Old 07-11-2010, 01:54 PM   #1
Darel's Avatar
1977 28' Argosy 28
La Porte , Indiana
Send a message via Yahoo to Darel
Slow filling at the pump
What is the reason for slow filling at the gas pump. I have to barely squeeze the handle on the fill nozzle and it shuts off quite frequently as I am filling the tank. Replace the fill hose?
Darel is offline   Reply With Quote
Old 07-11-2010, 03:17 PM   #2
Bfrank's Avatar
1979 24' Airstream Excella 24
Adams , Tennessee
Sounds like it could be a blocked vent hose due to dirt dobber or some other vermin or there is a crimp in the fill hose they tend to be longer on MH make sure the route taken to the fill cap is optimal it may be a replacement that didn't fit or get installed properly ie crimp instead of a
90 degree elbow etc..
bfrank
Frank & Lisa Sullivan
Bfrank is offline   Reply With Quote
Old 07-11-2010, 03:31 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Try turning the nozzle to either side. Don't hold it at the 6 o'clock but rather at 4 or 8 o'clock.
I say this because this will change the position of the backfeed on the nozzle and may work better.
If hat has no effect i would look for a crimp in the truck fill tube or something blocking the truck vent line coming up from the tank.
2004 Excursion 4x4
Old 07-11-2010, 05:49 PM   #4
r carl's Avatar
Lin , Ne
You can also try to only put the nozzle just half way in instead of all the way in.
Old 07-11-2010, 07:46 PM   #5
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
I too agree with Bfrank on the blocked vent hose. Check out the filler neck and see if there is a hose attached to the top of the filler neck. Follow it and see where it goes. Possibly down to a charcoal canister where a vent would reside. Unless its a diesel where there wont be a charcoal canister.
Good luck..
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 07-12-2010, 01:12 AM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, is it always slow or just this last time? I have run into a lot of defective filler nozzles at different gas stations. Try a different pump or different station, if this is the case.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-18-2010, 08:58 PM   #7
Darel's Avatar
1977 28' Argosy 28
La Porte , Indiana
It has always filled slow ever since I bought it. The previous owner even told me it would. The only time I remember it seems to be when I'm at the pump and it takes a looooong time to pump gas. Right now it's on my mind and I'd like to get it fixed.
Old 07-20-2010, 05:59 PM   #8
satia43's Avatar
1971 27' Overlander
1975 26' Argosy 26
Denver , North Carolina
Our 76 fills very slow also but we think it's problems with pumps since our whole fuel filler hose is brand new.
satia43 is offline   Reply With Quote
Old 07-22-2010, 05:17 AM   #9
projector's Avatar
1972 23' Safari
NSB , Florida
Our's had a severe belly in the fill hose. So severe it acted as a P-trap. I replaced everthing between the fill and tank and it took care of the slow fill problem.
Here's the before.
Name:	fuel fill before 3.JPG
Here's the after.
Name:	fuel fill after 4.JPG
You can look at my previous posts for a description of what I did.
Good luck.
projector is offline   Reply With Quote
Old 07-22-2010, 07:54 PM   #10
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Nice work projector!
1965 31ft Airstream Sovereign
1975 26ft Argosy Motorhome
Imagine the sight of them linked together!
gmehal is offline   Reply With Quote
Filling in Rivet Holes Roadrunner General Interior Topics 18 02-04-2010 09:18 PM
got a hole needs filling Frank's Trailer Works Doors & Locks 41 09-26-2008 05:49 PM
Help with Filling Water Tank james814 Fresh Water Systems 1 07-16-2006 09:13 AM
Water Tank filling up thecatsandi 2006 - 2010 Classic (all lengths) 11 05-13-2006 07:14 PM
Fuel Filling Problem Chaplain Kent Mechanics Corner - Engines, Transmission & More... 7 07-15-2005 12:21 PM
