Old 03-24-2015, 04:56 PM   #1
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
Removing some floor
Has anyone ever removed the floor in their Argosy from just behind the cockpit? I had some water damage and rot that I would like to address plus a nice soft spot. This is all under my galley area just in front of the bathroom. Roughly how far apart are the supports underneath? I only want to take out a small chunk or floor, enough to do my repairs. Everything else in the unit seems pretty solid.
Matt
mprokop87 is offline   Reply With Quote
Old 03-24-2015, 07:56 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Same as you know what, just a different pile.
Pg 2 will interest you but pg 1 is the nuts and bolts and will warn you about SEEMS OKAY. The difference being I replaced the front in four pieces with a 1/2" lap joint. Take the total width of the coach, add the 1 3/4" insert into the C channel, divide by two and add 1/4" and do a 1/2" lap joint.
http://www.airforums.com/forums/f311...me-106269.html
As for finding where floor grid is, you can always drill up through floor along side a piece of framework and then add half of framework width to get centre or even easier....the existing nails will tell you where the framework is.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 03-25-2015, 05:54 AM   #3
mprokop87's Avatar
1976 24' Argosy 24
Victor , New York
This looks like it might be one hall of a job. I might postpone it and just patch everything up until the time is ready. My floors are pretty solid except for a few spots under the windows. The ones in the back dont matter because I built a bed over my entire rear section but the one in the kitchen is my concern. Its right behind the driver seat, so no one should ever step on it, but I would like ot get it fixed eventually.
Removing interior vinyl panels: rivet-removing tool? What's underneath? Ellie25ftSov Upholstery, Blinds, Walls & Interior Finishes 2 08-20-2014 08:34 PM
Some progress and Some Questions SCopp 1973 Overlander 3 02-03-2013 07:25 AM
Some call it a hobby, some, an addiction balrgn 1974 Overlander 45 08-18-2008 07:32 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
Removing old flooring and enhancing exisiting floor? Andy R Floor Finishes 4 05-18-2002 12:56 PM
