Old 06-27-2018, 12:44 PM   #15
1977 24' Argosy 24
Crooksville , Ohio
Cool water
maybe a stupid question but i will ask anyways lol, this weekend we are filling our water tank for the first time. I understand you have to use water pump when filled to get through out the system. When you are emptying all water, I see that toilet water and sink water water have different levers on outside, but what about water you do not use, how do you empty the entire tank.
Sbell333 is offline   Reply With Quote
Old 06-27-2018, 01:12 PM   #16
Once your water tank is filled you then need to turn the pump on to get water pressure throughout the system. If your pump is not on you won't get any water out of your sink faucet.
The water system in your coach will have several different low-point water drains. There will be valves with a hose or pipe that points down to the ground. Your water tank will definitely have a valve like this that is close to the tank itself. Opening the valve will drain the water from the tank.
Did you find the link for the 77 operators and service manuals? The manuals should provide information as to where the drain valves are.
bkahler is online now   Reply With Quote
Old 06-28-2018, 06:34 AM   #17
1977 24' Argosy 24
Crooksville , Ohio
water
i have went through the manual, all i see is how to replace stuff and making sure tank is empty lol, i will continue to look i guess
Old 01-10-2019, 06:52 AM   #18
1977 24' Argosy 24
Crooksville , Ohio
new paint and floors
here are some pictures of new paint and floors from last year. Only problems we have ran into so far is that when we run water through the tank, it seems to leak in the middle underneath and will not pump through. The stove works so i know the gas works but can not get the heating system to work
ID:	331450   Click image for larger version
ID:	331452   Click image for larger version
ID:	331454   Click image for larger version
Old 01-10-2019, 08:47 AM   #19
Looking good!
Old 01-11-2019, 08:17 PM   #20
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
PM sent!
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
New Member: 1977 24ft. Argosy Rear-door granaudio All Argosy Trailers 10 10-23-2017 07:10 PM
1977 Airstream Arogsy Motorhome Vintage Ready to Drive anywhere Nice clean open eBay Watch Airstreams on eBay 0 02-22-2012 07:50 PM
1977 Airstream Arogsy Motorhome Vintage Trailer Ready to Drive eBay Watch Airstreams on eBay 0 02-07-2012 07:50 AM
Arogsy 24ft Motorhome Airstream product 1977 454 14000 oringinal eBay Watch Airstreams on eBay 0 10-26-2011 09:30 AM
New owners of a Arogsy 26' Tom Sawyer Member Introductions 5 04-29-2008 03:17 PM
