Old 11-25-2009, 07:24 PM   #1
1978 28' Argosy 28
Atlanta , Georgia
What is this red switch?
I have a 1978 28' Argosy motorhome that has been a pleasure to own! We have had it for just under a year. We have figured out most of its quirks, but a few things remain a mystery. One of the items on the list is a red toggle switch that is to the right of the ignition and to the left of the a/c toggle switch. It lights up when you flip it, but it doesn't seem to do anything. Anyone have any idea what it may do? Also there is a pull that says heater on it that is next to the window on the passenger side. I can heat a damper move when it pushes in or pulls out, but the manual has not info on what it does in either position. Thanks in advance for the help!
Todd
todbot is offline   Reply With Quote
Old 11-25-2009, 07:28 PM   #2
_
hi todd
some1 will come along and provide the correct info,
but till they do...
lots of mystery knobsnlights on these things...
given the season, i'd suggest that when it POPS OUT...
the turkey is done...
http://www.airforums.com/forums/f311...his-21132.html
cheers
2air'
Old 11-25-2009, 07:38 PM   #3
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
You are a lucky man !!!
It appears that your moho has been retrofitted with the highly sought after passenger ejection seat. Use it wisely ! !
my moho has some extra switches also- get the meter going- maybe it works electric fuel pump?
Have fun !!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 11-25-2009, 07:44 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Anti-Evil Switch
I am not familiar with your Moho but it does not look like a factory switch.
Reminds me of a switch I had in my Westfalia. The Westfalia would occassionally stall and you could not get it started unless you waited hours.
I took it to a VW mechanic and lots of money later he told me the problem was the Westfalia "had evil in it", but he installed an "anti evil switch". What this did was shut off the fuel pump. When it stalled you turned the fuel pump off so the injectors would not flood the cylinders trying to restart.
I don't know what your switch is but it is probably not an automatic pilot.
Old 11-25-2009, 07:47 PM   #5
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
Doorgunner beat me to it! Definitely Navigator Ejection System......
Al
.....looks to be added by a PO
..You could always check the backside and trace the wire out, it may only have the front leg (power) attached
Alwhisman is offline   Reply With Quote
Old 11-25-2009, 07:48 PM   #6
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Have fun !!
I'm afraid you are mistaken.
That is a stealth black tank dump device. Be sure to check if anyone is behind you before you activate it.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 11-25-2009, 07:53 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
Gives road rage a whole new meaning
Old 11-25-2009, 07:56 PM   #8
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
adds new meaning to $hitty driving conditions.
www.popasmoke.com
YETI ( 65 Quart )
Old 11-25-2009, 07:58 PM   #9
I'd be a real test for windshield wipers.
Make sure you don't use it when many motorcyclists in matching black leather vests are behind. you.
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 11-25-2009, 08:49 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
There was an option in the 70s called a Thermosan. Pumped the black tank into the engine exhaust.
Old 11-25-2009, 08:54 PM   #11
Just my luck. I'd get stuck behind that one in a traffic jam. Eewwwwww!
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 11-26-2009, 12:32 AM   #12
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
Go ahead and flip the switch. If you hear a loud BOOM, do not do it again. LJH
LJH is offline   Reply With Quote
Old 11-26-2009, 01:48 AM   #13
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
It switches your running gear in to the "Balanced Running gear mode"...
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 11-26-2009, 06:40 AM   #14
richinny's Avatar
2011 34' Classic
if it was added on after the original build the wires should be fairly easy to trace. start there and if you don't find the end, post how far the search took you.
Ricky
Red awnings Hhthorny Awnings 7 04-18-2008 08:26 PM
So what do the red numbers mean? tvadman1963 Member Introductions 2 12-29-2006 07:45 AM
seeing red codybear Off Topic Forum 19 10-13-2006 07:40 PM
red numbers lido&linda 85/345 Airstream Motorhome Forums 1 09-05-2003 11:39 AM
Am I The Only Red Neck? Gwen Our Community 29 08-06-2003 06:48 PM
