Old 01-11-2009, 03:08 PM   #1
Unlockable compartment locks
When we got our 74 Argosy Motorhome it included a huge keyring with probably 20 keys. Unfortunately only one of the keys fits the exterior compartment locks and it only opens one of the locks out of about 8.
Any recommended procedure for removing the old locks? I've never drilled a lock out before but that seems to be the only method I can think of to get access to these compartments.
Thanks!
Old 01-11-2009, 03:20 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Locksmith
A good locksmith can make a key for the lock. Not sure of the cost difference between a locksmith and buying and replacing the locks.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-11-2009, 03:27 PM   #3
I really would prefer not to use any of the old locks as they are corroded and rusty. The locks smith would probably be cheaper but I if I use a lock smith I still have to deal with the ugly lock assemblies.
Old 01-11-2009, 03:38 PM   #4
1967 22' Safari
1960 Caravel
Images: 8
I don't know much about Argosys but, most of the lock assembly's I've seen in compartment doors are just cam or leaver type cabinet locks. Like this. Am I close.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-11-2009, 03:49 PM   #5
Lee, you're right they are all just the lever type of lock as used on Airstream trailers and Motorhomes.
Old 01-11-2009, 03:59 PM   #6
1967 22' Safari
1960 Caravel
Images: 8
Photos
If your lucky the lock will be exposed and you will be able to remove the nut holding onto it. If your not so lucky you will need to drill enough rivets to pull the old lock out and put a new one in. Make sure you measure the lock they come in different lengths. Search around you should be able to find sets that are keyed alike so you don't have a bunch of keys to keep track of.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-11-2009, 04:00 PM   #7
345bill's Avatar
Las Vegas , Nevada
Brad- I was able to open two of mine with a old, old worn out chevy trunk key and alot of wigglin. Once open the locks were easily replaced, on mine the nuts were exposed.
345bill is offline   Reply With Quote
Old 01-11-2009, 06:26 PM   #8
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
If ya take it to the locksmith, he will use a lock pic gun to open all the locks and U then can take them apart with out damaging the skin. Sorry in not closer I'd open them for ya.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 01-11-2009, 07:43 PM   #9
Unfortunately a locksmith is out of the question. The Motorhome is a ways out in the country and is not drivable (yet). Since I plan on replacing the locks anyway it just seems easier to do whatever it takes to remove the locks.
I need to get some of the compartments open now which is why I was wondering about drilling out the locks. None of the locks that I really need to remove are exposed on the back side to where I could access the nuts on the locking ears. In order to remove the gas tank I have to open one of the access covers which hides the fuel tank.
Bill, I've tried using all of the keys that seem to slide into the locks along with lots of WD40 and other fluids with no success. On the keyring there were two keys that were broken off which makes me wonder if those were the keys I really needed . I've also tried all the keys from our 310 Motorhome with no success.
Old 01-11-2009, 07:46 PM   #10
Brad.
Please post a photo of one of the locks.
We may be able to help you from there, since we have some special keys.
Old 01-11-2009, 08:05 PM   #11
Here are two of the locks in question.
Old 01-12-2009, 10:50 AM   #12
1967 22' Safari
1960 Caravel
Images: 8
Work
Hi Brad, I hope Andy can come up with some sort of key. If not, you will need a good drill and several sharp high speed bits. Start small and centered in the lock and you might be able to drill out the screw holding onto the lock bar. You will have to drill through the lock. You may have to increase the bit size as you go. If nothing else you will eventually remove enough of the lock for it to fail. Be careful not to drill anything on the other side. Good luck!
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-12-2009, 11:27 AM   #13
dreadydreame's Avatar
1965 26' Overlander
Newport , North Carolina
we had to drill out one of the locks on our trailer, we just used a large bit, no bigger than the hole and went at it, it took a little while, but eventually got through and it came out easy. just be careful not to hit the skin on the sides. A new lock for ours was only a few dollars.
,Katie & Anthony, 2kids, lots of pets!
dreadydreame is offline   Reply With Quote
Old 01-12-2009, 09:48 PM   #14
VIKING's Avatar
Boulder Creek , California
These locks are not strong at all. I have opened them by running a screw into the keyhole and pulling on the screw with a pair of pliers to bend the locking lever and open the door. It's not hard at all. If you plan on replacing them anyway, you don't need to spend the time drilling them out. This is much faster and easier.
Good luck, Rich
VIKING is offline   Reply With Quote
Storage Compartment Locks - 1968 Jim Clark 1965 - 1969 Globetrotter 14 11-08-2017 08:05 AM
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
1970 compartment locks vhord Exterior Storage Compartments & Access Doors 3 03-18-2008 01:29 PM
Exterior Compartment Locks. Navigator Exterior Storage Compartments & Access Doors 12 03-10-2006 11:05 PM
side compartment locks & keys dogwood Exterior Storage Compartments & Access Doors 4 08-05-2004 05:20 PM
