07-15-2021, 04:00 PM
#21
Richmond
, Kentucky
Originally Posted by Chevyboy123
Also would it be worth while to add a second AC to the top? I know I would need to upsize the generator would 6.5kw be enough?
A second AC would be personal preference. A 6.5 Onan was in the 345 that I had with two air conditioners so 6.5 should work.
My 310 with two air conditioners had a Kohler 7.0.
1975 24' Argosy Motor Home
07-16-2021, 07:10 PM
#22
1978 28' Argosy 28
Haskell
, Oklahoma
I finally got the hatch door back on!
07-18-2021, 01:04 PM
#23
1978 28' Argosy 28
Haskell
, Oklahoma
Well she got a bath, new door handle, and new front air bags. Slowly working our way down the list!
07-18-2021, 06:43 PM
#24
1978 28' Argosy 28
Haskell
, Oklahoma
So I have a carrier ac that it seems the blower motor is locked up on. Is it worth fixing or should I just replace the unit?
07-19-2021, 09:23 AM
#25
Richmond
, Kentucky
I'm of the opinion that fixing the blower will be a stop gap solution. The AC is an old unit and will likely cause problems once you have it running for an extended time. Again, just my opinion.....ymmv
07-19-2021, 10:41 PM
#26
1978 28' Argosy 28
Haskell
, Oklahoma
I think you read my mind. I’m thinking about a Coleman Mach 15 A/C. The local RV shop was trying to steer me toward a Dometic. They wouldn’t give a reason though.
07-20-2021, 05:14 AM
#27
Richmond
, Kentucky
Probably because they make more money off the Dometic.
07-20-2021, 06:45 AM
#28
1984 27' Airstream 270
West Chester
, Ohio
How did the brake job work out?
Regarding AC, I have a gen 1 dometic 15k penguin as my only unit. I’m guessing installed in the 90’s. It required a motor replacement due to what I believe to be coil damage from low voltage conditions. It was a pretty invasive job and if it was any older, would have probably broken lots of plastic parts trying to disassemble.
The unit is up and running again, but at 20+ years is likely nearing end of life. Replacement parts are certainly more limited and dometic was not the source of my repair parts. All were found aftermarket.
The main reason I didn’t go new was for the convenience of keeping the same thermostat and AGS system
07-20-2021, 01:18 PM
#29
1978 28' Argosy 28
Haskell
, Oklahoma
Replaced the master cylinder and both front rubber lines. I still need to do rear wheel cylinders but it stops good now.
07-20-2021, 02:25 PM
#30
1978 28' Argosy 28
Haskell
, Oklahoma
Does anyone have the part number for the leveling air valve?
07-20-2021, 07:39 PM
#31
West Chester
, Ohio
Does yours have American carrier system? Also wondering if you have single valve or dual?
07-20-2021, 10:35 PM
#32
1978 28' Argosy 28
Haskell
, Oklahoma
Not sure, it’s gone but I know it used to have 2 valves.
07-25-2021, 08:05 AM
#33
West Chester
, Ohio
this is what I have on 1984 270
07-25-2021, 08:37 AM
#34
1978 28' Argosy 28
Haskell
, Oklahoma
Thanks!
So I hooked water up for the first time and I’ve got a leak. I’m thinking about redoing the whole system in Pex.
07-27-2021, 04:42 AM
#35
West Chester
, Ohio
Upgrade to PEX is a great idea. If you haven’t needed to remove anything due to water damage floor, the trick is access all the plumbing through closets and under cabinets
I did this when it was empty and found it to be a job. The crimping my tool is pretty big as well…if you take this on please post pics of your contortions!
07-28-2021, 10:52 AM
#36
1978 28' Argosy 28
Haskell
, Oklahoma
Will do! lol
That will likely be a winter project or at least after the AC is sorted out.
I’ve been looking at AC units. Are the heat pump units worth while? Does anyone have any suggestions? I like the Coleman Mach 15.
Side note- Someone removed the actual heater from this coach.
07-31-2021, 10:42 PM
#37
1978 28' Argosy 28
Haskell
, Oklahoma
So I was tracking my water lines down to fix my leak and ran into this thing under the nightstand. Was this a factory option?
08-01-2021, 06:08 AM
#38
West Chester
, Ohio
I have a heat pump AC unit and don’t use it. It only works to provide heat down to about 40 deg F. After that, it will freeze up and transition to furnace
IMO, you should have a propane furnace to provide heat when it really gets cold. Or some have done an ALDE system
08-01-2021, 11:36 AM
#39
1978 28' Argosy 28
Haskell
, Oklahoma
I was afraid there wouldn’t be enough usable range to make it worth while. I’ll just have to find the proper furnace.
