Old 11-24-2010, 06:43 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Oil Filter leak
Has anybody had the oil filter mount above the filter leak, And if so how did you fix it. I have engine oil leaking and it looks like it coming from around and above the top of the oil filter. Is there a gasket where the oil filter adapter mounts to the block.
I don't think it is the rear main at least I hope not I checked the valve cover and it is not leaking
shepherd57 is offline   Reply With Quote
Old 11-24-2010, 08:42 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Yes. I had the same leak on a work truck in the past.
Vaughan
Old 11-24-2010, 09:00 PM   #3
shepherd57's Avatar
Lindsay , Ontario
what was the fix ?
Old 11-24-2010, 09:03 PM   #4
1983 34' Excella
1967 24' Tradewind
Images: 32
what was the fix ?
New gasket.
Once you remove the adapter it's pretty obvious.
Vaughan
Old 11-24-2010, 10:52 PM   #5
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Those rubber gaskets get pretty brittle over the years and tend to leak. Take it all apart and reseal it and your good to go!
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 11-25-2010, 02:51 PM   #6
shepherd57's Avatar
Lindsay , Ontario
Do you happen to know if those gaskets are still available or do I have to make them up.
Old 11-25-2010, 03:06 PM   #7
moderator
Airslide's Avatar
Wilton , California
Images: 50
Carefully take off the old one and go to Napa and they will find you an eqivalent seal. It will be either square cut or round.
Vinnie
Old 11-25-2010, 03:07 PM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
They should be available. That's part of the beauty of Chevy engines, they made a lot of them for a long time and lots of parts interchange.
It's like an o-ring with a slightly rectangular cross sections. Some people call it an o-ring, but to me that implies a circular cross sections. Maybe just me.
On edit: Vinnie posted just before me. He's right again.
You really shouldn't have any problems getting one, just take your adapter in.
(Taking your old parts to the store with you is always a good idea.)
Vaughan
Oil filter report Astrodokk Classic Motorhomes 11 10-03-2011 07:29 AM
Oil Filter Study ViewRVs Mechanics Corner - Engines, Transmission & More... 32 03-11-2010 06:26 PM
Oil and Filter Change gypsychris Mechanics Corner - Engines, Transmission & More... 6 05-24-2008 08:30 PM
Oil Filter cooperhawk Mechanics Corner - Engines, Transmission & More... 8 11-03-2003 12:57 PM
Onan 4k 1979 Oil Filter? RichardT Mechanics Corner - Engines, Transmission & More... 2 09-28-2003 07:50 AM
