Old 04-12-2016, 07:26 PM   #71
Forgot to mention Peanut's new brake drums arrived today. I decided to throw a coat of paint on the first one to try and slow the rusting process down a little. With luck I'll try and install the hub tomorrow after work.
The second will get painted later tomorrow.
Old 04-12-2016, 07:30 PM   #72
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
That is a preformed front quarter the one, I took off the 28 was preformed. Martin has what looks like a good front quarter on the 28. As long as it wasn't damaged when the headlight casting was removed.It should be able to be removed and reused. It would be expensive to buy from Airstream.
After the bucked rivits are removed there will be 1/16 pre assembly rivits to watch for at the corners of the panels.
shepherd57 is offline   Reply With Quote
Old 04-12-2016, 07:43 PM   #73
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
After the bucked rivets are removed there will be 1/16 pre assembly rivets to watch for at the corners of the panels.
Unfortunately (and at the time I didn't know it would be needed....) I made a budgetary decision to get AS NE to cut around the wheel well trims on the donor. So although the rest of the panel is good - the wheel opening so approx 2in larger than original. I guess hindsight is a wonderful thing!
I guess I need to find out how 'expensive', expensive actually is.
martin300662 is offline   Reply With Quote
Old 04-12-2016, 07:44 PM   #74
shepherd57's Avatar
Lindsay , Ontario
It might be easier to just drill out the heads of the bumper bolts to remove the bumper. And then use heat to get the rest of the bolt out I had to do that on a couple of mine. Then I replaced them with 1/4" st steel counter sunk Phillips
Old 04-12-2016, 07:48 PM   #75
shepherd57's Avatar
Lindsay , Ontario
Then I would go with Brads idea and make a panel from the trim molding down. Brad is right that part is basically a flat panel. The upper section is the formed part
Old 04-13-2016, 06:34 AM   #76
I was reading through a list of old receipts that I found in one of Peanut's storage drawers last night and one of the items a previous owner wanted done was to "check wiring under dash - remove whatever isn't necessary".
I about fell out of my chair laughing!
After an untold number of owners modifications plus the original crappy wiring that statement probably applies to 50% of the wiring under our dashes.
Old 04-13-2016, 07:33 AM   #77
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Its all those darn gauges and gizmos that people 'need'!
Old 04-13-2016, 07:43 AM   #78
Does that mean I don't need the 12 gauges that I'm planning on installing in my dash?
Being an Automation Engineer by profession I guess I just have this fascination with gauges
Old 04-13-2016, 06:39 PM   #79
Brakes are complete for the right rear wheel. Still need to torque the lug nuts and slide the axle into place. Should be able to complete that tomorrow and get started on the left side.
Old 04-14-2016, 06:32 PM   #80
Moved on to the left rear brakes this evening. Got Peanut set on jack stands and the drum removed. Tomorrow I'll pull the backing plate and head to the car wash to clean and degrease it. With luck I might even have the backing plate re-installed by the end of the day. Things go faster when you have the parts on hand!
I still haven't found a smoking gun as to what might have caused the brake fluid to be missing from the master cylinder. I did notice this spot on the rear axle but I haven't tried yet to identify whether it's a leak from the differential or brake fluid from the brake line. I'll try and figure that out tomorrow.
This sort of thing scares me. Airstream routed the propane line right down and slightly below where the wheel well sheet metal ends. Granted there is supposed to be a mud flap in place. However I don't think a mud flap is going to stop road debris or tire remnants from shearing off the mud flap and taking the propane valve with it.
Not my idea of good design
Old 04-14-2016, 08:00 PM   #81
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by bkahler View Post
........... backing plate and head to the car wash to clean and degrease it.
Any room for one of these in your shop Brad to make cleaning parts for Peanut (and anything else) easier?
http://www.harborfreight.com/automot...ump-60769.html
That area of the axle certainly looks suspicious, is there anything above it?
Definitely looks like we need some POR15 on those wheel wells! Any chance the propane line can be re-routed?
Old 04-15-2016, 05:40 AM   #82
I have one of those parts cleaning tanks. They work great for somethings but 5 minutes at the car wash using their engine degreaser works wonders.
Not sure yet. I'm going to scrape some of the goo off and see if I can get an idea of what type of oil it is. My first impression is it's gear oil from the differential.
It should be a simple task to shorten the lines and install a new valve. I wouldn't consider trying to reuse the old valves, assuming they even work, because new replacements aren't that expensive. I've got a flaring tool for the copper pipe so it's just a matter of taking the time to do the modification.
Old 04-16-2016, 02:34 PM   #83
I think I found the smoking gun for the rear brakes not having any fluid. The left rear wheel cylinder was pretty much toast. Fluid was definitely flowing out past the dust seals. Add leaking brake fluid with leaking rear axle seals and you end up with a real mess inside the drum!
So today I finished installing the left rear backing plate assembly. Assembly time for the left side was about half of what it took me to assemble the right side
The brake tube that screws into the wheel cylinder was frozen and I couldn't budge it. So I move to the Tee where the brake tube screws in and tried loosening it there. That was frozen as well but I did manage to break it loose but it snapped the brake tube as well. After discussing it with Martin I opted to fabricate new brake lines. I think they came out pretty good
ID:	260873Click image for larger version
ID:	260870Click image for larger version
ID:	260871Click image for larger version
Old 04-16-2016, 02:47 PM   #84
Now for the drama of the day
Everything was assembled on the left side except the brake drum. I slid it into place and started to torque the wheel bearing lock nuts. This is where things went down hill....
It took forever to reach the 50 ft/lb torque required to seat the bearings. Once you reach 50 ft/lbs you're supposed to back off the nut and re torque to 35 ft/lbs and then install the lock nut.
After reaching the 50 ft/lb torque the drum wouldn't budge. The right side spun nice and smooth at 50 ft/lbs but the left side was frozen solid. I back the nut off all the way and pulled the drum back to where it would spin. I then repeated torquing the nut with the same results. Tried the several times and finally pulled the drum off and didn't notice anything that would cause a problem.
In case I didn't get the backing plate on correctly I removed and re-installed it but it was definitely seated properly.
I then repeated the process about 4 times rotating the drum as I slowly torqued to 50 ft/lbs. While rotating the drum you could definitely here it dragging on the brake shoes. Looking closer at the brake shoes I found this:
ID:	260874Click image for larger version
For whatever reason the top inside corners of the shoes are dragging o the drum surface. I verified the shoes were seated properly and couldn't find anything amiss there.
At this point I'm not sure what to do. The only thing I can come up with is to file the high spots down some to allow the drum bearings to be set to the right preload and then adjust the shoes for drag.
Anyone have any suggestions?!
vintage travel trailer canned ham? peanut? shasta? not airstream old camper look eBay Watch Airstreams on eBay 0 04-01-2012 06:30 PM
1971 peanut travel trailer small 10ft not airstream eBay Watch Airstreams on eBay 0 06-23-2009 01:40 PM
Pink Flamingo Lives Wayne&Sam Off Topic Forum 8 06-02-2007 05:55 AM
Airstream Hype lives on! Sneakinup Trailer Values 9 08-23-2005 11:14 PM
Airstreamphotos Lives! j54mark Forum Admin, News and Member Account Info 0 01-13-2004 05:27 PM
