Old 03-20-2006, 10:00 AM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Question Mystery Part
OK, I stopped playin with engines about the time they started adding all the smog stuff. I do not think this has anything to do with engine performance.
Maybe Cruise Control?
There is an actuating arm, connected to the center of it that looks like it attached to the throttle linkage???
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-20-2006, 10:31 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Andre, that is the vacuum motor for the cruise control. It should have a vacuum hose from the intake manifold leading to it via the cruise transducer.
Old 03-20-2006, 03:35 PM   #3
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Thanks, I suspected that is was, Hope I can get it working again!
www.balrgn.com
Old 03-20-2006, 04:58 PM   #4
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Andre,
Don't even try, the old vacuum cruise control never worked well even when it was working. You can purchase a nice electronic unit from JC Whitney for about $100.00 and it will do the job better than that old one will ever be able to. I messed around with ours and spent too much time and money on it before I learned that lesson.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 03-20-2006, 05:08 PM   #5
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Originally Posted by Chaplain Kent
Andre,
Oh, come on, you gotta let me try
www.balrgn.com
Old 03-20-2006, 05:28 PM   #6
Well Preserved
1993 21' Sovereign
Andre, you can go to almost any salvage yard that has 1970's-era GM cars and trucks sitting around, and start replacing things until it starts working again.
BTW, the part that USUALLY goes bad, is the transducer. You should have a speedometer cable going into it, and another one going from it into the speedometer head.
Old 03-20-2006, 05:30 PM   #7
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
It looks at a glance that the fastener slipped off. I am only thinking of reconnecting it to see if it works, if not, Kent is right, new is better
www.balrgn.com
Old 03-22-2006, 05:48 AM   #8
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cruise Control
Well, I at least have an understanding as to how the cruise control works. Pretty darn basic. The condition of the hoses and diaphragm are in poor at best. Several dry rot holes.
If I want cruise control, I'll have to go with one of those new fangled after markets...
www.balrgn.com
Old 03-22-2006, 07:21 AM   #9
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Words of advice.
You can reuse the turn stalk controls if you get an Audiovox cruise control. They have them at Autozone. There is a 4 wire molex connector that he control stalk connects to under the dash.
When you set the control module up set it for a manual transmission. That way if it overrevs the cruise will cut off. I did not do that and ended up having to buy a new engine
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
What is the MOST you have paid for an AIR STREAM part overlander Our Community 64 11-19-2002 05:15 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
12 VDC Mystery roessler Electrical - Systems, Generators, Batteries & Solar 3 08-01-2002 05:20 PM
