Old 02-07-2011, 04:47 PM   #1
projector's Avatar
1972 23' Safari
NSB , Florida
receiver hitch, frame repair
So it started with a simple solution to a couple of problems and turned into a can of worms. The plan was to add a spare tire carrier and to raise the reveiver hitch. The hitch was under the bumper and bottomed out while backing into the street...plus it was too low for most trailers.
ID:	121745Click image for larger version
Name:	bumper before.JPG
The bumper came off in 2 pieces. It was broken once before and was poorly welded back together. It broke in exactly the same place.
Name:	bumper removed 1.JPG
ID:	121751Click image for larger version
Name:	bumper broken.JPG
ID:	121750Click image for larger version
Name:	bumper removed 2.JPG
Once the bumper was off I could really see what poor shape the frame was in. So I hired a welder from work to help me with it and we replaced the frame rail ends. One side we had to go forward about 2 ' and the other about 5'. The steel is a 2"x5" 1/" thick section as original. To get to everthing I had to pull the generator and drop the propane tank...but they both needed attention anyway so not a big deal. I didn't get any demo pics because the helper was too fast but here's after fabrication with spare carrier and first coat of paint. I used Hammerite, silver first and followed with black so I could see where I missed.
Name:	frame repair_hitch 004.jpg
ID:	121753Click image for larger version
Name:	frame repair_hitch 005.jpg
ID:	121755Click image for larger version
Name:	frame repair_hitch 009.jpg
On one side where the new rail met the old rail, the ends were cut on an angle to get more weld area. The other wasn't as easy to get to so it's a square cut and plated for support.
Name:	frame repair_hitch 008.jpg
More to come. Thanks
Name:	frame repair_hitch 001.jpg
projector is offline   Reply With Quote
Old 02-07-2011, 05:02 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
The ole girl has a pretty good lookin' rear end.
Old 02-07-2011, 06:19 PM   #3
Ottawa , ON
:: snort :: You think so?
Old 02-08-2011, 07:07 AM   #4
projector's Avatar
1972 23' Safari
NSB , Florida
She's aged well.
Old 02-08-2011, 05:51 PM   #5
projector's Avatar
1972 23' Safari
NSB , Florida
Here's the final.
Generator is back in and running with a new carb, fuel filter, air filter and spark plug. I still need to change the oil but it's easier with the unit in it's compartment. The propane tank is painted and installed. I need to touchup the bottom because it came out easier than it went in. It took a floor jack and a lot of swearing but i won.
Here's everything back together. At first I wanted a more square hole but structurally this is stronger by spreading out the load. Plus it was a whole lot easier to cut, 2 hole saw cuts and removint the center. Also I added 4 extra screws arround the opening to hold the bumper on for extra support.
ID:	121848Click image for larger version
ID:	121849Click image for larger version
This isn't exactly related but I also sand blasted and painted both emblems.
Old 02-08-2011, 08:01 PM   #6
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Sweet
John H. is offline   Reply With Quote
Old 02-08-2011, 08:04 PM   #7
Ottawa , ON
Yeah, her rear end looks fresh as a daisy.
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 03:39 PM
Ready To Begin Tear Down To Frame.?.?! Althea68 Repairing/Replacing Floor &/or Frame 11 01-26-2011 05:28 PM
Equalizer hitch benefits Moonstruck Hitches, Couplers & Balls 34 01-19-2011 09:03 AM
Which Hitch to buy? jomondnv Hitches, Couplers & Balls 19 01-01-2011 08:22 AM
