11-26-2016, 04:34 PM
#441
Richmond
, Kentucky
We made a little bit of progress on Peanut today.
A few weeks ago while installing the new front air bags the brake hoses needed to be disconnected from the calipers in order to pop the lower ball joints. Unfortunately we ran out of time before we could bleed the brakes. So today we bled the front brakes. All that's left to do before the jack stands can be removed is to replace 4 cotter pins in the lower ball joints and tie rod ends and to install new dust boots for the tie rod ends.
I had ordered replacement boots but what I ordered and what they shipped were two totally different items So now we wait for new dust boots. I would imagine Peanut will be sitting on all four wheels again this coming weekend.
The other accomplishment was to fit the new generator floor pan. This past summer I had one fabricated and today we set the pan in place and drilled mounting holes for it.
In the next few days I'll mark the various holes and other cutouts on the floor of the pan and then have Ernie do the hard stuff
Slowly, very slowly....Peanut is taking shape.
1975 24' Argosy Motor Home
11-30-2016, 08:33 AM
#442
Richmond
, Kentucky
Water leaks
Ever since Peanut made it's way to Kentucky the issue of water leaks has been a persistent problem. Over the course of the summer and fall we've done a few things to try and stop the leaks and I'm happy to say the number and volume of leaks has dropped way down. However the area around the windshield continues to confound me.
It's been mostly dry around her for longer than I can remember so I wasn't sure exactly where we stood on resolving the windshield leaks until this morning. We had a good solid rain last night and hoping for the best I checked the cockpit floors and sure enough they were wet. Here's a picture looking up at the top of the windshield from the drivers seat.
A few weeks ago I had Ernie apply Tremco 116 in black (as recommended by Peter) to the seam between the gasket and the front cap. He applied a good solid bead of sealant and there are no obvious gaps or holes in it. No sealant has been applied to the where the gasket contacts the glass. The only thing I can think might be happening is the water is wicking from the glass up and in through the gasket and past the glass to where it slowly drips down onto the floor boards. One other thing of note, Peanut is sitting on jack stands in the front so the roof actually slopes towards the back so I'm assuming any water that might be coming in elsewhere is running towards the back.
I really really want to stop the leaks so I can install the new wood floor in the cockpit area!
Any suggestions?
12-05-2016, 06:46 AM
#443
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Brad, the leaking is very odd. Not a chance of condensation on the interior of the steel cap causing this? The cap of my 310 "stores" small amounts of water on the side channels, when I brake hard it drips.
I can think of 1 method to try to isolate it. First put some food coloring on the glass/rubber surface and see if if the colored water wicks up and drips inside. If not move up to the vulkem sealed (painted steel/rubber) bead. I seriously doubt the later will leak.
AIR #13
12-05-2016, 10:42 AM
#444
Richmond
, Kentucky
Peter, it very well could be condensation from inside the steel cap. The humidity level here vs the temperature does create a ton of condensation pretty much year round.
On my old 310 there were similar issues with braking hard and having water drip down on you
Probably by the end of the weekend Peanut will be back down on all four wheels which means there should be a slight slope towards the front. At that point it will be interesting to see if the leaks seem to get larger or stay the same.
I do know there are a few loose buck rivets on the roof and some time in the near future I need to get up there and replace them with Olympic rivets.
Wouldn't the food coloring dry before it has a chance to wick up in between the rubber and the glass?
12-07-2016, 06:23 AM
#445
Richmond
, Kentucky
Getting closer to where we can install Peanut's generator. Probably by the end of the year. Still need to peel the plastic remnants from the old insullation and install new insullation at which point the enclosure will be ready.
When pulling the front springs to replace the air bags the rubber boots on the tie rod ends all but disintegrated due to rot. The tie rods themselves were just fine so I started searching for replacement tie rod boots. I found a place called After Market Suspension Parts that sells replacement boots made in Polyurethane which should last just about forever.
Previously I had bought boots from the same company for my drag link. My drag link was brand new but the boots were already dry rotted
12-08-2016, 05:01 AM
#446
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Definitely 'getting there' Brad!
12-12-2016, 08:10 AM
#447
Richmond
, Kentucky
Well, I didn't really accomplish much of anything on Peanut this weekend other than getting the front wheels put back on and removing the jack stands. The temps were in teens and 20s this past week and I just didn't feel like working outside in the cold
However now that Peanut is on all four wheels again and has brakes there's a good chance in the near future he will be driven down to the shop where I can do the welding for the front and rear bumper attachment points and the replacement step support.
12-12-2016, 02:15 PM
#448
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
All of a sudden I am not missing the US so much...we may get one day below freezing....in February
12-12-2016, 02:32 PM
#449
Richmond
, Kentucky
A couple of years ago we had a stretch in January where the temperatures got down below zero day and night for a few weeks. I didn't even bother going down to the shop during that time!
12-17-2016, 04:33 PM
#450
Richmond
, Kentucky
Out of the blue we had a short warming spell where the temperature got up to 60+ degrees! Ernie took advantage of it and managed to get the rest of the sealant on the windshield gasket. The gasket has now been sealed all the way around the perimeter (except bottom) and around all four sides of each windshield between the gasket and the glass. If this doesn't stop the front leak then I'll look at plan G which is loose rivets and that sort of thing.
