04-16-2019, 01:59 PM
#2301
Churubusco
, Indiana
Originally Posted by bobmiller1
... plus I like the idea of the heat pumps, a back up so in case the furnace craps out I’ll have heat providing it’s not minus 20 outside. Regards, Bob
Heat pump or heat strip?
In my experience the strips work down to about 40, they're just tiny space heaters
04-17-2019, 08:00 PM
#2302
Foothill Ranch
I think it’s the Heat Pump units that are limited to what temp they work at.
So, I picked up the Penguin AC.
Looks ok. Shroud is cracked in a couple of places, and the lower frame is tweaked a little. I can fix both, but really don’t need to as it’s not visible from the ground. I’m ok with saving $600 if it works ok!
Just comparing the shroud sizes here. I think it’s probably a few inches lower, and maybe an inch or so in length
The ceiling assembly is $75 ish so will order that and test.
As I was out there picking up this AC, I stopped by and spent time at the Airstream.
Put the original roof shroud back on the front AC.
Much better.
This is rear one for comparison!
So, I thought I would test the front AC.
Fired up my noisy 3500w portable to see.
Ambient was 78f, blue sky day. Roof temp was reading 88f ish.
Front AC was working fine.
Thought the rear was dead.... but it fired right up!
And....
Dang it!
04-18-2019, 06:58 PM
#2303
Foothill Ranch
Was making some space in my garage for work, last week, so kicked a few items to storage, and in the reorganization of that, I found a box of TBI parts I’ve been looking for.
I’m not sure if I’m going TBI yet, but want to have it all to hand and ready if this carb or smog gear is not working out.
TBI, intake manifold, air filter assembly, AIR tubes, egr etc. more to come.
04-19-2019, 01:12 AM
#2304
Foothill Ranch
Stripped.
I knew if was a 454 unit, but confirming visually it’s the 2” bore.
04-19-2019, 05:56 AM
#2305
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Simplicity at its best ! Regards, Bob
04-19-2019, 09:49 PM
#2306
Foothill Ranch
04-19-2019, 09:53 PM
#2307
Foothill Ranch
04-20-2019, 12:22 PM
#2308
Foothill Ranch
High heat black on the coolant heater unit, and Eastwood Gold/Cad Carb Renew onbthe TBI body.
04-20-2019, 05:34 PM
#2309
2007 22' International CCD
Corona
Looks nice and shiny new.
04-21-2019, 11:19 AM
#2310
Foothill Ranch
Indeed!
Happy Easter/Passover everyone!
Have the TBI rebuild kit to hand now.
As I know and owned the Suburban this TBI came off, I know it ran pretty well. Looking at sending the injectors out to be cleaned, tested and balanced as it did have 165,000 miles on it.
Intake manifold will be going in the parts washer today hopefully.
Also found the lower air filter assembly and the crossover hard pipe for the air injection that went around the back of the heads to feed air into the exhaust manifolds.
And then the Penguin AC ceiling assembly arrived!
04-21-2019, 11:42 PM
#2311
Foothill Ranch
Intake refurb is.... interesting.
Scrubbing it and flipping it, I heard junk inside the heat shield on the underside of the intake.
Busted out the rivets.
Lotsa junk.
Glad I stripped it out.
Into the parts washer after.
04-23-2019, 10:01 PM
#2312
1991 35' Airstream 350
Columbia
, Tennessee
Attachment 338832Attachment 338833
Lotsa junk.
Attachment 338834
Yep, that's the way they are. As long it's not disturbed, it stays put. I tap the pin holes in the manifold and red locktite Allen head Cap screws to keep the shield in place. You could also wire tie them.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
05-01-2019, 06:30 AM
#2313
Foothill Ranch
Busy busy.
Degreased and media blasted the intake.
Got some Aluminum L extrusion for the solar panel frame and mounts.
And so I can roll the mount into the roof radius, doing the Swag Off-road upgrade on my tube roller.
05-01-2019, 10:52 AM
#2314
Foothill Ranch
That’s that little project done.
Next!
05-03-2019, 09:46 AM
#2315
Foothill Ranch
Heat shield drilled and tapped. [emoji3]
Need to find some red locktite as mine had gone hard.
05-03-2019, 11:20 AM
#2316
Richmond
, Kentucky
Sometimes that's a good problem to have.....
1975 24' Argosy Motor Home
05-19-2019, 08:01 AM
#2317
Foothill Ranch
Lol.
Started on the Solar panel frame.
Pretty happy with the upgrades I did to my English Wheel. That the level of stiffness imparted is such that it can curve this thickness.
Now.
I have to do a run out to the Motorhome to double check the curve, as I think it might need a touch more curve, but this is how it will look.
06-12-2019, 08:33 AM
#2318
Foothill Ranch
Test done.
Looks close, but in fact it needs another 2”.
12-11-2020, 11:26 AM
#2319
Foothill Ranch
Wow.
Has it really been that long since I updated my thread?
Ok, so life has been a little tough.
The loss of Tony(IzusuSweet), hit me really hard, even tho I had never met the guy.
It still hurts to think we lost such a great guy from our community.
Wasn't feeling right, and went to get checked up.
Erratic heart beat... diagnosed with Afib(My Dad has it too)...
Blood thinners, adjustments to Blood pressure meds, etc.
One of the BP meds, that was added was one called Metroplo.
My BP stats improved, but I completely ran out of energy... I mean by midday I was sitting in my chair falling asleep, or taking to bed and sleeping for several hours in the afternoon.
Worse than that was the complete apathy that came with it.
I have not been in the garage or to the Airstream or looked at any of my other projects for 6 months at least.
I explained what was going on, and that my in my research into Metroplo I found it noted that the #3 most common side effect of it was DEPRESSION.
Everything dropped into place in my mind.
So, after months of this I went back to the cardiologist, and had a discussion.
He agreed it was not right and swapped that one out.
Things have been improving and my energy levels are coming back but its been a slow road to recovery.
Anyway, I have some small updates to post, and hope to continue on soon.
12-11-2020, 12:11 PM
#2320
Foothill Ranch
So, I had been out the the Motorhome and done some work last year, and earlier this year, but hadn’t posted.
I started to focus on getting the water tanks and systems fixed, and reinstalled.
This involved replacing a rotted section rear subfloor under the bed where the tanks will go.
I cut the rot out, and made a replacement section, and fitted and bonded it in place. Then cleaned and sealed the whole area.
After scraping off the excess glue it looked good.
A trial fit of my twin tank setup followed.
To recap, my OEM 80 gallon tank was long gone. PO had put a 15g in. Not acceptable!
I was given a 70g tank... and then I was given a 25g.
My plan is the run both tanks in tandem, with the 25g as the main fill, and feed tank, for traveling, to save weight, and the 70g on a gate valve for when needed.
This is how they fit together, with the 25 to the rear.
