Old 05-17-2012, 08:26 PM   #1
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
My really bad AC install!
Before I get my Argosy, "George", painted, I want to address the roof. I have a few leaks. the main culprit is the Duo Therm AC unit. This unit originally had the Armstrong AC, then a Coleman AC, and recently a Duo Therm unit.
The unit sits between the spans and compresses the roof panels. The compression causes a big gap which lets in tons of water! The other issue is that the unit is flat and my roof is curved. You can also notice a really bad patch job near the front of the unit.
My other plans before painting call for a new Fan-Tastic fan and vent cover and a Jack TV antenna.
1) Is there a drip pan for Duo Therm Brick Air units to handle the rounded roof?
2) Should I build up the roof support to eliminate the roof compression? Right now I cut up some 2x4 pieces to minimize the compression.
ID:	158692   Click image for larger version
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 05-17-2012, 09:06 PM   #2
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Fairmont , West Virginia
When I added my Carrier HC to my 26' Argosy TT I layered styrofoam and then used a cardboard template to cut the styrofoam to the exact curve then installed them all around. Tighted up the bolts and I have never had any more leaks.
shermantic is offline   Reply With Quote
Old 05-17-2012, 09:11 PM   #3
ViewRVs's Avatar
1977 20' Argosy 20
First, I did not do the install. This is from a PO.
That is a great idea. I don't want to buy a whole other unit but I want it to be installed correctly.
Fred H.
Old 05-17-2012, 10:29 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
When you reinstall the unit have a new gasket there. Just support the cutout between the inside and outside skins. I used untreated wood. I ran the lateral fir strips from rib to rib. The two cross pieces I cut with a slight curve to match the trailer profile. Mine hasn't leaked in two years.
I didn't use a pan. I'll do that next time . . . maybe.
Old 07-07-2012, 02:03 PM   #5
ViewRVs's Avatar
1977 20' Argosy 20
I did get the AC unit off today. I had to stop when the temperature hit 96 and you could fry an egg up there!
I can clearly see the outline of both the Armstrong and Coleman units. It appears there are screw holes around the perimeter of the original Armstrong unit that are the source of my leaks! My hunch is that the footprint of the Coleman unit covered the holes and minimized any leaks (that and the unit was in Montana with not as much rain!).
After I clean all of the old sealant and silicone, should I fill the holes with Olympic Rivets?
ID:	162591   Click image for larger version
ID:	162593   Click image for larger version
Fred H.
Old 07-07-2012, 02:08 PM   #6
ViewRVs's Avatar
1977 20' Argosy 20
Here are three more pictures of the roof. My next step is to cut the 2x4 boards for a frame to match the slope of the roof so the panels do not get pinched in when I tighten it down.
ID:	162595   Click image for larger version
Fred H.
Old 07-07-2012, 02:10 PM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
beckybillrae just put photos up of her daughter's install of an AC to replace the original Armstrong. Nice set of photos, including bracing the roof. See http://www.airforums.com/forums/f427...ml#post1171096
It sounds like you are doing it right this time.
Vaughan
Old 07-07-2012, 03:00 PM   #8
1988 32' Excella
Robbinsville , New Jersey
Yes filling the holes with Olympic Rivets is a really good idea.
Old 07-07-2012, 03:51 PM   #9
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Don't forget the vulkem and HI Fred
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-07-2012, 08:47 PM   #10
ViewRVs's Avatar
1977 20' Argosy 20
Hey Peter! It looks like you've traded for a larger unit and I downsized since we last met!
Vulkem
I know where to order the Vulkem 5xx. I'll have to re-read the threads about 536 or 526. Will the real Vulkem please stand up! I assume you place some in/around the hole and then insert the rivet?
Olympic Rivets
I've seen how to do the Olympic rivets but I've never done them. The tool seems to be $200 dollars. Is there a less expensive better alternative? Any particular size I should order?
Fred H.
Old 07-07-2012, 09:09 PM   #11
Airstream Driver
1997 30' Excella
Images: 51
Vulkem
Olympic Rivets
Yes, Fred, I sold the ole trusted 79, so i could get something smaller and easier to work on . But I have been enjoying working on this 87 345, the previous owner took care of it mechanically, just needed the new generator installed and lots of exterior cosmetics.
I forgot which vulkem, but would not matter for olympic rivets anyways. Just put a little in the hole only, the rivet will take care of the rest.
Good news, you do not need the expensive rivet shaver, since they will be covered or out of sight. After you set the rivet, clip the stem as close to the rivet head as possible and then use a simple metal file to make it flush with the head. done!
AIR #13
Old 07-07-2012, 09:38 PM   #12
ViewRVs's Avatar
1977 20' Argosy 20
3/16" or 1/4" rivets? What is the drill bit size for each one?
I have the go-ahead from the wife to order the tool to smooth them down. I want to do this correctly since I am taking "George" in for painting next month!
I am going to clean off the surface in the morning before it gets too hot outside.
Fred H.
Old 07-07-2012, 09:48 PM   #13
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I used a Dremal tool to shave down the stems of the Olympic rivets and they really came out looking good.
As for the rivet size? Sorry I can't help you there.
I ordered mine from Inland RV, I had no idea what size I needed or what they sent but they worked.
Garry
Old 07-07-2012, 09:56 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Garry;
What tool did you use in the Dremel tool to shave down the Olympic rivets?
TG Twinkie is online now   Reply With Quote
