Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 02-08-2010, 07:17 PM   #1
gmehal's Avatar
1965 30' Sovereign
1975 26' Argosy 26
beaverton , Oregon
Short term paint touch-up
We have just gotten 1975 26' Argosy Motorhome. Because we are still underway with a 1965 Airstream restoration, we do not want to fully repaint our Argosy for a year or two. One panel which was previously repainted and the two galvanized end-caps need to be spruced up to pass for OK for a few years. What color would match the original off-white. Also, we will obviously also repaint the brown eventually: what color would match original? Any recommendations for where to source the paint?
Thanks!
1965 31ft Airstream Sovereign
1975 26ft Argosy Motorhome
Imagine the sight of them linked together!
gmehal is offline   Reply With Quote
Old 02-09-2010, 07:25 AM   #2
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
Thanks!
I have done temporary touch-up on our Argosy with Krylon Ivory spray paint. Matches exactly. I did it two years ago and it still looks good, not in a hurry to have it repainted anymore. I did sand the surface with 1500 and then 3000 grit sandpaper first. I don't know about the brown, we don't have it on ours.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
https://chaosinature.blogspot.com/
Isadora is offline   Reply With Quote
Old 02-09-2010, 07:46 AM   #3
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Once you get the end caps cleaned up you can (if you can take a sample of the color) have home depot tint a quart of rustoleum enamal and use a smooth roller. The paint will level smooth enough to look great and can be wet sanded later after curing. A paint shop recommended it after they tried it on equipment they had, rather than spraying enamal.
arcamedies is offline   Reply With Quote
Old 02-09-2010, 11:20 AM   #4
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
You can likely pull off something like the water heater, battery, or refrigerator access door to have it color-matched.
I should do that - got a spot or two that's flaking on ours...
Tom
mutcth is offline   Reply With Quote
Atlanta: short term storage Feb. 2010? AirsDream On The Road... 16 01-01-2010 07:36 AM
Short Term Trailer Parking in PA or MD Bambi75th On The Road... 9 09-09-2008 06:16 PM
Short Term Storage guy99 General Motorhome Topics 8 09-15-2005 05:01 PM
Short term fix, is it safe enough? Mike & Deb Tires 7 12-30-2004 04:10 PM
Short-term storage in central FL? rluhr Our Community 9 12-02-2003 09:36 PM
