Old 12-15-2015, 02:06 PM   #1541
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
No, didn't disconnect or remove the radiator or hoses. Flex fan came out, and new one went in from below. Worked from doghouse above to position and get a couple of bolts in, then finished tightening from below.
Yes, if I go TBI the feed is from the rear with ss flex lines as standard.
You must have a different fan shroud, because i can not even get a wrench in there from below
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-15-2015, 02:08 PM   #1542
Yes, mine is different to that... it also has some "aftermarket" tinwork, but the center section is open... will get a pic tomorrow.
Old 12-15-2015, 02:43 PM   #1543
A couple of things to look for. There is a curved metal guard between the frame rails right below the radiator. I see the guard in Peter's picture but I can't tell from Steve's pictures whether he has the guard there or not.
Also on the Classics with the horizontal radiator the plastic shroud is in two pieces. If the curved metal guard is not in place then the lower half of the plastic shroud should be able to removed for easier access to the fan.
The curved guard is riveted to the chassis frame rails from the factory but a lot of them have had the rivets ground off and replaced with bolts for easier access to the cooling fan, etc.
The 345 I dismantled had had a new engine installed at some point and the rivets were replaced with bolts. On my Argosy I have already removed the rivets and when I'm done installing the engine and radiator I'll use bolts to install the guard.
Steve, do you have the curved metal guard below the radiator?
Old 12-15-2015, 04:20 PM   #1544
Good info Brad.
I have a gap between the front x member and the radiator. From memory the fan shroud has a wing either side, that terminates with a piece of metal riveted to the plastic. I assume there should be a closing panel there then...
Old 12-15-2015, 04:23 PM   #1545
Peter, that aluminum section on your radiator shroud is definitely a PO add on. Is the shroud underneath the aluminum busted up?
Old 12-15-2015, 04:24 PM   #1546
Good info Brad.
Take pictures when you get a chance. I'm wondering if the metal guard under the radiator is missing in action. If it is I have the one of the 345...
Old 12-15-2015, 06:20 PM   #1547
Airstream Driver
1997 30' Excella
Images: 51
I am the CO who did that, not the prettiest but it sure does the job. Yes the shroud was busted.
That curved metal guard is not under the radiator on the 310, its right under the harmonic balancer and it seems to guard the brakes lines. It is riveted to the frame. And my shroud is a 1 piece. So, major pain to get to anything in the area.
ID:	253913   Click image for larger version
1996 Airstream B190
AIR #13
Old 12-15-2015, 07:07 PM   #1548
If it works thats all that matters.
I guess I need to look in the barn to see if I still have the shroud from the 345...
Old 12-15-2015, 07:11 PM   #1549
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Let me know how the 7 blade works, I am in the process of taking the seven blade off my 1979 GMC Jimmy and putting it on the 325....cannot find a seven blade anywhere. PS....still looking for the Alcoa's !
bobmiller1 is offline   Reply With Quote
Old 12-15-2015, 07:46 PM   #1550
Here is what I know Bob...
California spec '87 R2500/3/4T Suburban with 454/TH400, rear AC and tow package was fitted with the 7 blade. All others had 5 blades.
7 blades are rare... you can't find them new... I have 2!
Scoured the Junk Yards for them.
Living in the southwest, I don't think I can go wrong... max cooling if the Viscous Coupling can keep up.
Anyone wants a Flexfan and fittings off my 345, it's yours for the shipping!
Nothing from the Alcoa seller BTW Bob... letting that one go.
Old 12-15-2015, 08:00 PM   #1551
Now I am upset with you Peter...
I see your engine has the lower timing marks... mine does not.
Lets see how dedicated the smog inspector is when he has to check my timing!
On that note, no AS time today as it was Obamacare deadline day(I do health Insurance), but this was in my mailbox..
Correct 4 way check valve between carb and distributor!
Oh, and I have 80' of silicon 3/4" heater hose on the way too!
Old 12-16-2015, 05:01 AM   #1552
3am and I am awake thinking about my to do list!
An issue with the smog pump came up yesterday. I had taken the diverter valve off it to aid with the mounting of the actual pump body, so I thought I should test it before I mount. It's has failed internally. After a search it seems they are NLA... I hope I can find a working one somewhere.
Old 12-16-2015, 05:15 AM   #1553
Airstream Driver
1997 30' Excella
Images: 51
tried Rockauto, they list three? RockAuto Parts Catalog
Product Detail
1996 Airstream B190
AIR #13
Old 12-16-2015, 05:59 AM   #1554
Steve, I still have the smog pump and some misc smog hardware from the 345. If you're unsuccessful finding what you need give me some info and I'll see what I have laying around.
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 10:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-18-2011 11:06 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 10:13 PM
