Old 02-05-2016, 10:59 PM   #1
1978 28' Argosy 28
Broken Arrow , Oklahoma
New project 1978 28
I got it from my Grandpa. He added throttle body fuel injection to it. It needs some updating and repair but it's pretty solid.
Chevyboy123 is offline   Reply With Quote
Old 02-06-2016, 05:37 AM   #2
Chevyboy123 welcome to Airforums!
That's a nice looking Argosy you inherited, it appears to be a 77 or 78.
By all means post more pictures of your Argosy both inside and out. I for one would like to see pictures of the engine compartment as I'm in the process of adding TBI to my 74 Argosy.
Old 02-06-2016, 05:42 AM   #3
Gainesville , Florida
Go for it. Looks great.
Old 02-06-2016, 06:34 AM   #4
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Welcome on board Chevyboy123.
If you have a solid base, try to avoid the temptation to dive in and pull apart instead concentrate on getting it back in use and fix as you go. It's one thing to rebuild something that is already apart or gutted, but these are complicated beasts and many folks start with ideas of rebuilding/remodeling only to uncover a 'can of worms' that never get finished.
Get it back in use, enjoy, fix and update as needed, but best in that order.
martin300662 is online now   Reply With Quote
Old 02-06-2016, 11:52 AM   #5
1978 28' Argosy 28
Thanks guys
I'll get some additional pics today.
My plan is just get it back in shape then start updating. The first thing is brakes on the way home the driver side caliper locked up and the passenger side hardly worked. The pedal sucked and I'm not sure the back worked at all. I'm looking at changing the rear to disc so I can service them without removing the hubs. It also needs a heater the heat exchanger cracked on the old one.
Old 02-06-2016, 01:14 PM   #6
1978 28' Argosy 28
[URL=http://s47.photobucket.com/user/chevyboy123/media/D85396EC-406B-4773-9660-A5120DD2D242.jpg.html][/
Old 02-06-2016, 01:17 PM   #7
1978 28' Argosy 28
Old 02-06-2016, 01:25 PM   #8
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Think carefully before doing the disc conversion at the rear. If you look through my rebuild thread you will see the that my brakes sucked, then gave out all together. During the brake rebuild I asked the shop to do a disk upgrade and they advised against it, as disk brakes actually have a longer brake travel than well adjusted drums.
From my experience I now know that if the standard brakes are working as they should, they give a great pedal feel and at least stop my little 20 as good as a modern car/van. I took my low mileage Tacoma out today after driving Bella around last weekend and took a couple of 'stops' to realize I have to brake harder in the Tacoma than the Argosy to bring it to a halt.
Old 02-06-2016, 01:39 PM   #9
Boomer56's Avatar
1982 27' Excella
1982 28' Airstream 280
Midlothian , Texas
Broken Arrow! I have a friend up there I visit time to time! I also have a 82 Excella 280 that looks just like yours except it doesn't have paint! I've had it a year and just now getting started on it! Will be nice to see how you progress and compare! I was one of those guys that was going to tear everything out and quickly realized that was way more than I wanted to do! So now I'm focusing pulling carpet replacing with a hard floor and cleaning and repairing one thing at a time! Boomer in DFW area!
Boomer56 is offline   Reply With Quote
Old 02-06-2016, 02:47 PM   #10
1978 28' Argosy 28
The TBI setup is pretty straight forward. This one has an aftermarket harness with an 88 BBC computer. It uses all GM parts. There are factory throttle body adapters from the early TBI pick ups that will bolt directly to the Q-Jet manifold and TB assembly. You will need the TBI era coil and distributer. I hope this helps.
Josh
Old 02-06-2016, 05:14 PM   #11
Josh
Josh, thanks for the pictures!
I'm going all GM as well. I'm basically sourcing all the parts that would be used on a 94 P30 with a 454. The PCM is from a 94 with the memcal for a P30/454/4L80e which is basically the configuration that I have.
You can read about the conversion here.
You've got a pretty decent looking coach. A lot of good advice has been posted which ought to keep you busy for a while
Old 02-06-2016, 08:53 PM   #12
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Welcome aboard Chevyboy! Looks like you grandfather really hooked you up with a gem. Do be careful with those brakes. The most important thing is that you can stop. You definitely don't want to get in an accident and damage that beauty. Good luck
Gregsch is offline   Reply With Quote
Old 02-06-2016, 11:03 PM   #13
1978 28' Argosy 28
Yeah that's squarely in the maybe column. I know factory rear brakes will do great when working correctly. I just hate having to pull hubs to check a wheel cylinder. I think the max GVW is 12,500, so the brakes should stop it great once they are freshened up.
Old 02-06-2016, 11:06 PM   #14
1978 28' Argosy 28
Sounds good to me!!
1978 31' 1978 Airstream Sovereign Land Yacht - South Florida JoshuaSteven Airstream Classifieds 0 08-12-2015 07:58 PM
1978 Airstream International Ambassador 29' Travel Trailer Project eBay Watch Airstreams on eBay 0 04-08-2012 06:40 PM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
1978 22 foot Argosy vs 1978 22' Minuet drussel All Argosy Trailers 37 12-02-2009 08:34 PM
1978 Argosy 24 Project BillyP All Argosy Trailers 2 11-18-2006 04:35 PM
