Old 12-17-2015, 06:14 AM   #1569
Originally Posted by streamquest View Post
Steve,
Re: the big red wire….
Is that part of the system that's connecting your "house" battery bank to the engine battery for emergency starting power?
That's what it looks like to me as well.
Old 12-17-2015, 06:20 AM   #1570
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
While I was working on that, I spotted another issue...
I have a HUGE red cable(maybe 00 gauge) running from my battery drawer to the solenoid on the drivers bulkhead..
The one on the right in this pic...
Anyway, nice cable but badly routed...
It comes along the OUTSIDE pass side chassis rail... rolls up and over the rail, and then goes inside, zip tied to the FUEL lines, past the headers(insulation is already heat bubbled). Goes under the engine mount, and fuel pump, and then across the front X member(hanging down below the bumper) and then to the the solenoid.
Not good. AT ALL!
I pulled the darn thing out, and will reroute it... If I can't do a better, safer job, take me outback and shoot me, someone please..
Steve, will do ...
Before you reroute it, you may want to rethink that entire situation.
Those starter relays (combining house and engine batteries either by switch or ignition) are typically located right outside of the battery tray, specifically on the back of the tray or right on the frame. For the obvious reason.
Why yours were routed in an unsafe way all the way to the front does not make sense, since you already should have the isolator there to use as a power tap. Have you found where your alt wire is connected to. I can see another 6ga wire on the left by the fuses that should be another coach battery wire.
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-17-2015, 06:21 AM   #1571
Originally Posted by PeterH-Airstreamer View Post
identical to mine, except someone cut the access hole for the fan in the shroud. Well, that's just too cool, because all I need to do is drill out my fancy alu patch to gain access.
I don't think that cutout in the shroud should be there. Seems as it would be counter productive for cooling efficiency.
Peter, if you look at the picture of the shroud I posted in our thread you'll notice there is no cutout like that.
Steve, is your's a one piece or two piece shroud?
I know the one on my Argosy was one piece and I've been contemplating cutting it in have to make it two piece. I haven't made that decision as yet because once I do it, it's irreversible
Old 12-17-2015, 06:23 AM   #1572
Steve, will do ...
Those starter relays (combining house and engine batteries either by switch or ignition) or typically located right outside of the battery tray, specifically on the back of the tray or right on the frame. For the obvious reason.
What is even stranger is he doesn't seem to have a battery isolator for charging the coach and chassis batteries at least not in the normal location.
Steve's coach sure does have some weird electrical anomalies
Old 12-17-2015, 08:35 AM   #1573
Good info guys...
I just woke up, and read all this, but need to confirm a few facts when I go back over.
I know the following, attached to the starter main lug there are 3 cables.
1/ Big HD(0 gauge I think) power cable from a square junction box behind the battery tray. This goes over the chassis rail to the main lug on the starter. That one is good.
2/ Second heavy cable attached to the main lug on starter with cable #1 above. This is the one that had melted. This one goes rearward from starter, then up and runs around the rear of the doghouse/engine, and along the drivers side and forward to the same solenoid that the large red cable in my pic before. I think it's the heavy cable on the left of it, opposite the red cable.
3/ a smaller gauge cable that goes forward with some others along the oil pan rail, and is taped into that bundle that goes up the front of the engine coming out behind the water pump...
I will try to trace the Alt cable.
My issue yesterday was these cables are stiff, and I just could not get them into position ... The heat shield now blocks the main lug from view AND nut access, and cable #3 is too short to bolt on before putting the starter into place.
I suspect I will be cutting the starter shield back or rerouting more wires!
Keyair is online now   Reply With Quote
Old 12-17-2015, 09:38 AM   #1574
Airstream Driver
1997 30' Excella
Images: 51
Good info guys...
Steve take a picture for us of the square box behind the tray.
Also it would be interesting to know where the second heavy cable on your starter solenoids left side goes to. I would bet it goes to the Motor battery, which would make it a redundant loop.
