Old 09-23-2015, 08:43 PM   #1
1999 35' Cutter Diesel Bus w/slide
Sacramento , California
$1700 Front Brake Job On a 1989 345 LE!!
I had this in the wrong thread so moving here.
I picked up a 1989 345 LE with 55k miles in Seattle, WA. I drove it to get tires then dropped it off at RV Super Center in Kent. I knew they might be a bit expensive but they said they could hold it for as long as I needed at no charge. So far my bill is up to $3,300. I don't think this is too bad, as they took care of a lot of items that needed attention after 5 years of sitting, including:
Fixing water system (freeze damage), new front air bags, new alternator, new 55 amp converter, generator overhaul, 2 coach batteries (12v, said 6v would not fit).
I just got a call that the front brakes, brake lines, bearings, etc., all need to be replaced at a cost of $1,700. I'm told this is outrageous. Any thoughts on where to go from here? I certainly can not get it on the road as the brake lines have ruptured, and brakes are bare metal. Any thoughts on shops near Kent, WA?
Ryker is offline   Reply With Quote
Old 09-23-2015, 08:56 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Look for a truck repair center.
CRH is online now   Reply With Quote
Old 09-23-2015, 09:05 PM   #3
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Having tried every truck shop within a 30mile radius of my house and no one will touch our Argosy, then tried all the local auto repair shops and no-one can get the Argosy either inside or on the ramp, I have come to the conclusion that folks willing to work on a motorhome know they can charge what they want, because they are the only choice we have (unless you are able to do it yourself). I would be content just to find someone capable of doing the work, but then I am resigned to the situation, not happy with it.
martin300662 is offline   Reply With Quote
Old 09-23-2015, 09:26 PM   #4
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
I think you need to have a conversation with the Kent people, indicating that your wallet is not bottomless and asking them if they think that with this comprehensive brake job the vehicle will be ready to drive home. If they really are replacing everything, including lines and bearings, and giving themselves some wiggle room in the estimate, I would not call the price outrageous. You need to draw a line for them, and make sure it is a dead line.
1989 345LE
Punch is offline   Reply With Quote
Old 09-23-2015, 10:08 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Sorry to say but you bought a 25 year old Chevy that was only designed to be on the road for 15 max. Luckily for you, parts are cheap and plentiful. Unluckily for you, labour rates have risen sharply in the past few years and these old birds can be a beatch to work on. It took the shop I had a master cylinder replaced at, six times to bleed all the air out of the system.
If you're looking at hoses, wheel bearings, rotors, master cylinder replacement, pads and possibly callipers, $1,700 including taxes wouldn't be out of line.
Get it to a truck repair place (sorry, don't know one in your area), versus a RV service centre for mechanical. I think the heavy truck service place would be cheaper and probably more competent to do the work.
Goodluck
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Isuzusweet is online now   Reply With Quote
Old 09-24-2015, 05:08 AM   #6
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Have them email you a detailed estimate and ask them to include an itemized parts list. At least then you will know exactly what they are quoting you. As Tony said, That price doesnt seem too out of line IF they are replacing all the parts he detailed. Rotors, flex lines, bearings n seals, pads, etc etc etc.. It adds up pretty quick. If it were me, Id feel a good deal more comfortable if I had an itemized parts list. My 2 cents
Mike
mayco is online now   Reply With Quote
Old 09-24-2015, 05:13 AM   #7
mayco's Avatar
(2 more cents). Make sure they flush your entire brake system. If its been sitting that long the fluid needs flushed.
Old 09-24-2015, 06:38 AM   #8
1978 28' Argosy 28
I agree, for a comprehensive job that doesn't seem too far out of line. I just had my rears done to the tune of $1100 at a competent fleet service center here in central TX. Cost included new rear drums to go along with the new shoes and oil seals. ($360 for the drums. A rip-off considering I can buy them myself for half that) Still not cheap, but in the grand scheme of things they wont' have to be done again for a very long time.
bpg_austin is offline   Reply With Quote
Old 09-24-2015, 07:20 AM   #9
Livingston , Texas
That price is in line with what we paid last year for the front brake rebuild on our '08 Ford F-250, FWTW.
pattydoug is offline   Reply With Quote
Old 09-24-2015, 07:53 AM   #10
1989 34.5' Airstream 345
Ebro , Fla Panhandle
That price doesn't seem too out of line for a total replacementof all brake parts on the front.
I had to have the brakes on the drive axel on my 345 redone this summer while on a trip up the west coast. Cost was near $1200. Would have cost less than $500 to do it myself. But I was on the road and didn't have the tools needed for the job with me.
I also replace the front tires in Salt Lake City at over $1,100 for that job. Made me blink too. These old larger vehicles are not cheap to keep up, but are so worth it.
Otherwise it sounds like they are getting a lot done on your coach for reasonable $ s.
Lots of your classic motorhome brethren here are pretty DIY inclined, and lots of info and help is available here. Each job I complete on my coach makes me feel better about the condition of the coach and about my ability to deal with its needs on the road.
Welcome to the joys and challenges of classic airstream ownership. You will be rewarded in spades once you are out there enjoying your coach.
Post some pics of your new ride.
Cheers Richard
PS. Mine is also a 1989 345 LE, it was a great year for coach building :-)
tevake is offline   Reply With Quote
Old 09-24-2015, 08:44 AM   #11
Originally Posted by Isuzusweet View Post
....It took the shop I had a master cylinder replaced at, six times to bleed all the air out of the system.
It took a shop working on my old 310 over a month to get the brakes repaired properly due to what they said were problems with the replacement master cylinders they were getting from the parts houses.
As much as I think the $1700 is an outrageous price it may also be your best option. The other repair prices you mentioned had been done seemed to be reasonable. There are times when I will pay extra if I know the job is being done right. If that's the case here it might be worth it.
Old 09-24-2015, 08:48 AM   #12
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
How do they know it needs new wheel bearings without inspecting them? Bearings can last a long time if properly maintained.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 09-24-2015, 11:28 AM   #13
1977 31' Sovereign
Lynnwood , Washington
Call Elliott Tire. They work on just about everything. Knowledgeable staff. They won't rip you off.
25923 104th Ave SE, Kent, WA 98030
(253) 373-1500
Tom
TomKirk is offline   Reply With Quote
Old 09-25-2015, 08:53 AM   #14
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
As I stated before, for the brake pads, bearings and brake lines for the front only, 1700.- is totally out of line. That is a 3-4 hour job at the most.
If it includes turning or replacing rotors, replacing the master cylinder, I could justify the price if I am in a bind away from home.
Note: I have done the above work several times on P30 and G3500
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Brake Job Spartan EC2000 Kota Mechanics Corner - Engines, Transmission & More... 3 11-11-2014 07:05 AM
Brake Job on P30? 92landyacht Mechanics Corner - Engines, Transmission & More... 8 04-24-2014 04:43 PM
Found something weird doing my first brake job. uniquemicro Brakes & Brake Controllers 4 09-20-2009 12:14 AM
Brake job - now they're broken floridartist Brakes & Brake Controllers 25 08-13-2009 12:00 AM
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 05:28 AM
