07-21-2018, 10:56 AM
#721
Richmond
, Kentucky
Where the map used to be located he used the DA sander with various grits of paper and then used the buffer with the F9 grit and this is what it looks like now.
The before:
The after:
I believe he also used the DA sander on the door and then the buffer.
The before:
The after:
Next update will likely be Monday or Tuesday, he said something about his arms needing a break
1975 24' Argosy Motor Home
07-26-2018, 04:03 PM
#722
Richmond
, Kentucky
Progress as of this morning.
07-26-2018, 11:17 PM
#723
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Looking great Brad. Any photos of the drivers side?
Looks like the new front quarter aluminium is polishing up as well as the original?
07-27-2018, 06:04 AM
#724
Richmond
, Kentucky
Nothing's changed on the drivers side since he finished stripping the paint off back on the 12th. Right now he's been working in the mornings on the passenger side which is mostly in the shade during that time frame. Once he starts on the drivers side we will likely turn Peanut around so he can continue to work in the shade.
I was a little nervous about the new quarter panel when you decided to polish! It does seem to be polishing out the same as the original skin. It's overcast today so I should be able to get better pictures of the passenger side.
07-27-2018, 11:12 AM
#725
Richmond
, Kentucky
This mornings progress.
07-31-2018, 04:56 AM
#726
Richmond
, Kentucky
Martin and I have been having a discussion on some of Peanut's skin imperfections. The three horizontal lines in the first picture appear to be possible tree branch scratches. However I'm almost inclined to think they were there from the factory and are really marks introduced during the manufacture of the Argosy. The holes just to the left are from the awning mount and will be covered with a patch plate once Ernie gets farther along with the polishing.
More phase one sanding/polishing.
07-31-2018, 06:07 AM
#727
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
I think the chances of something naturally making three parallel marks is pretty slip Brad....looks more like the types of marks you get as sheet material runs over rollers either in manufacturing the sheet or in moving it.
07-31-2018, 09:59 AM
#728
Richmond
, Kentucky
Material handling scrapes are what they remind me of. It will be interesting to see how well they can be polished out.
08-01-2018, 06:35 PM
#729
Take me back to the 70's
1970 21' Globetrotter
1971 29' Ambassador
1977 20' Argosy 20
Boston
, MA
Did you notice the scratches when it was painted?
Jami
77 20' Argosy Motorhome-
70 21' Land Yacht GT-renovating
75 20' Argosy Motorhome...ISO. radiator
08-01-2018, 06:40 PM
#730
1971 29' Ambassador
1977 20' Argosy 20
Boston
, MA
These? I have a couple, I bet they could be sanded lightly.
How is he going to polish the rivets? The wool pad won’t get in there
Jami
08-02-2018, 07:14 AM
#731
Richmond
, Kentucky
Attachment 318668
There's a good chance the bulk of the scratches can be removed. However some portions are fairly deep. I'm sure a lot of sanding will be involved.
I'm not sure how he's working around the rivets. I'll have to ask.
08-02-2018, 04:45 PM
#732
Richmond
, Kentucky
Here's a close up of some rivets.
Working across the front.
08-03-2018, 08:15 AM
#733
Geismar
, Louisiana
How many hours does Fred have into buffing peanut? I am about to buff my caramel next month. Wondering what I got ahead of me in terms of hours.
08-03-2018, 10:07 AM
#734
Richmond
, Kentucky
Fred? You mean Ernie
My best guess is he's between 30 and 35 hours polishing so far. This doesn't count the hours to strip the paint. A lot of those polishing hours are dealing with scratches. He showed me a section today where the scratches had been greatly reduced to almost nothing by using a different technique with different media.
08-03-2018, 11:58 AM
#735
Richmond
, Kentucky
Here's an example of the revised technique that Ernie has started using. I guess this would be considered phase 1 polishing still.
08-04-2018, 10:18 AM
#736
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Do you think Ernie could post a ‘guide to stripping, buffing and polishing’ once he has worked to kinks out?
08-08-2018, 06:51 AM
#737
Richmond
, Kentucky
I'll ask but they could be trade secrets
08-08-2018, 06:57 AM
#738
Richmond
, Kentucky
08-08-2018, 06:15 PM
#739
1979 24' Airstream Excella 24
Tipp City
, Ohio
Ernie is right. There is a sweet spot for the temps to polish. I would say 68 to 75 degrees. I never had any luck working i the direct sunlight. Always work in the shade and don't waste your time when the temp gets above 80 it just makes a mess.
08-09-2018, 11:29 AM
#740
Richmond
, Kentucky
