Old 05-29-2011, 03:58 PM   #1
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
Rear outlets on a '77 24 foot rear bath
First time really using the "new" Argosy. The owners manual says there should be a 12v and 120v outlet to then right side of the bathroom window. Andrea and I are lost as to where they are. Anyone else have the same issue? Found the outlets?
WineStream is offline   Reply With Quote
Old 05-29-2011, 04:04 PM   #2
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
If it's at all like my '73 26, they are up and to the right (when facing the rear) of the mirror...The 120v is immediately right of the mirror and the 12v is housed in the med. cabinet portion of it.
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 05-29-2011, 04:05 PM   #3
x
XXXX , XXXX
Jason I can't help you but if no one answers try NOHILLGRISH in Springfield MO or TAE in Clearwater Fl. They both have 77 Argo's 24 fters and have been active lately.
wasagachris is offline   Reply With Quote
Old 05-29-2011, 04:09 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Rear outlets on a 77 24 foot rear bath
Greetings WineStream!
You might try looking behind the hinged vanity mirror. At least one of the two outlets is located behind the hinged mirror in each of my coaches.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 05-29-2011, 05:06 PM   #5
WineStream's Avatar
2005 30' Safari
Images: 24
Just a reminder: we're in a motorhome thread, not trailers. I'm not sure how similar they are.
My Airstream trailer has outlets on the under side of the cabinets. Not really possible in the Argy moho. I've attached a couple pics of the bathroom cabinet, side and under.
Name:	2011-05-29 19.01.33.jpg
ID:	131007   Click image for larger version
Name:	2011-05-29 19.01.47.jpg
Old 05-29-2011, 05:38 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers > Rear outlets on a '77 24 foot rear bath
Looks like you're in a trailer thread to me. Clarifying that should help.
It's probably a good idea to mention motorhomes even if you are posting in the motorhome forums because they show up on the portal and it's not obvious you're talking about a motorhome unless someone remembers to checkout the forum at the top. I'll admit, I often forget. Motorhomes are way more unusual than trailers. Way cool, but still in the minority.
Good luck on locating outlets. While my 67 Trade Wind (trailer) has a 12v outlet in the rear bath, my 83 Excella (trailer) doesn't in its mid-bath. As much as things change from unit to unit, you may not have one.
Vaughan
Old 05-29-2011, 06:36 PM   #7
WineStream's Avatar
2005 30' Safari
Images: 24
Sorry, a mod moved my thread from the argosy moho area to the argosy trailer area. Hopefully it will be moved back soon.
Old 05-29-2011, 06:54 PM   #8
Ottawa , ON
My apologies, folks, although I read this complete thread through, I totally misunderstood that it was meant to be in the Argosy moho sub-forum. Here I thought I was helping by moving it.
I remember thinking that it wouldn't be the first time that an Airstream claimed minor feature wasn't there. IIRC, the owner's manual for my Sov says that there is a 120V outlet in the rear bath for shaving, not the case.
In any event, very sorry. Won't happen again!
Aage
Old 05-30-2011, 08:57 PM   #9
WineStream's Avatar
2005 30' Safari
Images: 24
Today I found a tandem 120v outlet in the curbside closet in the bathroom, which according to the manual shouldn't be there, but still haven't found the elusive 12v outlet in the bathroom.
Old 05-31-2011, 01:21 AM   #10
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
On my '82 280 there is a 120V receptical in the bathroom closet, mine is street side, but I have not found a 12V socket yet.
Cheers, Dan
Old 06-26-2011, 08:53 PM   #11
Darel's Avatar
1977 28' Argosy 28
La Porte , Indiana
Send a message via Yahoo to Darel
Winestream,
I have a 1977, 28' with a rear bath. I checked for the outlets that you mentioned and they were pretty easy to locate. My 120V is inside the med. cabinet w/the wires of the 12V inside also. The 12V outlet is on the underside of the cabinet. I'm posting a couple pics.
Darel is offline   Reply With Quote
New twin mattresses for rear bath billynewk General Interior Topics 4 07-31-2011 06:57 PM
Painting Rear bath options SilverHoot General Interior Topics 11 04-07-2011 08:31 AM
Replacing the floor in a rear bath elkie2331 Repairing/Replacing Floor &/or Frame 4 04-04-2011 07:35 PM
1976 Rear Bath Lights Eagle & Bear Electrical - Systems, Generators, Batteries & Solar 5 03-26-2011 04:20 PM
1976 31 ft. Airstream - Rear Bath eBay Watch Airstreams on eBay 0 03-13-2011 12:40 PM
