Old 12-17-2015, 06:28 PM   #1583
Originally Posted by gunner View Post
My 1984 345 has a Isolator located where the solenoid is located in Keyair's picture.
Does yours look like mine Gunner?
Old 12-17-2015, 06:47 PM   #1584
Originally Posted by PeterH-Airstreamer View Post
Steve, here is my solenoid to combine the batteries for starting. Its located behind the battery box and looks like yours, except the location of the posts.
I have something similar looking from the back, but its the cutoff switch for the House batteries...
You can see it in this shot, similar looking but a lever switch inside the drawer... the big red one is the Chassis battery cutoff.
And on the subject of HWH Levelers, my pump and reservious is located in front of the radiator...
And front leveler mounts, if you have not seen the mess I inherited, here was mine.... I cut them off as they were dangerous AND UGLY!
For those who might know the difference, here is my MH cruising, and you can hear the Flexfan noise...
Click on this pic to watch video.
No MH work today...my Individual insurance clients been calling all day!
But I did get my 80' of silicon hose... sadly, I mistakenly ordered 3/4 instead of 5/8...
Old 12-18-2015, 07:17 AM   #1585
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
After seeing Steve's back of the battery tray, I want to take shot at his odd front solenoid:
His rig appears to have the "battery combining relay" right above his shutoff switch on the back of the battery tray.
Soo, why would there be another one in the front?
My wild guess is the Levelers. This may have been their first version of trying to incorporate a leveling system or it was installed after the fact. To avoid draining the Motor battery, they installed this relay to combine all batteries for the HWH operation.
If that would turn out to be true, Steve could route that trouble, burned wire directly to the BAT+ at the battery drawer and eliminate that terrible routing.
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-18-2015, 08:32 AM   #1586
Ah... I wondered what that was....
My Leveling system works on the motor battery alone tho... I had the house batteries out when I was lifting the rear for the gas tank refurb... But maybe it only saw the chassis battery and that was fine..
My motorhome is weird all around, even from the factory. Having just finished reading your 310 jacket thread, I think you would appreciate some of its odd features... The factory curbside dinette instead of barrel chairs!
Now the Obamacare deadline is behind us, I will be back at the MH today, and will sketch out the wiring layout as best I can.
Old 12-18-2015, 08:50 AM   #1587
Airstream Driver
1997 30' Excella
Images: 51
Love the curbside dinette. Adds storage and great day use. Barrel chairs and wimpy table are waste of precious space to me.
Please check if you have a switch in your glove compartment, if you do it energizes the back solenoid. Do your levelers work with the ignition off?
1996 Airstream B190
AIR #13
Old 12-18-2015, 10:15 AM   #1588
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Not sure what you mean. I have the solenoid that combines the coach and engine batteries attached to the back of the battery box, also have the battery disconnect switch fastened to the back of the battery box. There is a solenoid that is fastened to the bracket that is located above the top of the engine near the front to which the cruise control vacuum module is also fastened. I have not followed those wires to see what it controls.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 12-18-2015, 10:57 AM   #1589
Peter,
My levelers only work with the ignition on. I do/did have a red plastic toggle switch in my glovebox, but it is broken and floppy... It does not appear to be connected to anything... But the electrical part behind may have fallen off, and into oblivion behind the dash! I wondered what that was. So what should it do?
I also have a momentary switch next to my ignition that I think boosts my starter battery by connecting the house too.
Will get pics later today.
Gunner, I have a solenoid on the engine bracket next to the cruise control unit. I am trying to understand the rest of this puzzle too!
Old 12-18-2015, 11:04 AM   #1590
Gunter
gunner's Avatar
Greenville , Ohio
Peter,
I believe bkahler advised that the solenoid is for the starter circuit.
Gunter
Old 12-18-2015, 12:01 PM   #1591
Airstream Driver
1997 30' Excella
Images: 51
Peter,
Steve, since you need to concentrate on other issues besides this wiring puzzle, i would do this:
1. Dont use the levelers
2. Leave the burned cable out for now, so you can finish your heatshield/header
3. make sure your engine battery has a full charge for starting
4. Avoid using any of the start assist switches
In the worse case scenario, you would have to connect that cable that was burned to Bat + directly, because that is where it currently is via the starter terminal (please confirm that it was connected to the Bat + terminal on the starter)
1996 Airstream B190
AIR #13
Old 12-18-2015, 09:29 PM   #1592
Peter, you ROCK.
That phone conversation clarified my mind, and got me on track!
Peter gave me a list of things to check and verify, and I went at it.
Starting from the source... the battery tray.
Here is how my setup looks.
Now, starting from the left(fwd), that is the "Combining solenoid", and the two thick red wires come from the Motor(LH) AND House Battery(RH).
Note the Black cable(#1) connected to the LH terminal. More of that in a bit...
Next item to the right is the House battery disconnect switch.
Note the smaller red wire connecting the RH of the combiner solenoid to the disconnect switch..
Is that too small gauge?
Note the HUGE(5/16 or 3/4 dia) Red cable on the RH side... that is the one I pulled and rerouted and takes House battery power to the relay/solenoid in the driver firewall.
The Black cable(#1) from the LH side of the combining solenoid goes fwd to...
This junction box... on the chassis rail.
From this box, is the black power cable(#2 that is removed) that goes to the starter. This is the main starter cable.
Now I started at the front firewall solenoid.
Red cable on the RH side is from House battery.
Now, on the LH side of that solenoid...
Thick Black cable with ribbed grey cover pointing UP went to starter lug(the cable that was melted).
Black cable with ribbed grey cover pointing DOWN is MAIN ALTERNATOR feed/power/charge cable.
Black cable behind this one pointing down, is main power feed for HWH Leveler pump.
Note, the Alternator power cable is pretty beefy..
In this pic I am comparing a 10 Gauge cable to the alternator feed/power cable!
My guess is it is about 2 gauge!
Old 12-18-2015, 09:35 PM   #1593
The end result, was I moved the melted cable from the starter lug, to the junction box connector, it reached just fine.
This meant i did not have to put 2 thick cables on the starter, and so that is back in and good.
The starter shield is good, and I added some serious heat shield material for added protection.
View from under...
Will tidy up tomorrow and hopefully start her up!
Old 12-18-2015, 11:59 PM   #1594
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Why all the hassle?
When I look at my dash indicator lights and see one that warns me that the washer fluid is low, I wonder if there are simply way too many frills designed into these coaches. The "battery combining" feature with all it's switches and relays is an awful lot of fuss to do the job of the set of jumper cables that we're
all carrying around anyway.
streamquest is offline   Reply With Quote
Old 12-19-2015, 12:10 AM   #1595
So darn true!
Just like life.....
Old 12-19-2015, 05:16 AM   #1596
Airstream Driver
1997 30' Excella
Images: 51
you know the answer to that trivia question. After spending 100k plus for the shiny Motorhome instead of the the Lakeside cottage, the wife wanted, there is not another 19.99 for jumper cables. Besides the dirty hands factor and advanced technical knowledge requirements ( hmmm was it red to black or black to red???)
1996 Airstream B190
AIR #13
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
