Old 11-23-2006, 09:40 PM   #1
1982 28' Airstream 280
grosse pointe park , Michigan
1982 280 Leaks when it Rains
and the water shows up on the floor/carpet just behind the drive/passenger seating area without any trace of how it got there. This happens when stationary. Any Ideas?
thanks. kevin
k_rasmussen is offline   Reply With Quote
Old 11-23-2006, 09:49 PM   #2
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
I fought a small leak on my '72 Overlander for almost two years above the vista view window. My Sovereign had a similar leak in another place.
The obvious place to look is around any vents, antennas, etc., especially on horizontal surfaces (where it tends to pool up). Loose rivets (which are hard to detect) can be a real pain to track down.
I recently sealed the roof with 2 coats of Kool Seal white elastomaric (sp?) paint over a coat of primer and I have not seen another leak since. I never did get around to it before I sold the Overlander, but if I had it to do over again, it'd be the first thing I'd do. It was not expensive ($30-$35) and I used a roller with an extension handle after I masked off the edges.
Of course you should also check around your windows (gaskets, etc.).
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is online now   Reply With Quote
Old 11-24-2006, 06:22 AM   #3
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
both sides
evin, with the statement of it being wet on both sides, you have a very good hint the leak position will be from side to side instead of a small spot. I would first look at the larger holes in my roof. The A/C is the first suspect. A new seal can be had for less than $20. The replacement is the hard part. What about a skylight? The antenna is a possibility. The seam a cross the top is a very large possibility. Look for anything that would be from one side to the other that would allow water to run to both sides at the same time.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 11-24-2006, 06:26 AM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
thanks. kevin
Check your window seals, In heavy rain, I get a bit of seapage in behing the driver seat...
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-24-2006, 09:12 AM   #5
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Also check any roof intructions, horns, spotlight, antenna....most likely it's your sliding windows.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 11-24-2006, 09:35 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I had the exact same problem and tracked down the cause to the side window seals and clogged weep holes. The water runs down your side panels directly under the sliding windows and under the carpet on the walls, settling behind the seats. If you remove your side panels you will see the trail. Easy to fix, just replace the window seals ans clean out the weep holes which you have to do when repalcing the window seals. There are several good threads here on how to do this.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-24-2006, 09:37 AM   #7
1994 30' Excella
By the way welcome to the forum, it is always great to have another 280 in the group.
Chaplain Kent
Old 11-24-2006, 01:39 PM   #8
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
That's exactly what I found... Bugger ain't it! (all the pines around me)
www.balrgn.com
Old 11-24-2006, 02:50 PM   #9
Norfolk , Virginia
Kevin,
Get the hose out (if the temps are above freezing) and start to spray around the roof and windows. Have someone inside the coach to see if he can watch it drip. If you are by yourself, spread a sheet over the chairs and couch, etc. and see if it gets wet when you spray the roof. If you have it dried out, put paper towls on the floor and see which order they get wet in and where. This will point to a direction. If you are a little out of level and the water runs from one side to the other, you at least know which side the problem is on. Spray the windows and see if water gets in. If there, clean out the weep holes or if the channel is really rusted and worn out (very typical of an 82), follow the thread on how to replace and go for it. This is not something you want to let go as water is the killer of motor homes and houses.
My problem turned out to be one of the rivets on the "S" shaped piece of trim on the outside on drivers side where the strips are located (between the windows and the ground). There is also one on the curb side as well. To find out where water was coming from on my 82, 28', I removed removed couch and drilled a few inspection holes in the inner skin (where it would not show) until I finally found it.
You might get lucky and find it in a few minutes, or it could take hours like it did me. Regardless, good luck with it.
Steve
Geophilist is offline   Reply With Quote
Old 11-24-2006, 04:39 PM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
As a former (and recent) 280 owner, I would concur on the weep hole and window seal. Sounds like from where the water ends up that is likely.
The other thing to check is windshield seals, and the side windows also. Water tends to travel a bit when it gets inside you walls.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-24-2006, 07:04 PM   #11
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
thanks. kevin
I had a similar leak on my 345. Check your windshield seals on the top. I put some sealent around the gasket and it resolved most of my leaks. It could also be your AC gaskets. Since the interior ceiling is aluminum, the leak can travel and show up in wierd places.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Post your favorite picture of your MH PeterH-Airstreamer Airstream Motorhome Forums 42 07-24-2004 09:13 PM
1982 dash alfalsetto Airstream Motorhome Forums 0 10-31-2002 09:32 PM
finding/fixing leaks Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 10-16-2002 08:32 PM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