If it was me (and i am electr challenged but a fast learner), I would move the starter solenoid to the back of the battery tray and eliminate all those heavy cables running to the front including #2 and use the second heavy on the left for future heavy duty alt applications (if it indeed runs to the motor battery)
1996 Airstream B190
AIR #13
Old 12-17-2015, 10:25 AM   #1575
Will do.
My worry is my clock is ticking... I must have the mh up and running to move between Xmas and New year. My focus must be getting the cables rerouted safely for a 40 mile run. I can get into bigger stuff later.
It just shocked me to see that huge red cable inside the chassis rail strapped to the fuel lines and within 1" of the header tubes... The insulation is OK, but I see micro blisters on it. All of those cables were badly routed and pulled tight onto the sharp edges chassis rails. Not good.
On the fan shroud, I confirm it is in 2 pieces split into upper and lower about the fan centerline. I see the advantage of making a closing panel to shut the gap I photographed.
Old 12-17-2015, 11:07 AM   #1576
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Key, if you can get the starter in without doing any electrical modifications I think that I would get it running "as is" until you get it to the new destination. Your rig has obviously been modified from original electrically speaking. It may take a few days or more to get it sorted out and put back together the way you want it permanently. That heavy gage wire is expensive and so are some of the other componants like a new isolator. (Depending on what size and if you plan on installing an isolator). So rather than getting started on the electrical under a pretty tight deadline I would wait till its parked at a location where it can be disabled for as long as it takes to get things put together the way you ultimately want. There is a good deal of head scratching in sorting out the electrical on these Classics, and youre not starting from oem so you first need to know what the PO did. That in itself could be pretty time consuming. Just my 2 cents.
mayco is offline   Reply With Quote
Old 12-17-2015, 11:33 AM   #1577
Agreed!
I guess I am puzzled, so I need to post this pic again...
From this view, on the right, the large red cable is the one I pulled out yesterday.
I believe that red cable comes from the House batteries...
Now, see the two heavy cables(one going up, and one down), on the left side of the relay/solenoid thingy... One goes all the way along the drivers side of the doghouse, around the back of the engine to the lug on the starter(the wire that was melted), and the other(I think!) feeds the HWH leveler pump.
You guys have a different type of thingy/isolator there...
Mine looks original to me... and you guys have a isolator that looks aftermarket...
Now, what does the solenoid/isolator on the bracket on top of the engine do???
Top RH side of this pic fwd of the cruise control...
Old 12-17-2015, 12:56 PM   #1578
Agreed!
It might be helpful if you could provide a sketch of the heavy gauge wiring and where it all goes to such as solenoids, batteries, etc.
As far as I know your's is the only classic I've seen with a solenoid in place of one of the blue Isolator boxes.
Wires to your starter solenoid should route through that solenoid. This was added as a fix for starter solenoids that weren't working after getting hot. It's outlined in one of the GM bulletins. At some point it became standard installation on all P30s.
My Argosy didn't come with one but courtesy of the 345 it does now
Old 12-17-2015, 12:59 PM   #1579
What Mike said.....
Old 12-17-2015, 01:03 PM   #1580
Airstream Driver
1997 30' Excella
Images: 51
Now it makes sense, yours is a 84 345, a new model with levelers, thats where the second heavy wire goes. So this was their first version of dealing with it.
The relay in the front connects all batteries for starting, either via ignition or a switch in your glove compartment.
The relay on the top of your engine is the starter relay and it also serves as a junction block for the alternator charging wire AFTER it s supposed to go to the Isolator.
I also agree with Mike under your circumstances.
1996 Airstream B190
AIR #13
Old 12-17-2015, 02:27 PM   #1581
Airstream Driver
1997 30' Excella
Images: 51
Steve, here is my solenoid to combine the batteries for starting. Its located behind the battery box and looks like yours, except the location of the posts.
1996 Airstream B190
AIR #13
Old 12-17-2015, 02:56 PM   #1582
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
My 1984 345 has a Isolator located where the solenoid is located in Keyair's picture.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
