05-01-2018, 10:19 PM
#621
1977 20' Argosy 20
Arlington
Brad and Martin
I am definitely interested in making a replacement. The heavy lamp assembly in mine has contributed to severe cracking to the point that I have applied reinforced strapping tape to preclude the lamp from falling out. Originally when mine was new the ABS flexed a lot rolling down the road. In our Texas heat the ABS is so brittle that it easily crumbles. Also the ABS has yellowed. When new it was difficult to tell the difference between the light colored ceiling panels and the ABS.
Gregg
05-02-2018, 08:53 AM
#622
Richmond
, Kentucky
As the thought process evolves keep in mind that a replacement in fiberglass will require that the curve of the wall/ceiling be a permanent feature of the replacement part. My guess is the ABS panel was flexible enough when new that it was probably made flat and just laid into position and was flexible enough to do so.
I don't think I would have any problem coming up with a pattern of the curve, but I just wanted to make sure everyone knew about that aspect. The other issue is Ernie would have to spend the time to rebuild/repair the existing panel to use as a plug in during the mold making process.
Food for thought.
1975 24' Argosy Motor Home
05-02-2018, 09:35 AM
#623
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
I think the mold making process would be different this time Brad
On the valance the shop took a mold from the outside of your part, then cast replacements from inside that mold.
This time I think the mold would be from inside the current part, and then the replacements would be taken from the outside.
This opens the chance of using something like a urethane resin or silicone mold (poured into the current part). It should then peel out and let a fiberglass part be cast off of it. As long as the silicone mold is held in the correct curvature when cast then the fiberglass part would fit.
05-02-2018, 08:22 PM
#624
Dazed and Confused
Hillsburgh
, Ontario
Since the Argosy I'm purchasing from Don is a northern truck, maybe its interior parts will be in better shape for a mold.
I'd be willing to ante up the parts for any endeavour.
Cheers
Sidekick Tony
05-03-2018, 12:16 AM
#625
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Cheers
Sidekick Tony
I had heard the whisper Tony, but is this a quiet way of announcing you are joining the dark side of guys with painted coaches?
05-03-2018, 04:34 AM
#626
Richmond
, Kentucky
Cheers
Sidekick Tony
Unfortunately the 24' Argosy does not have this particular ABS panel installed. I don't know that it's unique to the 20 but it might be.
05-06-2018, 09:24 AM
#627
Geismar
, Louisiana
Does the other layouts have this panel? I will go check mine later today and see. I don't think it does though. :/
05-07-2018, 10:00 AM
#628
Richmond
, Kentucky
Dane, I know for certain your 74 doesn't have this panel. As far as I know it started being used in 77.
05-07-2018, 10:12 AM
#629
Richmond
, Kentucky
Friday and Sunday I spent a few minutes tinkering with Peanut's headlights. I'm in the process of installing the same LED bulbs that Mayco used.
One of problems with the original headlight buckets was the top adjusting screw on the drivers side bottom bulb had stripped threads. The adjuster was some sort of custom job from Airstream so I ended up removing an adjuster from the donor parts and riveting it into Peanut's bucket.
With the adjuster in place I was able to install the new replacement steel bulb holders. Both the driver and passenger side bulb holders were rusted beyond repair so replacements had previously been ordered.
I did follow WayneG's lead and drilled the large hole in the bulb holders to account for the breather cap on the LED bulb. I still need to add the holes to the upper bulb holders but the bottom holders are done.
Possibly later this week I'll be testing Peanut's wiring for the first time. So if you see a mushroom cloud on the horizon you'll know the cause....
05-07-2018, 10:16 AM
#630
Dazed and Confused
Hillsburgh
, Ontario
Please notify NORAD and the Ruskkies first.
05-07-2018, 10:22 AM
#631
Richmond
, Kentucky
Heck, I wasn't even going to tell the neighbors......
05-07-2018, 12:20 PM
#632
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
I'll watch the international news for an update!
05-07-2018, 02:46 PM
#633
Take me back to the 70's
1970 21' Globetrotter
1971 29' Ambassador
1977 20' Argosy 20
Boston
, MA
Originally Posted by bkahler
Friday and Sunday I spent a few minutes tinkering with Peanut's headlights. Brad
We are tinkering here ourselves...
[emoji15]
Jami
77 20' Argosy Motorhome-
70 21' Land Yacht GT-renovating
75 20' Argosy Motorhome...ISO. radiator
05-07-2018, 02:49 PM
#634
Richmond
, Kentucky
Originally Posted by jamimes
I'd have to say your LED's are getting installed.
05-07-2018, 06:44 PM
#635
1971 29' Ambassador
1977 20' Argosy 20
Boston
, MA
“We” tinkered first.. [emoji851]
Jami
05-07-2018, 08:04 PM
#636
Richmond
, Kentucky
Tinkered with Peanuts Headlights as well after work.
The wiring in each bucket is now working and configured correctly for the new LED bulbs. Hopefully this weekend I can install the bulbs
05-11-2018, 05:53 PM
#637
Richmond
, Kentucky
Peanut now has working LED headlights, front side LED marker lights and front turn signal lights
I was a little surprised by the headlights when in low beam mode. Seems odd that not all the LEDs are lit but that seems to be the case. The headlights still need to be aimed so when it goes to the shop for a new exhaust system I'll have them align the headlights as well.
I'll have to get some night photos one of theses days and post them.
05-11-2018, 07:23 PM
#638
1971 29' Ambassador
1977 20' Argosy 20
Boston
, MA
P
I was a little surprised by the headlights when in low beam mode. Seems odd that not all the LEDs are lit .
These are ours on low beam.-Manouch
05-12-2018, 04:29 PM
#639
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Attachment 310698Attachment 310697
Are you sure there aren't marker/side light, low and high beam modes Brad?
05-12-2018, 06:00 PM
#640
Richmond
, Kentucky
I'm fairly certain they are connected correctly. The GM factory configuration only turned the lower bulb on when high beam was selected.
The bulbs have a ground, low and high connections. In the factory configuration either the low or the high is on, not both at the same time. In fact the lower bulb only has a ground and high beam connection. The low beam wire is not there.
Next time Mike reads this thread maybe he can comment as to what bulbs are on with low beam and high beam and if on low beam are only some of the LEDs are turned on on the upper bulb.
