Old 09-11-2012, 08:43 AM   #29
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by 1985air345 View Post
The antenna is the Jack antenna by King Controls (thread).
It is designed for the digital TV signals. It has a signal meter and a rotating knob on the inside ceiling so there is no guessing about the signal strength. The wall outlet has a signal booster. I have heard very good things about the antenna. I also like the futuristic look!
Have you had a chance to use/test the JACK antenna? I've been looking at that one, since the PO of my trailer removed the antenna altogether so I'm starting from scratch I figured I'd go modern with that if it performs well.
David
Old 09-11-2012, 10:04 AM   #30
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
I have not used it in the field yet. I just used it from my home parking spot. I was able to get four local stations with max signal strength. I use a USB TV tuner and my laptop for TV viewing. The picture looked really good.
I first saw the Jack antenna at Camping World but what sold me was seeing it on Jim Bound's Argosy 20 in Orlando. Jim runs the Cooperative Motorworks in Orlando. He has heard good things about the antenna from GMC owners.
I will be "field testing" it in October (2012)!
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 09-11-2012, 11:21 AM   #31
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
The JACK antenna comes in 2 flavors. The one like Fred has is simple, nothing to crank up or down, it rotates with a knob on the ceiling base which also includes a built in signal meter which is helpful in getting the antenna pointed towards stations before running a scan on the TV.
The other is designed to be a replacement for the antenna element such as the Winegard Sensar. A separate signal meter is optional and the head uses the existing Winegard power supply. A pole bracket and 110 wall wart is included so this model can be used as a residential antenna.
A vendor was selling the JACK at the spring Samboree in Waco. A fellow chapter member bought one to replace his non functional Sensar and had excellent results. Installation of the replacement was a snap as he had ready ladder access to the roof of his 5th wheel.
Another member later bought one from Amazon and claimed he was getting twice as many watchable channels after replacing his Sensar.
I borrowed his JACK for a test.
Test 1: Winegard Sensar III with Wingman, antenna pointed towards most distant stations. Ran scan, 21 watchable channels.
Test 2: Swapped Sensar with JACK, pointed in the same direction and reran scan, received the same 21 watchable channels.
My assumption is that his noted improvement was due to either a dirty coax connector at the head that was unknowingly corrected by reseating the connection or he had a weak amplifier in the Sensar head. I did note that the JACK seemed to have a wider field of view than the Sensar. That is, I was able to turn the antenna further left or right before the channels started to freeze and pixelate.
I don't know how this would compare to the model Fred has as his sits closer to the roof. My conclusion is that either would be a good choice as a replacement for a missing or non functional antenna. The integrated signal meter on the model Fred bought is a real plus and with nothing to crank up or down there's less concern with low hanging branches or forgetting to lower the antenna before pulling out.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 09-11-2012, 01:07 PM   #32
DKB_SATX's Avatar
1976 Argosy 28
Silver Goose: Thanks! That's the most believable test I've seen on the JACK. "As good as Sensar" is a good sign. I'm planning to mount it on the JACK mount since I don't have a Sensar to modify, and like the no-retract-necessary aspect.
David