While the temperature was so warm he also painted the inside of the electrical compartment.
Generator installation is being pushed out a little. I'm still looking for the best way to mount the floor pan to the side walls. Also I want to test run it one more time before installing it just to make sure it starts like it should. That still might happen before the end of the year. We'll see....
12-18-2016, 03:38 AM
#451
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Another 'milestone' passed this last week, and should be a cautionary tale to anyone taking on one of these sort of projects....
Even with Brad doing a big chunk of the labor, with many of the big parts coming from the donor, or (like the wheels and tires) being Bella's spares, and with Ernie doing the rest of the work (at far less than commercial rates), the running total for the cost of project went through $15K.
Although that spend includes most of the future spares to get Peanut back on the road (like the seats, and new AC), it does not include any projected labor cost or any of the interior work, the remaining body work, window gaskets or repainting.
Any one who thinks they can bring one of these old MH back into use (not perfect just usable) for less than $25K is living on cloud cuckoo land.....remember Peanut had extensive work by Andre (documented on the forum), and was 'supposedly' checked over by the shop in Florida before heading to Brad's place.
12-18-2016, 05:32 AM
#452
Airstream Driver
1994 30' Excella
Austin
LOL, Martin...Labor Of Love
Sweet little town you live now. I did a google earth search and even was able to "drive" the little roads. Must be exciting to navigate with Bellas steering wheel on the left side.
AIR #13
12-18-2016, 05:41 AM
#453
Dazed and Confused
Hillsburgh
, Ontario
Blew snow for 2 hours Friday and another 3 hours yesterday. We have had almost a foot of snow just in the last week! including a thunder snowstorm.
On the upside, it'll be a very white Xmas.
Cheers
Tony
12-18-2016, 07:08 AM
#454
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Hopefully we are only in this town until Thursday Peter, then we close on the new house - about 20miles closer to 'civilisation' and where the roads are a lot wider.
This current 'town' is actually the quarters for the air men/women of the old RAF Manston airbase (we have an RAF museum - including numerous planes and ancillary vehicles about 400yds away) and the typical road width is 120in. I would even try and bring Bella to this house and even our little Mercedes A class is 68in wide. This means each road has 'passing places' every few hundred feet, because even the smallest of cars can't pass.
You can see one of the passing places on the left.....
If this isn't scary enough, I will add that these roads only apply the national speed limit, ie 60mph so the closing speed could be 120mph on a road where two small cars don't fit!
12-19-2016, 05:53 AM
#455
Airstream Driver
1994 30' Excella
Austin
Martin, you hit the nail on the side of the head. From a financial viewpoint, these rigs are notoriously a bad investment. Just alone the parts will quickly bring them to 20k plus.
I have restored 3 Classic Motorhomes and have kept detailed record of every $ spent. Its mind boggling how much money goes into little stuff, like vulkem, rivets and this and that.
I simply cannot imagine or justify to add the cost of labor to the equation and do not think there is a market for these with the labor cost added.
So that begs the question, why does one do it?
For me its a Hobby, I really enjoy along with being a member of a group of like minded people.
If someone decides to have the bulk of the work done by a third party and is so lucky to find someone that is honest, skilled and available, I suggest to consider our late forum members 87MH, Dennis Watermann's signature:
AIR #13
12-24-2016, 02:21 PM
#456
Richmond
, Kentucky
Peanut decided for Christmas Eve he wanted to go visit my Argosy
It stopped raining enough for me to finish the patterns for the passenger side floorboards. I'll use these pieces to cut out the actual flooring on the correct thickness of plywood. The drivers side is about the same as the passenger side except there is a section of wood cut out to fit around the steering column and pedal box area.
If it doesn't rain tomorrow I should have the flooring cut out, after that they get coated with several coats of Spar Urethane.
Peter, I need to talk to you about the drain pipes you put in the cockpit windows on your old Argosy. Peanut needs these drain tubes real bad.
Merry Christmas everyone
12-24-2016, 03:46 PM
#457
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Great progress Brad
Merry Christmas!
12-25-2016, 11:15 AM
#458
Airstream Driver
1994 30' Excella
Austin
Brad,
I did send you a pm, but like to share with everyone my "high tech", fail proof solution to this very common problem
This was in a 1979 28' Excella.
Please keep in mind that I tried just about everything to find the elusive leak before I resorted to this solution.
After observing the location of the drip coming out of or close to the very front of the window channel, I permanently installed a small funnel under the channel with a drain tube leading out of the vehicle. I may also have drilled a hole to assure any water would drain out of the channel into the funnel. A solution driven by desperation, but it proved to be effective.
Years later, when I disassembled the front side panels of my 1987 345, I saw that Airstream had factory welded a drain tube to the center location of that channel.
AIR #13
12-27-2016, 01:36 AM
#459
1991 25' Airstream 250
Oxford
, Oxfordshire
I stopped counting the costs of upgrades years ago. I know my missus would put a stop to it if she knew the total cost
12-27-2016, 09:40 AM
#460
Richmond
, Kentucky
