Old 08-12-2009, 08:39 PM   #1
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
Window work Argosy MH.
Has any one done any window work on thier motorhome? I am in the process of replacing the fuzzy channel I now see I need to address the seals on the fixed window that sits next to the slider.Does anyone have any knowledge on this venture?I have a 1977 Argosy 28' and am working on the coach windows.Any help would be appreciated. Thanks
Gypsy Jo is offline   Reply With Quote
Old 08-16-2009, 08:14 PM   #2
You might find some useful information in the following threads:
http://www.airforums.com/forums/f160...air-19059.html
http://www.airforums.com/forums/f160...ment-9584.html
I believe there might be a few other threads about windows. Do a search on window seal replacement, etc you might get lucky that way.
1975 24' Argosy Motor Home
Old 08-16-2009, 08:25 PM   #3
Gypsy Jo's Avatar
1977 28' Argosy 28
I did check those sites .None seemed to have what I was looking .Did find out on some post that they used vulcum to seal the fixed window which will work .Thanks for the reply.
Old 06-25-2012, 10:38 AM   #4
1977 28' Argosy 28
dexter , New York
gyspy jo did you ever get that window fixed ? Ilooked all over on here and nothing seems to match mine ,they slide have squeeze locks and I see no plastic track .only the bottom part of fuzzy is bad . some are glued some not , is the all rubber fuzzy better than the metal core ?? mine the metal is all thats gone just cloth in track
jonesy 1 is offline   Reply With Quote
Old 06-25-2012, 12:10 PM   #5
Gypsy Jo's Avatar
1977 28' Argosy 28
jonesy 1
I did get some of the sliders done. I had both the metal fuzzy channel and the rubber fuzzy channel . I used the metal one for the windows and the rubber fuzzy channel for the screens. Be careful of the window locks they are expensive to replace.
They are not that hard to do. Check out the links from bkahler's post I think one of them gives you exact instructions if not Inland rv sends instructions with the order.The second post from bkahler's thread is the one you want .
Jo
Gypsy Jo
1977 Argosy 28' Motor Home
'76 Argosy window channel rv-n Argosy Motorhomes 11 05-29-2009 09:36 PM
Window Leaks(?) in 76 Argosy Toby Briggs Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 08-13-2007 03:04 PM
Need argosy window U trim nodpete General Interior Topics 3 07-03-2007 04:11 PM
Window for my Argosy asilomardad Windows & Screens 2 01-04-2007 05:11 PM
