Old 08-01-2017, 02:30 AM   #1
1977 28' Argosy 28
Baytown , Texas
MoHo Generator sliders, anyone do this?
So I'm still waiting on my harness and want to fix some other mechanical issues while I wait. Has anyone installed sliders on your generator? I want to do this on my Onan. Apparently the generator weighs about 240lbs so I need sliders that hold 300 lbs. I need to measure how wide the gen tray is but these are a good start. Lots of reviews say they were used for generators.
https://www.amazon.com/Drawer-Slide-.../dp/B0009ODZMM
Jjona5 is offline   Reply With Quote
Old 08-01-2017, 03:56 AM   #2
Long Island , New York
No experience with MH generator slides personally, but plenty of cabinetmaking experience, so some general considerations follow.
Those slides mount to the sides of the generator enclosure, with the drawer fitting between them. Do you have the necessary width to permit this? Does the enclosure have stable, and more importantly parallel, sides? The drawer slides are fairly demanding that they be mounted exactly parallel to each other, and that the structure of the enclosure sides permit cantilevering the heavy load mostly outside of the MH. Your slides are 22" full extension but is this enough? You might need access to the back of the gen for wiring and plugs.
There are also slides which mount under the "drawer" being moved in and out, but in this case available height may be an issue. Most MH generators are fairly well crammed in to their spaces IMO. The good news about under-mount slides is that you don't need your generator enclosure to have sides at all, just a "floor" that is reasonably flat and level +/-.
The new search function above with the blue border works well, and here are the results for "generator slides" which include some motorhome threads it appears:
https://www.google.com/search?q=gene...=airforums.com
A MH thread: http://www.airforums.com/forums/f311...-144957-3.html
When you get the Google-powered search results on their own page in your browser, you can edit the search parameters as you wish. Just make sure to leave "site:airforums.com" as one of the search terms.
Good luck!
Peter
Old 08-01-2017, 04:17 AM   #3
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Dont forget disconnects for the battery, exhaust & fuel.
I thought about slides for mine but eventually figured that unless it needs servicing frequently, the stock mounting is probably best.
If it needs servicing frequently, a new gen set would be less effort in the long run.
WayneG is offline   Reply With Quote
Old 08-01-2017, 08:39 AM   #4
I installed drawer slides on my 84 310 with the Kohler generator and I just finished drawer slides on my 74 Argosy. Of the two the 310 was the easiest by far. A lot depends on the type of generator cover that is installed. On some models the cover is hinged on the side and there is no way a generator can be mounted on slides. On my 310 the cover was fastened with screws on the bottom half and hinged on the upper half. To pull it out on the drawer slides the cover had to be removed. Which was 6 screws and it was off.
310 generator drawer slides install
On my Argosy the original Generac generator was welded in place from the bottom so the only way to remove it was to torch the welds. I decided to replace the Generac with an Onan 6.5 Emerald which is ironically smaller than the typical Onan 4.0 that is usually used in the smaller motorhomes.
The 6.5 was a shoe horn fit but it did fit
If you start at post #707 you'll see my Argosy generator installation.
There are varioius styles of drawer slides available. On my 310 I inadvertently bought slides that only extend about 2/3 of their overall length. On my Argosy I bought full length slides. Weight is something else to consider. Generators typically weight between 250 and 300 pounds. I bought 300 pound slides for the 310 and 500 pound slides for my Argosy. They also sell latching and non-latching slides. Go for the latching style.
The bottom line is slides are definitely nice to have, especially with older generators where it seems you need to service them more often. I was having issues on my 310 generator and I would have had to remove and install the generator multiple times before the problem was resolved.
The only real hassle using slides is the exhaust pipe. No matter how you do it the exhaust pipe(s) will need to be removed before you can extend the slides. Not a big deal, I just run the generator without a muffler while I have the slides extended.
For the electrical I bought a 30 amp plug & socket so the power could be disconnected easily without having to open any electrical panels to unhook wires.
For the fuel I added a T in the line with two shutoff valves. One side of the Tee went to the fuel tank, the other side of the Tee had a section of hose attached that I could stick into a gas can that I set on the ground by the generator. The other leg of the Tee goes to the carburetor.
Old 08-01-2017, 11:32 AM   #5
1977 28' Argosy 28
Baytown , Texas
Thanks so much for the input! I'll take it all in before I decide.
Old 08-01-2017, 12:48 PM   #6
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I ran into the same issues. It was more problematic than convenient. Once you go through the motions and actually planning it out, you will likely come to the same conclusion.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 08-01-2017, 01:34 PM   #7
I guess that would depend on your point of view and what you're trying to accomplish. I found the conversion on the 310 to be pretty straight forward and wasn't all that hard to accomplish. On my Argosy if I had to hard mount the generator then I would never be able to work on it, period.
So I guess for me it wasn't problematic at all, more of a relief to be able to work on them out in the open when needed.
Old 08-01-2017, 02:26 PM   #8
1977 28' Argosy 28
Baytown , Texas
Well I am kind of a clean freak when it comes to engines and not being able to truly clean up after maintenance is kind of a nightmare for me. I hate looking at the generator as it is. On an unrelated note, changing a fan motor on a duo therm air conditioner is a nightmare.
Old 08-01-2017, 02:41 PM   #9
WayneG's Avatar
Scotia , New York
You must not have hit "Engineer middle age" yet.
At a certain point in your years you will say "Fudge It, If it works, dont mess with it"
Old 08-01-2017, 02:57 PM   #10
1977 28' Argosy 28
Baytown , Texas
Not quite yet! My older friends constantly give me crap about painting engines and engine bays light colors. I want to see the leaks!
Old 08-01-2017, 03:13 PM   #11
1973 31' Sovereign
van nuys , California
The 3320 Accuride drawer slide showing in your message is Not rated at 500 lbs.
Check with Accuride at Accuride.com for ratings and add 20% to your Onan generator depending on the extention length. Be very careful or it will FAIL!
Didier
starboard is offline   Reply With Quote
Old 08-01-2017, 03:25 PM   #12
2007 22' International CCD
My late father had white walls and floor tile in the engine room occupied by two GM-12/71 marine diesels. We maintained those beasts to total leak-free perfection. The space could pass a white-glove inspection even after a day of hard running. He was amazing as a ship-handler as well.
rmkrum is online now   Reply With Quote
Old 08-01-2017, 03:41 PM   #13
After working on my Argosy for the last 4 or 5 years and also being in the middle of a TR6 frame off restoration I think I'm fast approaching the "don't mess with it" phase
Old 08-01-2017, 03:49 PM   #14
1977 28' Argosy 28
Baytown , Texas
ID:	291074Click image for larger version
ID:	291075Click image for larger version
MGB but it doesn't have a frame
Curtain Sliders For '63 Overlander squrlgurl Upholstery, Blinds, Walls & Interior Finishes 4 08-29-2014 08:29 AM
Gaucho Sliders Lumatic General Interior Topics 5 10-10-2012 06:54 PM
1962 Overlander Curtain Sliders gnored Upholstery, Blinds, Walls & Interior Finishes 0 06-12-2009 10:35 AM
Looking for curtain sliders for globetrotter mariestephan Upholstery, Blinds, Walls & Interior Finishes 6 04-21-2009 12:39 PM
1964 curtain sliders Safari64 Upholstery, Blinds, Walls & Interior Finishes 6 11-26-2008 06:49 AM
