Old 12-05-2015, 11:55 PM   #1499
Great info guys!
Ah-HA, Peter, I did not know those little blocks were breakers!
Now I know where to look!
Brad, I saw your post about Teleflex electronic speedometers... freaked me out, cos I bought 2 new ones a couple of years back... I checked mine and they are cable driven!
While we are talking about the Teleflex gauges... is the stock Tachometer spark driven or alternator pole driven???
Old 12-06-2015, 07:56 AM   #1500
Great info guys!
I think on the 83 and 84 models the compressor was originally power from the fuse block under the dash. If yours is now connected to one of those circuit breakers I'm betting that was a PO mod. On my 310 those circuit breakers were for the electric seats.
I also bought a speedometer a couple years ago that was cable driven. It wasn't until the last year or so that I saw one on ebay that was electronic. I prefer the electronic as it eliminates the cable and just makes easier to work with.
Good question. I have a new one in the box with the original instructions. When I get home next week I report back what I find.
Old 12-06-2015, 09:52 AM   #1501
Reading Mel's diesel swap I think he mentioned the alternator and tach drive wire....
Old 12-06-2015, 03:24 PM   #1502
I've never dealt with a tach driven from an alternator. Guess I'll do some research to see what the differences might be.
Old 12-06-2015, 09:04 PM   #1503
I know Brad... Who knew!
Ok, I was working double hard on sunday...
Went to the storage around midday.
Finished up the fuel tank filler neck clamps, and got everything tightened up.
Put 10 gallons of gas in... did not even register on the gauge!
I figured out the suspension compressor issue.... somewhat...
So, here is my snakes nest on the front bulkhead....
No fancy blue thingy like you Peter!
So I test the "Breakers", and none of them have power....
When I supplied power to the #2 down, I hear the compressor start... I knew I was on teh right track at last!
I spent an hour fiddling around and no joy...
So, I moved on to priming the fuel lines, and the engine would not start... Turn the key... click!
It was cranking just fine before....
My 2x 6v house batteries are at home, so I took my spare Dodge van battery and attached it as my House battery to boost the chassis battery, thinking that it was low.
As soon as I connected it, and turned on the ignition... I hear the Compressor start up!
Someone has obviously changed the feed for the compressor to the house battery!
What I did find was that the rocker switch that I thought controlled it... does not! And also it runs for a few mins and then I hear a "Ping", and it shuts off, which I assume is the breaker...
So now I have an engine that wont crank!
Checked the chassis battery... 12.5v and a new battery.
Remove and clean all the battery connections, nothing. I check all the connections on the battery tray... looks fine.
Then I check the starter connections...
First I find the main power connector if not tight... I turn the power off to tighten it...
But I quickly find another issue, that maybe related or not... either way its not good and needs fixing.
I drop the starter out to investigate further.
Here is one of the power cables running to the main lug on the starter!
Melted insulation, probably from heat radiating from the Banks headers.
I chased this wire, up and over the transmission, into the drivers side harness, and on to the solenoid shown in my #1 picture on this post.
I think there is enough slack to cut off the damaged section and crimp on a new connector.
I pulled teh starter and will bench test it tomorrow, as well as order a starter heat shield!
Ugh...
Old 12-06-2015, 09:41 PM   #1504
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
That made head spin, I think I will pass out
The blue thingy I have is the Isolator. It keeps the 2 battery system separate, but they share the same charging system from the alternator. What you have in that place appears to be the starting solenoid, either activated by a switch in the glove compartment or by the ignition.
That starter wire looks very scary and appears to be more than just heat damage
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-06-2015, 09:44 PM   #1505
I know.... Never a dull day with an ASMH!
Mr Gasket starter heat shield ordered!
Old 12-06-2015, 11:07 PM   #1506
Oh my...
I am a Dumb @ss... I just realized what I did to cause the non start condition!
Moved the shifter to D!
I was trying to get a straight shot at the header bolts on the LH or drivers side head.
Could not loosen them, because I forgot to bring the correct tools today, so gave up.
Neutral safety switch!
DOH!
Planned to pull off the LH header so I can weld in a O2 bung to tune the carb and later put TBI on...
Ok, grumpy, but happy because I found a possible safety issue with that cable.
Another issue I found was the "Soundproofing" on the doghouse has failed and fallen down.
Pic from hood looking into engine.
I brought the doghouse home tonight and will look at my options.
Also, forgot to post, I had a fuel flood condition, in the carb... I was puzzled... not had that before that I was aware of, so I tested the fuel pressure... 2 to 4 psi with just the Mech pump, and 8psi with the rear electric pump on.
That is my Fuel Pressure tester gauge you can see in the pic, which reminded me!
8psi is too much pressure for most carbs.
4 to 5 psi is fine.
Holley Fuel pressure regulator and gauge on its way.
Engine oil and filter was changed today... I think the oil smelled of gas... maybe the fuel pump was leaking into the oil.
Another issue I had was a PS fluid leak... drips off the bottom of the pump. Think its coming from the pipe between the underhood reservoir and pump. Pulled that off too, but no clue what type of pipe to use!
More fun tomorrow!
Old 12-07-2015, 06:24 AM   #1507
Airstream Driver
1997 30' Excella
Images: 51
I used wire mesh before to fasten the doghouse insulation.
1996 Airstream B190
AIR #13
Old 12-07-2015, 06:31 AM   #1508
Good idea Peter.
It's too far gone and looks like hell anyway. It's outta there!
I am thinking MLV as a base layer and then some fireproof material I happen to have...
Old 12-07-2015, 06:04 PM   #1509
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
That was an arc from hell waiting to happen....a little gas from an old fuel line, some residual oil to maintain the flame and flambé au de Airstream. Wouldn't be the first, unfortunately probably won't be the last.
Good catch Steve, but I wonder how long it took your heart to start beating again.
Cheers
Tony
Old 12-07-2015, 07:12 PM   #1510
I know Tony!
I pull the doghouse out, and today I stripped it of all fiberglass insulation off... and the darn thing is ABS!!!!!
Good job that is fire resistant! NOT!
Ugh.
And now I am all itchy!
Old 12-07-2015, 08:42 PM   #1511
Here is the heat shield I ordered.
http://www.summitracing.com/parts/mrg-3678/overview/
I also plan to put a heat wrap on the starter to double protect it.
So, today I was "In the Doghouse".....
Here is the wreck.
A few hours of work and I have this....
I got it DA sanded and prepped now.
Am planning to put a 1/2" layer MLV on the inside...
Then a layer of some fire rated material, I just happen to have a roll of to hand...
Its called ZetexPlus, and is fire rated to 2000F..
I built a exhaust heat shield for my Alfa with it last year, and it works fantastic.
Old 12-08-2015, 12:49 AM   #1512
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Teleflex
Great info guys!
On the Teleflex subject….
Does anyone have a line on an OEM Air Suspension gauge? Any thoughts on a source for repair?
Charly
streamquest is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
