Old 01-14-2011, 07:30 AM   #141
slaughters , Kentucky
Hello again about the tag axle brakes,
Yes, the feeling that you might need a little more braking power has caused me to have some bad dreams. Now we know how the 18 wheelers feel with the big rigs. But, essentially the 345 is a big bus and we need to allow time and space between us and the people in front. And, on secondary roads I drive fairly slow as well.
The tags help but they are only an assistance. They need to be adjusted so that they do not lock because when they slide they are not braking very much, but they certainly should be able to lock.
The tag axle magnets are color coded for power; the NAPA guys should know about the codes. Wimpy magnets are useless.
Drive carefully,
Joe
joe gooch is offline   Reply With Quote
Old 01-14-2011, 10:22 AM   #142
Thanks Cooperhawk, the dogs are sweet, the M/h... not so much... yet!
Choctawmel, wow, thats a mess under there... I have heard many tales of the rats nest of wires... now I see!
Joe, thanks for the info. Can you ever have too much brakes? I will do a brake check after I have the smog stuff all up to spec, and this sounds like a good upgrade.
Old 01-14-2011, 12:00 PM   #143
1989 34.5' Airstream 345
Silverton , Colorado
After having to spend a lot of $ on the tag axle brakes, I did what the po did...cut the lines and just added more time to my travel...a bit of a concern over the mountain passes, but once you get past the pucker factor that at 3300 rpms, the tranny shifts into 2nd gear without your permission, you learn to adjust...we have replaced them twice in 5 years, and the last time they failed was when one of the retaining springs broke...about a year old, so past the warranty...drive slower, live longer...m
AND, you get to be one of those folks that used to be in front of you when you were an in-hurry teen!
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 01-15-2011, 08:47 AM   #144
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
I have the 'Roadmaster' toad brake also. It's a pain to get in, but better that pain then the pain and destruction of running over someone. Don't think I'd operate the 'Silver Bullet' if I was aware all the brakes weren't working. Heaven forbid I was to have an accident and injure/kill someone. The legal consequences would be savior.
choctawmel is offline   Reply With Quote
Old 01-15-2011, 09:59 AM   #145
As I plan to upgrade the hitch, and pull a Toad and probably my 5000lb Jeep Grand Cherokee, i need all the brakes working good and a Toad brake!
The recent rain we had here in California gave me a chance to search for water leaks...
1/ A wet patch in the curbside bedroom closet is most likely from the damaged skin, but I need to reseal the roof vents as the sealant is cracked on everything up there! Anyone got advice?
2/ The carpet on the pass side front window was damp, but the channel and window seals need doing, so I plan to get those.
3/ Water on the dash, so will need to reseal the windshield upper.
4/ No sign of leak, but unsightly, the rear window seal is weathered and pulled out... I have heard horror stories about trying to seperate the frame to replace the seal, as its impossible to get the frame back together after correctly.
How should I fix this?
Old 01-15-2011, 05:40 PM   #146
There is a site for window seal repair, and Andy can help you, there...there is also a site for hitch upgrade...great pics, and the guy in Austin, TX did a 10K re-adjustment of our tow capacity...we now have a 4600 Nissan Maxima behind us, and while the mountain passes are intimidating, the flat tow places...well...they're flat tow...the downloaded pics will save you a bundle, and they will help your mechanic in understanding what he wants to do...worth it, in my view, as I had my tag axles clipped last year...the continual failure was just too expensive...m
Michael & Tracy
1989 345 Motorhome
Old 01-15-2011, 05:56 PM   #147
I did look in the windows section for info on resealing, but was not sure if the M/H and Trailer windows are the same.
I have a bunch of pictures saved of what people have done to upgrade the hitch to 10k, so I have a good idea on the plan. I have a welder, but planning to let a Pro Welder buddy of mine do that job to be sure!
For the sake of interest, here is how my underside looks at the moment...
