Old 09-17-2012, 08:05 AM   #1
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
My new project - Argosy 24'
Hello everyone. I am in the process of purchasing my first RV, which happens to be a 1976 Argosy 24. My wife and I had always enjoyed camping but we never had any of our own equipment, always borrowed my dad's place for the weekend. I started looking around on CL and other local classifieds to find something cheap that we could try traveling with. One of my coworkers got wind of what I was doing and said his dad had this old motorhome sitting on his property that he had started parting out. He sent me some pictures of it (see attached) and I was immediately interested. I was even more interested when he said the asking price was only $300.
So here is what is needs besides the obvious interior:
-Fridge
-Stove
-Toilet
-Water heater
-Brake lines (pedal went to the floor)
-Rear tail lights
-Mirrors
Also, it doesn't run but it did when it was parked a bunch of years ago. I did some basic diagnosis and I think it's just a grounding issue. Surprisingly the generator is still with it. Something interesting I found under the front is that there were a few air lines that were capped off near the battery tray. Any idea what they are for?
If you guys (and ladies) have any idea where I can find some of these parts let me know. My plan is to keep it looking original on the exterior but upgrade the interior to a more modern contemporary design. The interior was 'upgraded' at one point so most of the original stuff is missing and it is currently torn apart.
I will keep this updated as I make progress with the resto!
ID:	168509   Click image for larger version
ID:	168511   Click image for larger version
mprokop87 is offline   Reply With Quote
Old 09-17-2012, 03:05 PM   #2
First off, welcome to this forum! The members here have a wealth of information to share.
There is absolutely NO way you can go wrong buying the Argosy at that price. The windows alone are worth a lot more than that. With that said the real issue is are you capable of handling mechanical repairs (both engine and coach repairs) yourself? If the answer is yes then it's a great deal. If the answer is no then you will be spending a ton of money to get it road worth and ready for use. If you can just do some of the work then I would probably say the answer is yes, buy it.
-Fridge
-Stove
-Toilet
-Water heater
-Rear tail lights
-Mirrors
Fridge: $1000 to $1600 depending on size
Stove: $350 to $500
Toilet: $100 to $150
Water heater: $300 to $500
Brakes: $200 to $800
Tail lights: $200 (depending on what all is missing you might need to adapt airstream trailer lights since the Argosy mh lights are no longer available.
Mirrors: $100 to $600 (I might have a pair from a 310 available)
You can buy some of the items above used if you're careful and do your homework before buying.
If the motor isn't frozen then there is a good chance the engine will be ok. If you haven't turned it over yet I would squire some automatic transmission fluid (ATF) down each cylinder and let it sit for a few days before cranking it over. The air lines are likely for front air bags that are/were located inside the front coil springs on the suspension. The bags are typically inflated to 55 psi and help improve the ride.
Having a generator is also good but will likely need a thorough going through before regular use.
Surprisingly I've got a lot of the appliances for our 310 from ebay. Prices seemed to be as good as found elsewhere and I have yet to have an issue with a vendor.
The interior would probably be the least of my worries. You can literally make it into anything you want.
Good luck and keep us posted as to what you end up doing and your progress.
Old 09-17-2012, 03:16 PM   #3
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
That's a great buy!
I'd love to have one, but the wife's cut me off, I'm not allowed to buy anything else with wheels.
In that condition you can make it what ever you want.
I do an almost daily search for Airstream on Ebay, CL ect, and I put the word out to my car guy friends when I need parts, it's amazing who has parts you need.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 09-17-2012, 03:17 PM   #4
Oh yeah, almost forgot tires. Expect to spend $1000+ for the six 16" tires.
You might want to check the tire size and if they are 16.5" tires then start looking for some replacement 16" wheels from a 70s or 80s chevy 1-ton dually pickup. 16" tires are a lot cheaper than 16.5" tires and a lot easier to source as well.
That's what I did on for my 74 Argosy mh and I'm glad I did.
Finding wheels at a good salvage yard shouldn't be to difficult. You've got enough to do that new wheels and tires shouldn't be needed for a while anyway
Old 09-17-2012, 03:20 PM   #5
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I agree with bkahler. You can not go wrong at that price. Good luck and keep us informed (with pics) with your progress.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 09-17-2012, 04:36 PM   #6
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 36
What a Find...
... and what a great project!
I suggest you find a good mechanic to help you with engine, drive train, and all the other automotive stuff.
Take it one step at a time.
The Magic Chef stove you need is for sell in the classified sections of these forums.
bkahler has provided some really good advice.
Keep us posted.
Give us more pictures, please.
Ken L
1966 Tradewind 24
2018 GMC Yukon XL Denali
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 09-17-2012, 05:34 PM   #7
1988 32' Excella
Robbinsville , New Jersey
Nice find I would spend a little extra and get a ceramic toilet instead of plastic.
Old 09-18-2012, 05:12 AM   #8
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
Thanks everyone for helping to reassure me that it was a good buy! I was not too sure at first because of the work involved and my wife is still not sure why on earth anyone would ever want one of these. BKahler, I will be doing most of the work myself (engine included). This thing ran when it was parked 8 or so years ago. The electronics stopped working when someone hooked a battery up with reverse polarity, however, I do not think that this would do any damage and that it was a pure coincidence. I did some testing of the battery cables and I can't seem to get any voltage at the other end of them so this is leading me to believe it is either bad cables or bad ground. Once I replace the cables I will go from there.
