The tank on my hot water heater is cracked almost all the way around the outlet bung. So best bet looks to be to replace the entire heater. Any advice for a 1975 Argosy? The heater is dual propane and electric. Thanks in advance.
al
Most likely you had an Atwood 6 gallon water heater. Over the years they came with different options. Some had a pilot light, then later they had electronic ignition and newer ones has the gas or electric option. Find the model that matches your version or upgrade (additional work required) to a newer model.
Richard Wally Byam Airstream Club 7513
Why was this post moved from the motorhome section?
1975 24' Argosy Motor Home
We installed & removed 2 Atwood heaters and the quality control was awful. Each one had leaks in different spots. We gave up and eventually just made the whole camper "hot" when we shower by using one of these on the inlet side.
