Old 09-12-2015, 12:46 PM   #1
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
More fuel tank woes
Well we definitely aren't on top of the fuel tank issues.
We are due at the NEU Rally in Plymouth this weekend but DW couldn't finish work until late last night so the plan was to catch up this morning.
I knew we only had about 4 gallons of gas on board from running out the other week. So first stop after loading up was the local gas station. This time it was filling remarkably easily until it cut off at around 24 gallons, still way under what should be the capacity.
At that point I notice gas running out of the bodywork surrounding the gas tank, and the leak got worse and worse - there is obviously an issue with the tank itself.
I managed to get the panel off whilst DW ran in an informed the gas station of the issue. The gas is pouring from the top of the leading edge. I quickly loosen the drain plug and try and let enough out to drop below the leak, luckily I had a couple of bowls and DW walked back and grabbed the 5 gallon can but I ended up having to remove about 2.5 gallons to stop the leak. It appears that as soon as I was below the leak it stopped fine so there must be a bad weld or pinhole somewhere about half way up.
Drove back home now trying to get a little cleaned up before making attempt number 2 to get to the rally.....
martin300662 is offline   Reply With Quote
Old 09-12-2015, 01:49 PM   #2
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Well that was short lived......
No more leaking fuel but about five miles into the journey, a car pulls out in front of us, I jump on the brakes (we were doing about 55mph), we stop, but the break warning light comes on and is stuck on, so we must have popped a seal somewhere. Brakes seem to be working fine, but we played safe and drove home. Oh joy!
Old 09-12-2015, 02:37 PM   #3
1982 28' Airstream 280
Redwood City , California
Or your brake proportioning valve...
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 09-12-2015, 06:16 PM   #4
Keen amature
1975 20' Argosy 20
Chestfield , Kent
You maybe right Dean, certainly can't see any obvious leaks.
Old 09-12-2015, 08:11 PM   #5
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Anyone know where the proportioning valve is on an Argosy? Is it built into the MC, as it appears one circuit?
Old 09-14-2015, 10:52 AM   #6
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Follow the hard brake lines to the valve.
NavyCorpsman is offline   Reply With Quote
Old 09-14-2015, 11:14 AM   #7
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Thanks, I have tried that. They all seem to come together under the MC, at the moment I can't see there is a separate valve of the valve is mounted to/under the MC. It will have to wait until the weekend now as I am heading to the airport straight from work. Working in Graz, Austria for the rest of the week.
Also it looks like either the lock ring around the sender is loose or the return fuel line is not attached to the send on the tank. So hopefully that is easier to fix than first thought. Fingers crossed anyway!
Old 09-14-2015, 09:38 PM   #8
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Perseverance Martin
You're going through the same year I'm going through, a debugging year. Between broken fan belts, throttle cables, compressors and water check valves it adds up to more down time than I wanted for this year.
Look on the bright side, you weren't far from home.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 09-15-2015, 06:59 AM   #9
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Cheers
Tony
For sure, and as I said to DW I had already said I wasn't happy with the brakes - just means it turned from an adjustment to a probable replacement!
Old 09-15-2015, 10:03 AM   #10
Regular Guy
1978 31' Sovereign
Long ago I was able to free up a PV switch by bleeding the front brakes. Have an assistant pump hard ( not rapidly but with some force) while the bleeder screw is fully open. As your assistant continues to pump, close the bleeder screw as they push slowly on the pedal. Start with the passenger side wheel, then the driver. I use a small section of rubber tubing into a glass container to catch the fluid and prevent a backflow of air into the caliper/wheel cylinder. Hope it's an easy fix.
Old 09-25-2015, 10:36 AM   #11
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Amazing.....after much phoning, emailing, and DW visiting and ask personally, and every 'frigging' truck and auto shop refusing to even look at the brakes on Bella. I have a day off, so go back to square one and 'door-step' the transmission shop which is across the road from our house. The guy says, 'oh yeah I remember your wife coming in....didn't I get back to you? yes of course we can do it'.
Arggghhhhh! I think someone needs to study the impact on life expectancy from the frustration of owning one of these 'old dears'.
Old 09-25-2015, 03:05 PM   #12
Glad you've found a place to fix it.
What I'm wondering is what's it going to be like trying to find service shops once you take Bella across the pond
Old 09-25-2015, 04:30 PM   #13
Dazed and Confused
Isuzusweet's Avatar
The very same impact as a pre-facelifted Jaguar XJS V12, Triumph Stag TR7-8, all TVR's and Austins, pre 2000 Rollers and all Rovers, Range or otherwise...... I seem to be detecting a common thread here.
Keep a stiff upper lip Martin.
Cheers
Tony
Old 09-25-2015, 04:50 PM   #14
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Hmmm, note the "do more"
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
F250 Fuel Tank - Add or Replace for more Capacity? Boogieshoes Tow Vehicles 24 09-13-2015 09:07 AM
fuel gauge woes Mike Leary Airstream Motorhome Forums 15 07-17-2014 09:19 PM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 07:56 AM
Fuel Line & Fuel Tank crazeevw Mechanics Corner - Engines, Transmission & More... 4 12-02-2011 08:38 PM
More Henschen Axle Woes baywolfblu Axles 1 10-03-2006 11:28 AM