Right now my big task is to get the darn thing back home. It's still at the other owners house burried in the stone pad that it was parked on years ago. Surprisingly all of the tires are still holding air! As soon as I get a spot cleared out in my yard I am going to have AAA tow it home. Hopefully this will happen within the next 2 weeks and I will post some new and detailed pictures of her at her new home!
Old 09-18-2012, 06:04 AM   #9
I can't say for certain but there should be a battery disconnect switch somewhere near the battery compartment. So it's possible that the switch is turned off. I'm not certain if the battery cutoff switch affects only the coach battery or the coach and starting batteries.
Assuming it is not the battery disconnect switch the first thing I would do is pull all of the spark plugs so that once you get it to turn over you can build up some oil pressure. Once you have oil pressure then you can try and start the engine. On an engine that has sat that long the bearings are going to be pretty dry so pre-lubing by turning it over without compression will definitely help.
Be very leery of of having it towed. The back end of the motorhome can easily be damaged by idiot tow truck drivers. I would spend the few extra bucks and have it hauled to your place on a flatbed tow truck. Besides, while it's up on the flatbed you'll have a chance to look at the undeside
Old 09-18-2012, 08:25 AM   #10
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
Brad,
Thanks for the tips. I was planning on replacing the plugs anyway, I just hope they aren't too bad to get out. The motor home has sunk into the ground so it was hard to get a good look at the bottom side of the engine. Wouldn't that be something if it was just a kill switch? I can only hope!
My AAA usually brings a flatbed. I checked with them and my current policy covers me for car and RV towing. If I get the right person and I give them the right story I might even be able to get a free tow! If not, it's only a few miles from my house.
Also, I will keep you in mind for the mirrors when I start buying parts. Right now I am not purchasing anything because I do not have the paperwork in my name. As soon as the current owner gets back in town from his business trip (this friday) we are going to setup the transportation.
Matt
Old 09-18-2012, 03:51 PM   #11
Matt,
Something else to look for would be any wiring that might have been chewed by mice or rats. Unfortunately that is a common occurrence on these sort of vehicles. It's amazing what they seem to find tasty
Good luck!
Old 10-21-2012, 03:30 PM   #12
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
Update:
Yesterday I was at the place where my Argosy has been sitting for the past few years. She has been emptied out and ready for transport. Based on the last registration sticker she was last moved in 2004 so she sunk into the ground 8 inches or so. With the help of some hydraulic jacks and some chunks of 4x4 it's now sitting level on land. To my surprise, none of the wheels were frozen. I thought for sure one or more would be frozen up. I'm going to over later this week to see if I can get her to turn over. I would love it if the engine would fire up but I'm not counting on it. Once I get it home I will post some updated photos!
Old 10-21-2012, 03:42 PM   #13
Matt,
I was wondering what was happening with your project. Having the brakes free is a definite bonus after having sat for so long. My 74 Argosy has sat for about 2 years and I had a heck of a time getting the right rear drum off the other day.
Good luck getting it started. You can use starter fluid (judiciously) as you try to start it. If you try and draw gas from the fuel tank check to see if it has an electric fuel pump and if it does make sure it is energized when the ignition is on.
Probably your better alternative would be to use a 5-gallon gas can with a rubber hose ran from the can to the carb. That will elminate any problems with the fuel delivery system.
Good luck!
Old 11-03-2012, 04:38 PM   #14
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
So big news, SHE RUNS!
Brad, it looks like you were right about the cut off switch. There is a solenoid near the battery box (I thought it was that starter solenoid) that is used to shut off power to the dash and ignition. The switch used to turn the solenoid on runs off off the coach batteries and since there are no coach batteries in the Argosy, that solenoid won't turn on. I bypassed it and was able to get the engine to turn over. With a little starting fluid she started right up, no issues. There is a slight miss but I think it will go away when I replace the plugs. It was also smoking blue a bit but that died down after running for 20 minutes. The only thing that I do not know is if it will shift into gear. I tried to shift it but the tranny is a little low on fluid. I will pick some up tomorrow or this week.
Overall I am ecstatic about today's progress. This week and next weekend I am going to start working on the brakes so I can easily move it around. Once that is done I am going to start putting the basic systems back into it. There is a junk yard in Buffalo, NY (only an hour drive) that I used to go to when I was younger and lived there. They get in RVs and I should be able to get a water heater and the drinking water storage tank/pump. Might even be able to pick up a nice stove and fridge. I will keep posting pics and updates in this forum to keep you guys/gals up to date.
Name:	2012-11-03 13.26.06.jpg
ID:	171977   Click image for larger version
Name:	2012-11-03 15.52.14.jpg
Any interest in a US (mid west) Argosy salvage / repair yard? Sprouty All Argosy Trailers 3 08-09-2013 08:35 PM
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 08:46 PM
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 10:18 PM
Project 24' Argosy in Central CA.. Rick F Argosy Motorhomes 0 08-09-2011 04:06 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 12:11 PM
