Old 12-17-2012, 02:02 PM   #15
dznf0g's Avatar
Oswego , Illinois
We're just looking at owner manual page pics....no actual vehicle. What you see above is what we get to guess at.
-Rich-
Old 12-17-2012, 02:35 PM   #16
Originally Posted by dznf0g View Post
I wish I could see it more clearly. Upon further examination, is that a cable housing coming in from the right, running under the aluminum housing, and attached to the lever on the left side. That would indicate some kind of cockpit slide or pull knob?
I just used a magnifying glass and I think you are right, there is a cable heading to the drivers left that appears to connect to the lever.
Wish I could see the upper part. It would really be an elaborate overkill if it were a heater control valve for the rear of the coach?
I have not seen any pictures showing what the heater control valves looked like. I do know it is NOTHING like the heater control valve in my coach.
They never used vacuum or hydraulic wiper motors, did they?
YES! The manual does list the windshield wipers could be either electric or hydraulic. The manual describes the different switches used for each type. However my coach has the electric type of wipers but the controls as described in the manual don't match mine
The two hoses definitely head down towards the power steering pump area. I think you hit it, the pictures shows the control unit for hydraulic wipers.
I'll look at the Chevy parts manuals tonight for windshield wipers.
Thanks!
Old 12-17-2012, 03:06 PM   #17
dznf0g's Avatar
Oswego , Illinois
Bingo! But when the chassis is shipped there are no wipers. Just a bare frame sled with powertrain, steering column and a wooden box with loose parts as a driver seat. Wipers were added by coach builder. Some GM parts and many not. We never had a hydraulic wiper system for the P-chassis.
-Rich-
Old 12-17-2012, 03:10 PM   #18
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
The fuel priming pump on an Isuzu is a small piston pump on the side of the high pressure injector pump. It is about 1 1/4" in dia. with about a 3" stroke.
I have no clue what that thing is but judging from the pictures the hoses look pretty big for fuel hoses and also if it was some hydraulic wiper control I really don't think it would need hoses and flow that big.
It will be interesting to find out what it is.
Cheers, Dan
Smartstream is online now   Reply With Quote
Old 12-17-2012, 03:18 PM   #19
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Just guessing, maybe it is some kind of oil pump booster. I had similar looking doohickey on my boat. It had a Kubota (Universal) diesel 4 cyl. You gave it a few squeezes prior to starting the engine. It prelubed the top end of the engine.
MICHAEL
Old 12-17-2012, 03:55 PM   #20
Images: 59
I like the idea in Post #2. Many Boats and Motorized RVs have economizers (heat exchangers) built into the water heaters. They use engine coolant to keep the water heater hot.
Why would they use such a stange looking spool valve? Lots of different manufacturers and lots of plumbing choices.
Old 12-17-2012, 04:22 PM   #21
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
How about....manual air horn switch?
Old 12-17-2012, 05:15 PM   #22
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
Brad,
I'll go back to my original thought in post #2. Take a look at the attached file.
I think, in the long run, you will have to trace these hoses for the group.
Please let us know what they turn out to be.
Chris
newsgauger is offline   Reply With Quote
Old 12-17-2012, 05:20 PM   #23
Excella CM's Avatar
1978 31' Excella 500
Venice , California
That's a Trico "Hydro Wipe" wiper motor. It was used extensively on Ford products in the '60s.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-17-2012, 05:33 PM   #24
I think you nailed it! Being a Ford product (or should I say used on Fords) actually makes sense because the Argosy uses the dash heater control from a 73 Mustang and the vacuum actuators for the A/C-heater system are Ford vacuum actuators.
Check out: 1969 Lincoln Continental Coupe Hydraulic Windshield Wiper Motor
The contraption in this auction is the same as shown in the owners manual. It's certainly looks a lot different when you can see the whole thing. Kind of like an ice burg, most of it is hidden from sight!
Thanks all for helping me track down the unknown device.
Old 12-17-2012, 05:36 PM   #25
Originally Posted by newsgauger View Post
Brad,
Chris
I wish I could trace the lines! The pictures in question are just images from my Argosy owners manual. I wanted to find out just what it was. Now that I know it is a hydraulic wiper motor I'm glad my Argosy didn't come with that option
Old 12-17-2012, 05:37 PM   #26
When I first read your post the picture you included didn't show up, not sure why but I didn't see it until after I posted the ebay auction listing.
Thanks for the ID!
Old 12-17-2012, 06:18 PM   #27
Rich,
Based on your comments I gather you have or have had some involvement with the P30 chassis. Does this mean the motorhome owners on this forum could consider you our in house expert on the P30 chassis?
Thanks for your help.
Old 12-17-2012, 06:49 PM   #28
dznf0g's Avatar
Oswego , Illinois
Yes, I was involved with the commercial version of the P30...and just a little bit with the MH version. It was15 years ago and I no longer have access to paper manuals, as I am a field rep. The old manuals were not converted and put online, since we sold the business and responsibility for the chassis a long time ago.
Soooo, I'm only an "expert" to the ability of my aging brain's retention of 15 year old info. I recall some stuff, but haven't touched one for about 12 years. If I can contribute I will, but most of you owner DIYers probably have more info than I.
-Rich-
