Old 03-24-2007, 07:54 PM   #1
Sway Bar Bushing Search
I have a 1975 Agosy 20' MH with a P30 Chassis. Looking for replacement of the sway bar bushings. The sway bar diameter is 1 3/4 roughly. O'reilly's and Advance Auto has no access. Anyone have any ideas? Thanks.
911rs is offline   Reply With Quote
Old 03-24-2007, 11:23 PM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Check with these guys:
Welcome to Henderson's Line-Up, Brake and RV, Inc.
There are P30 experts and make the SuperSteer line of suspension products.
Nice guys too.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 03-25-2007, 07:13 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Frame bushing, or control arm?
Napa has them, I have bought them and put them on both bread trucks and MoHos.
Old 03-27-2007, 08:24 AM   #4
Thanks to both of you for the help. I will contact both.
Old 04-10-2007, 01:51 PM   #5
geirws's Avatar
I have a 77 argosy and get most of the engine and chassis parts from my local chev dealer, since it is a chev chassis and power train.They have the serial no. on there computer so I get the correct parts most of the time. One exception so far was the fan clutch. They gave me a light duty one instead of a heavy duty one and that was because the light one was on the engine and I brought it in to them.
geirws is offline   Reply With Quote
Old 04-11-2007, 12:24 PM   #6
Great to know. Thank you
Old 04-12-2007, 06:18 AM   #7
IPM
1996 clipper gas 34'
Blue Springs , Missouri
There's after market polyurethane bushing available and have them on my P30 chasis airstream and really made the sway bars much much tighter, less roll. Unfortuately I can't remember who made them. I found them with a google search originally.
It's all good
IPM is offline   Reply With Quote
Old 04-13-2007, 09:32 AM   #8
IPM, If you come across the name let me know. All sources dried up. No GM dealer help, Energy Systems does not seem to want to return my calls or emails for some reason. I learn from GM these bars where an option called HD (Heavy Duty) for their motorhome chassis. I have a 1 1/2" sway bar on the front and 1 3/4" on the rear. The brackets that hold the sway bar and bushing in place are 1 1/2" wide, bolt centers 3 1/4",3" tall and 2" for bushing to slide in bracket.
Old 04-13-2007, 04:11 PM   #9
guy99's Avatar
Images: 16
Henderson's couldn't help you?
Old 04-14-2007, 06:17 AM   #10
IPM
Here's mine, maybe not 1 1/2":
Performance parts and accessories
How about use the undersized 1 3/8 as is, they split, or drill them out to fit?
GMC Applications
It's all good
Old 04-16-2007, 08:43 AM   #11
Talking to IPD. The back bushings shows part number of IPD 150 404. I also located a company that makes these bushings to order. Thank you
Old 04-18-2007, 10:26 AM   #12
FYI to everyone: It looks like Roadmaster has the sizes I needed. They are the only company I ran across that matches the large bracket size I have. They also have the large diameter sway bar sizes. According to the GM dealership I visited these sway bars where an option and show in my manual called HD (heavy duty)Thank you all for all your help.
Old 05-29-2007, 02:06 PM   #13
IPD Sway Bar Bushings
FYI, Roadmasters purchased IPD a couple of years ago.
Old 07-12-2007, 11:45 AM   #14
1975 26' Argosy 26
London , Ohio
Looking the other day my 75 argosy needs new bushings too , Jegs.com has the Polyurethane ones .If you don't do any good on line I would give them a call I betthey can get them
slow-canoe is offline   Reply With Quote
2003 International AS Pahaska 2002 - 2005 International 149 10-01-2017 06:38 PM
Sway bar help Diana Langley Hitches, Couplers & Balls 13 06-10-2008 05:02 PM
Equalizer hitch and sway control Rod Pease Airstream Trailer Forums 15 04-07-2006 11:00 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Search Questions hex Forum Admin, News and Member Account Info 4 10-15-2002 11:38 PM
