Old 06-28-2016, 04:06 PM   #295
Originally Posted by martin300662 View Post
Are you re-purposing those military satellites again Brad? Or is it just the Google Earth have re-done the images in your area?
The first question I can neither confirm nor deny
As for the second question, Google Earth apparently now has better image resolution than NASA does.
Old 06-28-2016, 04:14 PM   #296
2007 22' International CCD
Other TLA's can do much much better
(Three letter agencies)
KE4GNK/AE
Old 06-28-2016, 05:44 PM   #297
Google does better than this picture as well when you get closer to the big cities. Out in the country they don't provide the same resolution
Old 06-29-2016, 10:42 AM   #298
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
What a nice location you have there.
When you've lived in cities and suburbs all your life it's always interesting to see the pictures others post.
Sometimes I see the driveways, the grassy spreads, the barn and structures and more country living and wonder/dream.
I digress, nice spot.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 06-29-2016, 11:15 AM   #299
Thanks! It is a nice property. It does require a lot of mowing but it's one of the more peaceful quiet places I've every lived.
Old 07-07-2016, 02:15 PM   #300
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Finally (and by that I mean after spending approx 80 hours and numerous broken tools), the bumpers are off the parts donor.
Along with all the original seat mounts, and belts (for both the drivers, passengers and barrel cab seats).
Along with the generator and many other parts.
Next stop is renting a Uhaul to get them all down to Brad's!
martin300662 is online now   Reply With Quote
Old 07-07-2016, 08:58 PM   #301
Wow!
I was beginning to think those bumpers were never going to come off I hope AS NE didn't charge to much for their "assistance".
I'd say you accomplished everything you really needed to.
Old 07-08-2016, 05:10 AM   #302
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by bkahler View Post
Wow!
Actual AS NE bought the most important thing to the party....the knowledge of the best way to remove the bumpers!
Turns out, the easiest (in my case only) way to remove the countersunk machine screws, is to get behind the bumpers remove the nut then knock the screw out from inside. However to do that you needed to be able to get under the bumper. I couldn't when it was parked (dumped?) out the back of the shop, but the techs had pumped up the tires and temporarily pulled it on to the asphalt using their plow truck....they didn't want to work laying in the dirt!
Old 07-08-2016, 06:50 AM   #303
It sure didn't appear that there was access to the bumper bolts from inside the frame. Hopefully that same approach will work with Peanut. If not I've got my acetylene torch that will work as well
I don't blame them for not wanting to work in the dirt, that's why Peanut is parked on my driveway!
Old 07-09-2016, 04:15 PM   #304
At some point in the past the right front brake line from the brake compensator block to the right front brake hose had been replace. It wasn't routed very well and rubbed on the gas lines to the fuel pump.
A while back I fabricated a replacement brake line to match the one on my Argosy and today I got around to installing it. The picture makes it look like its interfering with the rubber gas lines but in reality it's several inches behind them
Next up was to install the AC compressor. At some point someone had repaired an elongated hole in one of the mounting brackets. Unfortunately they didn't grind it down flat which made it difficult to remove and harder to try and install.
ID:	266318Click image for larger version
So prior to mounting the compressor on the engine I ground down the offending repair which made it much easier to set the compressor on the mount.
ID:	266316Click image for larger version
The compressor is now installed. Those A6 style compressors are definitely heavy!
I'm finally done reassembly everything between the front of the engine and the radiator so once the radiator is done it can be installed.
I've mounted an new AC condenser in front of the radiator and am currently working on installing a 16" electric fan to aid in cooling. I'd like to get the fan installed this week so when Martin get's here we can lift the radiator into place. Lifting the radiator and trying to set it in the chassis is not something I want to do by myself
Old 07-09-2016, 05:55 PM   #305
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Attachment 266320
Attachment 266319
Attachment 266318Attachment 266317
Attachment 266316Attachment 266315
Attachment 266314
Attachment 266313
Great stuff Brad....U-haul is booked, next job is to try and get all these parts in it!
Old 07-09-2016, 06:23 PM   #306
Getting the parts in the trailer is only half the battle. The other half is trying to find a place to put it all once you get here!
Old 07-09-2016, 06:39 PM   #307
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Oppsss!
Old 07-09-2016, 06:56 PM   #308
Oppsss!
We'll figure out something
vintage travel trailer canned ham? peanut? shasta? not airstream old camper look eBay Watch Airstreams on eBay 0 04-01-2012 07:30 PM
1971 peanut travel trailer small 10ft not airstream eBay Watch Airstreams on eBay 0 06-23-2009 02:40 PM
Pink Flamingo Lives Wayne&Sam Off Topic Forum 8 06-02-2007 06:55 AM
Airstream Hype lives on! Sneakinup Trailer Values 9 08-24-2005 12:14 AM
Airstreamphotos Lives! j54mark Forum Admin, News and Member Account Info 0 01-13-2004 06:27 PM
