer
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 12-21-2015, 04:46 AM   #1632
Good progress Steve!
Just to be sure, in your post you mentioned pump "with" reservoir. On our rigs the reservoir is remote mounted and indeed your picture shows a pump without reservoir.
You might want to double check what you ordered.
Old 12-21-2015, 07:17 AM   #1633
Yes Peter, I checked, and they have the puller and will borrow it.
Brad, my pump has the remote reservoir up front.. With these pumps they sell them with and without the tinwork that surrounds the actual pump body. That tinwork is what they refer to as the reservoir. The pump without the tinwork was $40, with a $9 core, and they could have got that tomorrow, but the one I ordered was complete and $48, but a $60 core.
I think I could have fixed mine as it was working fine, just leaking at tinwork where the rear mounting bolt is... I bet just an O ring. My issue is time, safety and peace of mind.
I think I will pull out the one I took off my suburban, which was good, and carry as a spare.
The engine started and ran with the new carb, but sounds/feels a little unstable. I suspect a vacuum leak somewhere as I could not get the idle to drop below 1200.
Old 12-21-2015, 08:51 AM   #1634
I guess I'm still confused by what you've ordered!
As long as it looks like the one in your picture all should be good
Old 12-21-2015, 10:09 AM   #1635
Brad,
yes, its confusing without pics!
Let me clarify.
The Saginaw Power Steering Pump(as it is known), is very common.
The pump itself is pretty much the same across many applications, but the assembly itself, and by "Assembly", I mean the pump AND its tinwork onboard reservoir.
There are 2 basic reservior shapes.
1/ Round, like ours, with a large hose nipple feed for the external additional reservoir.
2/ More pyramid shaped. This one has a screw top lid, and no external reservoir.
3/ They also vary by the number of return pipes. most have 1, but ours have 2... I assume because of the PS return andf the Hydroboost return.
To explain it best, look at this rebuild video... Particulaly from 3:15 where thy put the O rings on the "Pump" and then put then about 4:20 they put "reservoir" on. This is where mine was leaking.
Old 12-21-2015, 10:24 AM   #1636
Oh, a follow up on the tank refurb and level sender saga.
I put more rubber blocks between the top of the tank and the frame... there was 2 thick (3/8) spacers at 6 points, but I was having problems getting the tank strap bolts in, so I took 1 off each place.... This time I was able to get 2 back in, so allowing more space for pipes...
As I knew I was starting from an empty tank, I guess I can see how much fuel I am adding and how that corresponds to what the gauge reads.
I put 20 gallons in to a 80 gallon tank....
That would mean the gauge should be reading 1/4, but the gauge reads about 1/8th.
Now, I have the front of the MH on jack stands with the front wheels just raised off the ground. Maybe that is tipping the rear back enough to effect the reading...
More telling was to double check my pipe feeds, I also pulled a vacuum on the genset feed, and all I got was air. So, the genset pipe must still be above the fuel level... which if the gauge reading is close to the "read" tank level, makes sense, as it is uncovered at 1/4 of a tank the manual says.
Old 12-21-2015, 12:37 PM   #1637
I wasn't aware that the sheet metal surrounding the pump was a reservoir I thought it was just a shield of some sort. I had thought the only reservoir was the remote unit. Interesting approach.
Makes sense though.
Yep the hydroboost returns there as well as least it does on my Argosy.
I can sleep better tonight knowing you're ordered the correct pump
Old 12-21-2015, 03:13 PM   #1638
Thanks Brad!
I won't, knowing I have to install it again!
However, that big hole I have where there should be a fan shroud is a help!
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 10:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-18-2011 11:06 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 10:13 PM
