Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Argosy Motorhomes
Old 11-01-2012, 08:24 PM   #1
huberto's Avatar
1979 24' Airstream Excella 24
Monterey , California
'79 Excella 10 amp DC circuit problem
Attached picture is of the DC fuse panel which is vertically mounted behind the passenger seat (just like the 1978/9 Argosy.)
I have found a 10 amp drain to the house batteries! Circuit 7 is the culprit. I pulled the fuse to stop the drain, but cannot figure out what is the cause. (Airstream Manuals do not identify where the individual DC circuits go. The purple wire does go to the galley overhead lights, but must also power something else, as these lights I don't think could draw 10 amps.
Any insights? Thanks.
huberto is offline   Reply With Quote
Old 11-01-2012, 09:55 PM   #2
huberto's Avatar
Problem with DC circuit on '79 Airstream MH
Old 11-01-2012, 10:22 PM   #3
1974 Argosy 20
Kooskia , Idaho
Just a guess, but possibly the kitchen exhaust fan is stuck and on. You don't know it is on as it is not running. Another possibility is an overhead vent fan, or furnace fan, any one of which could be frozen, but drawing current. The water pump motor is another possibility.
Old 11-01-2012, 10:33 PM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Leave the fuse out. When you find something that doesn't work, that's it!
Old 11-01-2012, 10:39 PM   #5
Not sure on Argosy MH's...
Bathroom fan seized?
Old 11-01-2012, 10:46 PM   #6
huberto's Avatar
Thanks for your reply idroba! With the fuse out, all the items you mentioned work fine, obviously running on other circuits. I wonder what else it could be?
I suspect the rusted-out non-working furnace. Just need to figure out how to isolate and identify. I would love a schematic!
Old 11-01-2012, 10:47 PM   #7
huberto's Avatar
Thanks drboyd:
That's what I will do. I'll start with the furnace. I smell a rat.
Old 11-01-2012, 10:55 PM   #8
huberto's Avatar
Thanks Keyair, I will check that.
Seems far down the line, but would be capable I guess of drawing 10 amps. I also suspect the old Suburban furnace. Wish I had a schematic!
Old 11-02-2012, 05:32 AM   #9
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Originally Posted by huberto View Post
Thanks drboyd:
That's exactly what I had....mice. My issue was in the front passenger side wheel well. A rodent built a nice house there and chewed my wires. The wires also sit on a C-channel and wear at that spot. The wiring harness left the 12v panel, goes OUTSIDE into the wheel well, and then re-enters the wall. The wire are unprotected for that short distance. Maybe they changed it for the Airstream brand! They learned as they went with the Argosy prototypes!
ViewRVs is offline   Reply With Quote
Old 11-02-2012, 07:27 AM   #10
Compartment lights??
Could be.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-02-2012, 07:43 PM   #11
Surprise's Avatar
1984 31' Airstream310
Surprise , Arizona
Circuit 7 on my 310 is for the refrigerator.
Surprise is offline   Reply With Quote
Old 11-03-2012, 10:07 AM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Do you have the refer in "electric" mode? A 150 watt heating element would draw 10 to 12 amps.
Old 11-03-2012, 12:13 PM   #13
huberto's Avatar
Solved!
Thanks Keyair:
It was indeed the bathroom fan. Impressive bees nests build up in there jambed the fan!
Old 11-03-2012, 12:39 PM   #14
huberto's Avatar
Problem solved!
The bath fan was jambed with bees nests.
Old 11-03-2012, 01:40 PM   #15
Thats great news... that you found the issue that is...
I looked back at my issue with fuses and the shower fan, and my fuse was #7...
