Old 08-06-2015, 12:03 PM   #1
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Rear disc brake conversion
Looking for some input on benefits and any experience in installing a rear-disc brake conversion on a small Argosy.
The brakes on my 20ft work, but you have to stand on them, and then for about 80% of the pedal travel there is not a lot, but they are able to lock the front wheels in the last 10%.....so only the band from 80-90% is useful.
I'm looking for something more progressive and that seems to mean a different hydro-boost unit (mine has been tested and is working to spec) or different brakes.
I have the parts guys looking at bigger/modified hydroboosts (to get the power curve altered), but also I want to get something better in terms of brakes on the back. There are plenty of disc brake conversion kits for 10 lug dually axles, almost as many for 8 lug with either a 14 bolt or a Dana70 rear axle and 19.5" wheels, but to fit the little 16" wheels on my 20ft (and I have already established bigger wheels wont fit without changing the frame) it seems only TSM have a kit (2830 - TSM Mfg. Co., Inc.). Anyone tried it?
martin300662 is offline   Reply With Quote
Old 08-06-2015, 12:57 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Martin,
I had about the same curve on my 310 with four wheel disc. New pads, flex lines, master cylinder, and brake flush. Still had a good deal of travel in the pedal before real engagement of the brakes. I was told by two different mechanics that I needed to get used to it, its just the way they are. I started snooping around looking at the brake linkage for some adjustment or something to take some of that travel out and sure enough found a cure....for mine. There is a vertical rod on the front side, towards the grill, that has several inches of thread on the end and a coupling with a through pin. (I cant remember the name of that coupling, U shaped end with a female threaded end that threads onto the vertical rod. Through pin with a cotter key) But anyway, I started threading that coupling up the vertical rod a little bit at a time and eventually it took the travel out of the brake pedal. There wasnt "slop" in the linkage, it just needed to activate the push rod into the master cylinder higher in the stroke of the pedal. Sure enough, I got it adjusted up and it made a WORLD of difference in the brake pedal. I had one fron wheel jacked up off the ground while adjusting it so I could check for any drag in the brakes. I realize we have a didderence in our brake system but the linkage may be similar, dont know. But its sure worth checking out before you go much further. You may want to go ahead and do the rear brake conversion which is understandable but if you have that same adjustment capability in your linkage it could solve all or part of the pedal travel problem.
I hadnt seen anything mentioned here on the forums about that adjustment when I searched for all the threads regarding the brakes. It sure worked for me and Im pleased as punch now with how my brakes feel. That rod is pretty easy to spot when tracing the brake linkage, easy to get to from underneath the front end. The hardest part was just braking it loose to start threading that coupler up the rod, I used plenty of PB BLASTER and it broke loose without too much fiddling. If I can find a drawing Ill send you a link
Mike
mayco is offline   Reply With Quote
Old 08-06-2015, 01:28 PM   #3
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I will have to read this whilst actually looking at the hydroboost Mayco, because I think you are describing the output rod and shortening it (moving the coupler up) will increase the drag on the brakes, vs lengthening (moving the coupler down) will reduce the drag. But all the pictures I have seen don't have a thread on the output shaft there are just 3 or 4 locations for the circlip and you can shorten and lengthening to one of those positions only...I am just working for pictures though - reality could be totally different!!!
Old 08-06-2015, 01:42 PM   #4
mayco's Avatar
Clevis coupler is what thats called I think. Ill get underneath and see if I can take a picture that makes sense.
Old 08-06-2015, 02:02 PM   #5
mayco's Avatar
Name:	ImageUploadedByAirstream Forums1438887551.790614.jpg
ID:	244735Click image for larger version
Name:	ImageUploadedByAirstream Forums1438887586.639109.jpg
ID:	244736Click image for larger version
Name:	ImageUploadedByAirstream Forums1438887618.372230.jpg
ID:	244737Click image for larger version
Name:	ImageUploadedByAirstream Forums1438887668.055649.jpg
ID:	244738Click image for larger version
Name:	ImageUploadedByAirstream Forums1438887723.355877.jpg
Old 08-06-2015, 02:04 PM   #6
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Thanks Mayco, I will check when I get in from work
Old 08-06-2015, 02:13 PM   #7
mayco's Avatar
Well, obviously my memory kinda stinks but, the top couple pictures show the rod coming down and threads on to the connecting device. In the last pictures you can just make out the boot and push rod. What I did was thread the male end further up into that connecting rod which pushes on the push rod going to the hydroboost/master cylinder. So the brakes respond higher in the pedal travel. Good thing I dont write instructions for a living, Id be starving. Hope this helps, it really did the job for my brakes. Now when I press my brake pedal I can feel the brakes start to engage in about the upper 1/4 to 1/3 of the pedal travel. Worth a look anyway Martin.
Mike
Old 08-06-2015, 02:31 PM   #8
Keen amature
1975 20' Argosy 20
Chestfield , Kent
From the 1975 chassis manual there is a similar linkage the translate the pedal stroke to the input rod.... let me see if I can find it!!!
Old 08-06-2015, 03:40 PM   #9
1978 28' Argosy 28
This is interesting! I've got the same pedal feel in my '78. Good pedal, but toward the bottom and this is after a brake job, (which they bled the brakes for me). Keep us posted Martin.
bpg_austin is offline   Reply With Quote
Old 08-06-2015, 05:43 PM   #10
Keen amature
1975 20' Argosy 20
Chestfield , Kent
I definitely have a similar setup at first glance.
But on closer inspection the input rod is not threaded, and there is a fixed rose joint at the end of the rod.
Trouble is I can't see if there is any adjustment on the pedal rod from below and the grill is in the way from the front/above....and the 1975 grill is riveted on.
Think it is going to have to go up on a ramp to get a better view.
Old 08-06-2015, 06:45 PM   #11
Martin,
Here's a view of the rod/clevis if you were looking down from the floorboard where the brake pushrod exits the floor.
This would be a side view from where the radiator would be. Since my radiator isn't installed I can get a clean look at it.
The threaded end in the picture above is shown in Mike's picture below.
bkahler is online now   Reply With Quote
Old 08-06-2015, 07:12 PM   #12
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Thanks Brad. I will take another look at the weekend, as I ran out of daylight this evening.
The down side of poking around under the front is the Airstream guys may have given everything a once over but I think the is a set of SuperSteer bell cranks/arms, rod ends and urethane bushes in my near future.
Old 08-06-2015, 07:54 PM   #13
I put a supersteer on the drivers side of the old 310 and it made a huge difference in steering. My Argosy has new bushings in the original units so I should be good for a while.
For OEM brake controller with Airstream's disc brake setup cmkirkland Brakes & Brake Controllers 16 01-28-2016 09:17 PM
Rear disc brake question 92landyacht Mechanics Corner - Engines, Transmission & More... 19 10-16-2013 11:19 AM
Disc Brake Conversion Question AtomicNo13 Brakes & Brake Controllers 2 05-23-2012 09:53 AM
Disc brake Retro fit kits Inland RV Center, In Commercial Listings 57 01-29-2005 11:17 AM
Tandem disc brake kit Inland RV Center, In Commercial Listings 2 10-31-2004 12:25 AM
