Old 07-07-2012, 10:05 PM   #15
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I used one of the metal quick connect disk and shaved 54 rivets, took around 30 minuets.
I suspect the tool is faster but the price is fairly steep.
Garry
Old 07-08-2012, 07:08 AM   #16
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by 1985air345 View Post
3/16" or 1/4" rivets? What is the drill bit size for each one?
I have the go-ahead from the wife to order the tool to smooth them down. I want to do this correctly since I am taking "George" in for painting next month!
I am going to clean off the surface in the morning before it gets too hot outside.
Exterior Olympic rivets are 5/32. Buy yourself a new univolt or 1/2 tire for the cost of the rivet shaver, that's IMHO a better way to spend $200. I only bought it, because I had thousands to shave...
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-08-2012, 08:35 AM   #17
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I have created an a/c "kit" that consists of two curved bow sections and two sections of Z channel to rivet around the hole where the old a/c was, so the new a/c has something to clamp to. I'll see if I can transfer photos from my phone to here.
Old 07-08-2012, 08:50 AM   #18
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
Another option is to get some thinker aluminum (like stop sign thickness) and cut it a bit larger than the original flashing that was on it to cover the screw holes and give it plenty of surface area. When you screw down the large piece it will bow correctly and will create a strong platform for your new ac. You would need to cut a hole in it once it's on there, but that's easy. I completely removed my ac from the top and used thick aluminum and you can nearly walk on it if you are so inclined. Personally I would not use wood, but that's just me.
Eric H is offline   Reply With Quote
Old 07-08-2012, 09:15 AM   #19
Well Preserved
1993 21' Sovereign
Okay, I got the photos, after the window of editing expired.
Name:	2012-06-29 14.51.28-1.jpg
ID:	162696   Click image for larger version
Name:	2012-06-29 14.51.43.jpg
Old 07-08-2012, 09:51 AM   #20
Eric H's Avatar
1974 23' Safari
That looks solid! Better than wood!
Old 07-08-2012, 11:49 AM   #21
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Nice job Terry!
Vaughan
Old 07-08-2012, 12:05 PM   #22
1981 31' Excella II
New Market , Alabama
You could put stainless screws in the holes or pop rivets. Seal them with Trempro-635 or something similar. No reason to use Olympic rivets just to fill a hole. Did they put in something between the skins around the vent opening to strengthen it? Most folks use wood to strengthen the box area. Airstream used some sort of channel to stiffen the box around the vent hole.
Perry
Old 07-08-2012, 12:07 PM   #23
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
A little off the top please!
Today I started cleaning the old Vulkem and caulking around the AC. I removed the old antenna post, antenna stand, and the old roof vent.
I forgot the stripper gloves so I still need to finish cleaning the surface when it is cooler.
There is not any support around the AC opening. I do have some 2x2 boards and some wood shims. I am going to frame the box around the hole before putting the AC unit back up.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 09-10-2012, 08:03 PM   #24
ViewRVs's Avatar
1977 20' Argosy 20
No leaks!
I am pleased to report that I finished my roof repairs and I have NO LEAKS after a solid day of rain!
I put the whole story and more pictures on my blog. The source of the leaks was the AC install and the old rivets that were left open or partially removed.
I really like the way the roof looks and the new Fan Tastic (A6000) fan will be a great addition.
I ended up using almost 100 Olympic rivets so I am glad I purchased the rivet shaver. The shaver was very expensive but I figured I saved a bunch by doing this job myself.
Fred H.
Old 09-10-2012, 08:33 PM   #25
1982 28' Airstream 280
Redwood City , California
Tell us a bit about your TV antenna!
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 09-10-2012, 09:12 PM   #26
The unit sits between the spans and compresses the roof panels. The compression causes a big gap which lets in tons of water! The other issue is that the unit is flat and my roof is curved.
Fred,
I haven't looked but I'm guessing my 20' Argosy MH has the same issue you found with the original air conditioner install. I think I need to salvage some ceiling rib spacers from the 345 before the remains get hauled off.
Thanks for posting your findings.
Old 09-11-2012, 06:56 AM   #27
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
ditto that, Fred?
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 09-11-2012, 06:58 AM   #28
ViewRVs's Avatar
1977 20' Argosy 20
The antenna is the Jack antenna by King Controls (thread).
It is designed for the digital TV signals. It has a signal meter and a rotating knob on the inside ceiling so there is no guessing about the signal strength. The wall outlet has a signal booster. I have heard very good things about the antenna. I also like the futuristic look!
Fred H.
