Old 11-29-2011, 08:17 PM   #15
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Originally Posted by dlcain View Post
OK.... She's up and running again. I pulled the doghouse and switched out the fuel filter mounted to the engine, primed it a whole bunch and........ She wouldn't stay running. I noticed that when pumping the primer pump it didn't feel like there was any or very little liquid being pushed through - just felt like air. So, I tracked down everything that could be a potential place that could let air into the fuel system and found - the damn plastic tube that goes from the filter housing to a vacuum gauge on the dash had somehow come loose from the back of the gauge.... At least now I know what that gauge is for(if it starts pulling high vacuum - time to replace the filter) and now I know where the other fuel filter is...
Thanks for the help....
On a side note anyone know the belt size for the alternator belts? Might as well replace them while I've got the doghouse off.....
Cheers,
-don
The Isuzu no. is 1136711430. If I remember correctly this is for a matched pair. The Gates number is 1420. I run the Isuzu belts belts because the Gates matched pairs aren't matched very well.
To answer Mike's question in the next post, the vacuum gauge is sold as an accessory by Racor for their filters.
Cheers, Dan
How to get to engine on rear diesel pusher? 442 john Land Yacht/Legacy Motorhomes 1 10-21-2011 10:26 AM
Replace engine in 95 LandYacht Diesel cjshaffer2 Land Yacht/Legacy Motorhomes 4 09-25-2011 07:40 PM
Excella :: 1981 Airstream 280 Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
Diesel Engine Programmers moosetags Tow Vehicles 34 05-23-2011 09:49 AM
AIRSTREAM 1981 Trailer Excella II eBay Watch Airstreams on eBay 0 04-20-2011 02:00 PM