Bent wheels and all!
Note, that my skids are completely different to anything else I have ever seen!
Old 01-15-2011, 06:11 PM   #148
Interesting pics...I have 'skid' brackets...somewhat worn over the years but still able to handle the steeper inclines...so far...I would prefer rollers, and have seen them attached, but just haven't gotten 'round to it, yet...another reason to park on the street till the Sheriff tells ya to move...
Michael & Tracy
1989 345 Motorhome
Old 01-15-2011, 06:15 PM   #149
My plan was pretty similar to what others have done.
I planned to drop the tow hitch and clean it up, and then add a, extension from the hitch tube about 3 feet, and then tie that to a new crossmember. Two diagonal bars would tie this to the new extended rails bolted to the M/H chassis legs. These will extend forward to the gas tank and I would like to add a rail under the tank to protect the rear edge.
I have been looking for replacement wheels that could handle the job better and these are the best I have found so far..
Cast iron centered, with solid rubber tire, and rated for 2,500lb.
Florida Casters and Wheels, Inc.*::*Wheels*::*Rubber Tread Wheels Product Line*::*MH Heavy Duty Mold-On Rubber: up to 2500 lbs.*::*Heavy Duty Mold-On Rubber on Iron Core Wheels
Old 01-16-2011, 12:45 AM   #150
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
If you really want some effective drag wheels you might consider some heavy casters. I don't know about you but when going in or out of driveways where I scrape I'm usually turning. As much overhang as these coaches have that is a lot of scuffing on a rigid mounted wheel. Might almost be as good to mount a flat plate with the leading and trailing edges curved up. I don't think it would make much difference to the coach. As long as the plate was 4" or 5" square it probably wouldn't make much difference to the pavement either.
Cheers, Dan
Old 01-16-2011, 03:24 PM   #151
Very good info and a better idea.
If I decide to go the caster route, what rating should I look for?
It would need to be high.. 5000lb each?
Old 01-16-2011, 04:37 PM   #152
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
Originally Posted by Keyair
Mine is an 84. I will post a pic of mine later today...
Found it! Wow! Thanks. I now know what it does. I thought it was for my CB lol.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 01-17-2011, 02:12 AM   #153
If you went to 5000lb casters you could lift the whole rear of the coach, of coarse then you would be stuck because the drive wheels would be in the air. I've got two big casters on mine from the PO that I'm going to remove when I get a chance. I have a rear bath so the tanks are there and the casters are right at the bumper and really look strange. When I drag the stern it sounds and feels like skid plates anyway. I need to beef up my hitch but I have to work around the tanks. When I get to it I'll mount a skid plate on the hitch, it's to lowest point. It sits so low I've even thought about recessing it into the bumper. If I can raise the hitch a couple of inches I could eliminate 90% of the tail dragging. Just thinking.
Cheers, Dan
Old 01-18-2011, 05:02 PM   #154
Yes, you are correct, I am sure that a 5000lb caster is heavy duty, but I am concerned about the "Shock load" involved when the rear of the coach hits the ground... most likely with just one of them. I felt that 5000lb might not be enough!
I am spread a little thin and have lots on on top of the Airstream the last month...
My latest worry is batteries...
I have 2 Interstate Megatron Marine Deepcycles as the Coach Batteries.
From the paperwork I got with the rig, looks like they are 3 years old.
Stupidly I left something on last month and deep discharged them down to dead.
I have no 120V at my storage, so pulled them off and recharged them at home using my new BatteryMINDER charger/desulfator.
One of them came back ok, and I just checked it after a week of resting here and it is reading 12.6V.
The other is not good, shows 10.5V and a check of the SG in all the cells tells me one is dead, and reads very low SG.
I posted over in the battery section, and the news is not good.
So, with a battery replacement or replacements on the cards, I need advice!
Here is how my compartment looked with batteries installed...
Pulling them out told me I got issues....
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sraab928
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
