Old 07-28-2017, 12:40 PM   #1
1978 28' Argosy 28
Minoa , New York
Suspension Compressor Cycling
I noticed my rear suspension compressor was running often even when parked. I found and fixed a small leak but notice even when it's parked on a flat surface the compressor cycles on for twenty seconds every three and a half minutes. I can't find any leaks though there must be one somewhere.
If you park your rig on a flat surface and turn the key on or leave the engine running, does your compressor cycle on / off? Is every three minute excessive, will it burn out the compressor?
---78 Argosy 28 footer---
gravitysucks is offline   Reply With Quote
Old 07-28-2017, 01:58 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Sounds like a leak to me. It shouldn't cycle like that. But if its cycling that quick I would think it would be easy to find the leak......hmmmmm..might be the pressure switch too. Its telling the compressor when to cycle according to psi. Have you soap tested all your fittings? I would do that first.
mayco is offline   Reply With Quote
Old 07-28-2017, 02:41 PM   #3
Mollysdad's Avatar
Three minutes sounds excessive to me.
I never counted, but while driving, if I watched my air gauges, they drove me nuts. Sometimes low (80) sometimes high (120)
I finally quit watching, but I know they lose air with dump valves, brakes, dryers, ride height adjusters.
If I had to guess I'd say mine cycled every 10 minutes.
Old 07-28-2017, 03:45 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Leak.
Take a bottle of soapy water and spray down the air bags. Specifically top and bottom which is where the leaks typically occur (where rubber is joined to the assembly). Look for bubbles. Bubbles = replace airbag.
wulfraat is offline   Reply With Quote
Old 07-28-2017, 08:12 PM   #5
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
If you don't find any obvious leaks take a look at your check valve. It should be in the line coming out of the compressor. When they foul or freeze up the air bleeds back through the compressor and is difficult to detect.
Cheers, Dan
~ Margaret Thatcher ~
Old 07-30-2017, 05:02 PM   #6
1978 28' Argosy 28
Minoa , New York
Thanks. I did the soap test and still can't find it. I'll check the check valve.
Independent Suspension on an Airstream - Timbren Axle-Less Suspension BoldAdventure Axles 23 04-02-2017 02:45 PM
Where is rear suspension compressor relay??? 1987_345 Classic Motorhomes 9 02-21-2011 10:42 PM
Rear suspension air compressor Robfike Mechanics Corner - Engines, Transmission & More... 11 09-28-2006 04:20 PM
Water Heater Cycling? BigAl Water Heaters, Filters & Pumps 0 07-06-2004 08:48 PM
