Old 07-18-2015, 05:32 PM   #1401
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Steve,
Think of how proud you'd be to take a hundred pounds out of an Alpha.
streamquest is offline   Reply With Quote
Old 07-19-2015, 11:29 AM   #1402
I had an Alfa that I took 200lbs out of... It disappeared!
I am seriously impressed by FormicaFX... And in particular the petrified wood version... Beautiful indeed and with a lightweight and strong substrate... It would be good!
Old 07-21-2015, 06:12 PM   #1403
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Welcome back Key!!
I would check the weight of the current counter. That sucker is heavy! I was worried when the DW wanted to replace the bathroom counter with granite. Figured why not it is just a small piece. They weighed the same! That original corriane (?) is heavy!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 07-22-2015, 06:40 AM   #1404
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Originally Posted by wxbuoy View Post
Welcome back Key!!
Missed the seeing the progress, Key, glad you are back!
AS must of had a scale handy for all components or you wouldn't be able to move it. They did miss the target with ceramic tile on mine, if it wasn't so much work I would remove it and use cork.
Old 11-11-2015, 10:32 PM   #1405
Time for a quick update....
Just thought I would post this to let everyone know I am alive... just distracted from my AS for a bit longer!
Life just keeps handing me lemons...
Alfa, that I thought would be done and sold, is dragging its heels with a bunch of gremlins... now its decided to start leaking oil from the oil pan and/or rear main... both are a PITA to do... and also the pinion seal on the rear axle is leaking.
All of the above were on the cards to be done in the last 2 months... but... I need my ramp... and...
The Stepson's Subaru decided it was not getting enough attention.
It started with a split radiator earlier in the spring, and after replacing that, it ran for a couple of months... then overheated again in a dramatic fashion. Of course, the stepson ignored my explicit instructions to check oil and water weekly...
A detailed examination pointed to a blown Headgasket, but oil pressure was good, as was compression, so out came the motor.
Headgasket was obvious... but I was concerned to find coolant in the oil.
We decide to risk a limited rebuild, with new headgaskets, and timing belt set.
Motor was replaced and ran fine.... until suddenly developed a rod knock.
We knew it was a risk, and this time we lost.
Out came the motor again... and the oil I drained told me it would be grim..
The autopsy showed spun rod bearings on #2 and #3...
This is #3, where the bearing is welded to the rod!
Anyway, I am now up to my neck in Micrometers and Bore gauges!
I hope you regular Airstream Programming will resume soon!
Old 11-12-2015, 12:02 AM   #1406
1936 20' Clipper
1947 22' Liner
Curtis Wright
Key,
Glad to hear that everything is going according to plan.
But especially glad that you're still in the fight!
Keep hitting them. Pretty soon it will be nothing but Airstreams and open roads.
Charly
Old 11-12-2015, 12:20 AM   #1407
Originally Posted by streamquest View Post
Key,
Charly
Who's darn plan Charly? LOL.
Ya know, the good part of what is going on is that I am gaining tools and experience for the Airstream as i bump over these cobbles!
The engine will be going out to the machine shop next week, and they are telling me 2 weeks lead time... The subaru is on the ramp and sans motor is not going anywhere... which means I can't work on the Alfa either!
I have done some stuff to the Airstream between projects, but i have 3 items on my list for this downtime I intend to get done.
Old 11-12-2015, 06:43 AM   #1408
Trying to divest oneself of projects is always tough. I'm getting closer to that point myself but I'm still not there yet.
The trick is once you've eliminated one project, don't go get another one to make up for it!
Glad to hear you're still in action
Old 11-12-2015, 06:57 AM   #1409
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
The head gasket on those Subarus has been a problem for a long time. They say that theyve corrected it. It went on for years though. Great cars, we love our Forester. First thing to ask though if buying used, has the head gasket been replaced.
mayco is offline   Reply With Quote
Old 11-19-2015, 10:24 PM   #1410
The Subaru project is ongoing, with the engine machining underway!
But back to the real deal...
I got a call from my Storage place, and it seems that I(and others) will be moving by December 31st!
Good riddance to these people... 4 rate hikes, theft of fuel and other items, and general crummy service.
They will be getting a black eye online after I leave.
So, I packed up my pickup with tools, fresh battery, and supplies, and began the process of awakening my sleeping beauty!
Pulled the plugs, and gave each cylinder a shot of MMO, to lube the rings.
I had drained the fuel tank(because of theft), so I knew I needed to start from scratch.
Planned to pull and clean the fuel tank, so started with a fresh fuel can and plumbed that into the rear fuel pump feed.
After cranking for a bit I had no fuel feed at the carb... The rear electric pump was working fine, but nothing was travelling along the line.I worked my way along, checking the filters, and all was good to the mechanical pump on the block. Seems that has failed somehow internally and blocked the fuel supply.
A new one is on order, but I might bypass it to see if I can.
I did get the motor running by force feeding it gas down the carb throat...
Just got busy checking stuff and getting my list together!
More real updates coming soon!
Old 11-20-2015, 12:22 AM   #1411
1936 20' Clipper
1947 22' Liner
Curtis Wright
Steve,
One would think it's bad enough having to deal with the self destruct tendencies built into these motorhomes, but having to contend with fuel thieves and cutthroat landlords all at the same time, makes the experience extra rich.
On to greener pastures, blue skies, and airstream adventures on the open road.
Old 11-20-2015, 07:41 AM   #1412
Steve, have you found a different place to store your 345 or are you going to park it at home?
Old 11-20-2015, 09:20 AM   #1413
Where I live, in Orange County, space is at a premium, and so prices are not cheap. This place was reasonably close, and also they didn't mind people working on stuff. Many places here forbid anything...
I have not confirmed a place yet, I have a shortlist and will go inspect places next couple of weeks. It will be further away, but cheaper for sure.
In the meantime, parts are on their way.
The new Carter fuel pump was only $17, and I also bought some 8mm plug wires.
As its been sitting for over a year, its due a full fluid change.
As the transmission pan is the original stamped steel pan with no drain, which I hate. It will be replaced by a n extra deep Derale steel pan. This takes 3.5 quarts more than stock. It has a drain plug, and and a temperature sender plug. It also has pipes running thru the pan base for cooling. I was leaning toward a cast aluminum deep pan as they add more strength to the trans case, but this will do for now.
Old 11-20-2015, 09:39 AM   #1414
Hopefully you'll find something that fits your needs.
Can you post a link for the transmission oil pan? Sounds interesting!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
